Yamaha A-420 amplifier damaged from PC?
  • Bobhoskin
    • Mar 2012
    • 23
    • italic
    My Yamaha A420 it's dead!!!
    Here I think it's my fault, I've connect it on a PC without checking the soundcard volume output, that was at max volume.
    I turn on the amp and it came out like a frying sound at low volume slowly disappearing completely, even trying regulating the volume on the Yamaha amplifier. Until no sound came out.
    The max volume of the PC has burned something?
    Please, what is the first thing that I can check to replace inside the amp?
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: Yamaha A-420 amplifier damaged from PC?
    It wouldn't be unheard of. They are somewhat prone to blowing output... About as often as a CR-640 has a habit of blowing power fuses.
    Follow the white rabbit.
    • Coert van Dorsten
      Sansui Integrated Amplifier replacement volume control troubles
      by Coert van Dorsten
      Hi all you clever electronmic gooroos!
      I was wondering if you could help me with the below issues Im having on a Sansui Integrated amplifier. I bought this unit as a project to repair as Im playing around with basic electromics.The unit has a faulty volume control pot. The service maual refers to a 150K Logarithmic pot (A) tapered stereo. Im struggling to find this value. Seem to be a jump from 100K to 250K. Im now trying a 250K pot. It works but the problem is that as the volume is turned up from starting at Min the Left channel will come on first just slightly before the Right...
      Today, 02:54 PM
    • crackedprint
      Sony HCD-HX80R Amplifier Volume Control Problem
      by crackedprint
      I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
      I have tried a Cold Reset as per the service manual.
      I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
      I have looked all the way through the service manual and tried many online...
      01-21-2025, 12:18 PM
    • karthur
      Vizio D65x-G4 Volume changes on its own
      by karthur
      On this Vizio D65x, the volume will change on its own. I don't mean like during commercials where the volume will increase. I mean its like the (+) volume button on the remote is pressed and the actual volume dialog is displayed on the screen going up. It will do this, then the volume may start going down. It might go all the way to "0"or it might stop at a different number, then start going back up. The whole time its doing this, the volume dialog is shown on the screen.
      It wont do it until it has been "ON" for 20 or 30 minutes, so it does seem to be heat related....
      06-05-2025, 08:13 AM
    • roadrash
      Yamaha HTA-5630RDS Amplifier dead
      by roadrash
      Belongs to my son and he just says it stopped turning on. Any help greatly appreciated. Theres 240v in and fuse is ok but no power anywhere else.
      12-12-2024, 10:19 AM
    • BigOof
      Marantz SR5007 popping on volume change and mute in Direct Mode
      by BigOof
      I bought a used Marantz SR5007 and it's giving me some issues that I can't seem to really place. It functions well in most settings, ARC mostly works, it has no issues driving my speakers in any of the digital input modes, but I'm having issues running analog inputs in direct or pure direct mode. For some reason in this mode there's distortion for every volume increment I give it, but once the volume is stable it has no issues. Muting creates a loud pop, switching to another source also causes a pop and so does turning off the amp in that mode. Again, no issue in the digital modes....
      12-12-2024, 06:15 AM
