What op amps in side the RME firefaces models?
  • jocondor
    • Feb 2016
    • 22
    • Italy
    Anyone know what op amps there are in side these units and obviously all other staff in side....
  • Khron
    • Sep 2006
    • 1350
    • Finland
    Re: What op amps in side the RME firefaces models?
    Google is your friend
    http://synthnl.blogspot.fi/2012/06/r...00-repair.html
    Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
    • jocondor
      • Feb 2016
      • 22
      • Italy
      thanks once again Khron you are a good web researcher...the internal RME design it seems pretty similar to MOTU design, it uses some visible IC's but I can not see what op amps it uses ....go on with the research especially of late and last models ufx and 802 or superior
      • Khron
        • Sep 2006
        • 1350
        • Finland
        I'm still not quite sure just how relevant "what opamps are inside" is, for repairing / servicing this sort of units
        If you're looking to upgrade opamps and such, that's a different story...
        • Khron
          • Sep 2006
          • 1350
          • Finland
          Did a bit more googling, and i came across this absolutely wonderful post, which i couldn't agree with more
          https://www.gearslutz.com/board/7269605-post19.html (post #19)
          It would seem RME use NJM2068's - https://forum.redfox.bz/threads/bit-...-7#post-200455
          ... Except that particular person has no clue how things actually work, and is just "parroting" datasheet specs, as well as imagining THD adds up numerically (which it most definitely does not).
          More confirmation: http://www.crome.org/wpn/inside-the-fireface-800/
          And some more good points: http://therecordingrevolution.com/20...one-told-me-2/
            • 31305
            all irelevent when the end customers are going to compress an mp3 with a 96k bitrate to stuff on a phone!!
            • jocondor
              • Feb 2016
              • 22
              • Italy
              Thanks for the infos Khron I want to see for further informations by Others forumers which had to do with RME or similar gears
              • jocondor
                • Feb 2016
                • 22
                • Italy
                after having seen what there is inside the RME I say that it's absolutely not convenient invest lots of money to buy these expansive interfaces cause they have exactly the same components as cheaper units...same op amps, same converters, similar caps ....sampe FPGA ....the only difference is the software and additional software functions implemented .....it should be interesting to take a look inside the top expansive interface by Prism Audio, Universal Audio Apollo (11), Apogee and so ON ....
                • Khron
                  • Sep 2006
                  • 1350
                  • Finland
                  http://www.harmonycentral.com/forum/...dio-i-30964997
                  PGA2500 mic preamps, and on the close-up of the DI board, there's an NJM2082(?) with a JFET input, and an NJM5532. Pretty safe to assume the rest of the opamps are also 5532's
                  http://gearautopsy.com/bla-finally-l...of-uas-apollo/ - and some NJM2068's as well, it seems.
                  http://cdn.shopify.com/s/files/1/043...g?v=1453744712
                  http://s1221.photobucket.com/user/Br...?sort=3&page=1
                  dCS 954 (A/D converter) - https://www.gearslutz.com/board/1820958-post70.html
                  Prism stuff (mostly older, though)
                  • rhomanski
                    nowhere man
                    • 5157
                    • U S of A
                    I use an infinite bitrate.
                    sigpicThe Sky Is Falling
                    • jocondor
                      • Feb 2016
                      • 22
                      • Italy
                      Khron you really are a GOOOOD web researcher.....hey the Apogee Ensemble cost 3000 EUROS !!! In side just 200 $ of components perhaps less
                      • Khron
                        • Sep 2006
                        • 1350
                        • Finland
                        Perhaps, but i'm not sure i wanna know just how many man-hours went into the development of the firmware (not so much the drivers)... That being said though, some of those DO indeed smell suspiciously much as overpriced-ness :P
                        And yeah, it takes a looooooooot of skill(?) to go to google, write the search terms, go to "Images", and just scroll down...
                        • jocondor
                          • Feb 2016
                          • 22
                          • Italy
                          Khron go on with your research please ....let us know other links
                          • Khron
                            • Sep 2006
                            • 1350
                            • Finland
                            Are you really THAT lazy to do a google image search? I know "outsourcing" is fun and effortless, but i really don't care what's inside that overpriced stuff
                            My 896mk3's working fine (along with my two recapped 8Pre's), just used it on a drum recording session this weekend, and that's all i care about
                            • jocondor
                              • Feb 2016
                              • 22
                              • Italy
                              sob.....Khronne you let me DOWN !!
                              • Khron
                                • Sep 2006
                                • 1350
                                • Finland
                                Read the first question from my previous message (again)... Or actually, the entire first line.
                                What i've found so far, i've searched just because i was in a good mood, and i was a tiny bit curious myself.
                                And i'm really sorry, you can put all the sad faces you want, but the last time i checked, i did NOT owe you ANYTHING
                                • jocondor
                                  • Feb 2016
                                  • 22
                                  • Italy
                                  No plz do not say that....come on ....I want to meet you once I will be on your country ....
                                  • montemcguire
                                    • Mar 2015
                                    • 15
                                    I disagree. The circuit board itself can have a significant effect on the performance of an analog circuit, as can the power supply and bypassing. Maybe it doesn't matter if you care very little beyond basic function, but the distortion of a circuit and the performance details are not just the result of the parts used.
                                    • diydidi
                                      • Sep 2012
                                      • 17
                                      • South Africa
                                      Not a fan of opamp rolling. If you want to better it, rather look at the power supply, filtering, heat management etc.
                                      • quic307
                                        • Jun 2015
                                        • 259
                                        • Greece
                                        Hello friends,
                                        Does anyone have schematic for RME fireface 800 ???
                                        Thank you.
                                        • flibidy
                                          Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                                          by flibidy
                                          I have here a Magnum IA.100 which belongs to my parents.
                                          The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                                          Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                                          What Ive done........
                                          01-01-2025, 01:26 PM
                                          A Dead/DOA Gigabyte GP-P450b 450W ATX PSU
                                          by momaka
                                          More eBay specials: this time a Gigabyte GP-P450b 450W ATX PSU for $8 with free S&H. Listed “For part/not working”, as usual. Showed up in a beat up EVGA box without any padding… but that's understandable given the total price. PSU made it out fine without damage. It's a non-modular (yay!), pretty modern-day looking PSU with a black paint and all black cables (meh, not my favorite, but figure it's good to keep a few of these in case I do need one for a more modern PC build, just so my old gray boxes don't look too odd in there.)
                                          And a shot of the label:...
                                          01-26-2022, 03:26 AM
                                        • Fisher8865
                                          MacBook Pro A1990 stuck at 5v .592 amps
                                          by Fisher8865
                                          Hi guys
                                          I have a MacBook Pro A1990 that takes 4.9 Volts and .592 to .615 amps on one port. The other port on the left side power cycles with about the same amount of volts an amps but quickly power cycles. The same thing happens on the other side but opposite. So on the left side the bottom port stays on and on the right side it's the top one. I think it is a CD3215 chip but I am not sure how to test it or where to get one. I have checked for voltage at ppbus_g3h and it has 12.6 V which is also on fuses f7000 and f7001 I checked pp1v2_s3 and it has 1.2 V then...
                                          05-30-2024, 07:36 PM
                                        • bouny56
                                          Lenovo E15 Nm-c421 usb-c work only in one side
                                          by bouny56
                                          ​Hello
                                          Laptop E15 I5 10gen
                                          Mb nm-c421
                                          I have a problem with the usb-c power dc.
                                          The motherboard start only in one side of the usb-c
                                          Replace the usb-c port 2 times same problem
                                          With the usb-c meter, one side 20v ok, other side the usb-c meter don't come on
                                          Try to test the pin with the Mechanic Tail insertion tester and every pin are ok ?
                                          Can the pd controler be the fault ? Or something else maybe ?
                                          Thx
                                          02-11-2025, 03:15 AM
                                          KingWin ABT-650MM 650 Watt ATX PSU [PCB: SW8835REV:A]
                                          by momaka
                                          For today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
                                          http://www.rmac.kingwin.com/products.../abt_650MM.asp
                                          I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
                                          What mostly drew me into buying it is its 2x PCI-E power connectors...
                                          03-29-2022, 11:34 PM
