Fender Rumble 75 amp repair, pops and cracks noise, intermitently
  • Chungalin
    • Jul 2014
    • 422
    • Spain
    This bass guitar amplifier had a subtle background rumbling noise, and intermitently it started making pops and machinegun-like cracks. This noise was independent of volume setting, so it seemed power stage problem.
    Schematics are kindly and openly available at manufacturer's website. That's a load off...
    But power amps TDA7294 were OK (it has 2, bridged). I tried swapping sub-PCBs contaning TDA's but changed nothing at all. So at this point I need scope. It shows the rumbling noise in U2, third output (quad OPAMP TL074CN JFET input), but it's present even before, at U7 and U8 (same type quad OPAMPs). I notice that third output of U7 is the most crazy one (linked to Punch control). When pressing Punch switch things get worse, so I decide to swap U7 with a NJM2902N and all fine!
  • CapLeaker
    Fender Acoustasonic 100 / 150 repair
    by CapLeaker
    Got this Fender Acoustasonic 100 in for repair.
    Complaint: Supposedly does strange things, the instrument channel goes pop, crackle, no audio then all of the sudden works again?
    Well... Open this 15 year old sucker up and I am greeted with leaking capacitors. I changed these out, cleaned the board and no audio out of the instrument channel, but some weirdness is gone and sounds now clean on the second channel. So I put my laptop on there and cranked the music full tilt. Sure enough, it goes crackle and pop with the bass in rhythm. Put my signal geni on it and sure...
    07-26-2025, 02:06 PM
  • ex250
    Kenwood SW-505D no sound issue and pops from time to time when it works
    by ex250
    Hello mates,
    I bought this subwoofer a few days ago used and blind and it works erratically, as far as I could see, it has been tampered with, the speaker is not the original one and of 8 Ohm when it should be of 4, and there are some welds like reworked by the boards.
    It doesn't have much power (expected more from it) and it distorts if you increase the volume over the middle, maybe it's because of the high impedance of the speaker. The problem is that it has sound when it wants, the led panels all work correctly, you can hear the power relay on power on, but right now...
    12-29-2024, 03:27 PM
  • t4796
    Fender Mustang non valve guitar amp - owner connected 110v amp to 220v.
    by t4796
    I recently picked up this amp as not working. I took it as is. Didn't notice until I got home it had foreign power plug and was marked 110v and our local voltage is 220v so then I knew what had happened to it.
    Opened it up and was able to find the schematic online. In the schematic I have uploaded I have erased the parts for 220v operation to make it easier for me to visualise however I have since added the two additional diodes and remove the wire link from the power supply so I can test it easier on 220v
    From the FAQ I learnt that for 110v the power...
    10-25-2024, 06:59 PM
  • mecha1166
    Anyone here fix a tv and customer cracks panel when they get it home?
    by mecha1166
    About 2 times a year, a customer will do this. We fix the tv, put it on test play, and customer sees it working. They see me pull power and video wire. Sometimes I pick up tv, right in front of them, and carry it out to their vehicle while they are next to me. I set it in their tv gently, and tell them the tv is very fragile, be careful with it. I let them close the door/trunk. That day, or a few days later, they tell me there is a crack inside the tv. Normally I tell them transportation is their responsibility and normally that is the end of it. Has anyone had a customer that was not buying this...
    03-29-2024, 11:27 AM
  • daigs
    Fender Blues Junior IV guitar amp not working
    by daigs
    I need to repair the guitar amp in the title. I'm new on tubes, it's the first time for me. Usually I repair keyboards.
    After a time from 10 to 25 seconds about from power-on, the amp start randomly with one of the following issue:
    -some intermittent little pop/cracking sounds on the speaker followed by a “uuuuuhmmmmm” continue sound
    -a continue big big distorsion sound, like a big noise (with the volume and master to zero, see the video)
    Yesterday I powered on the amp and all went well without crack sounds and with no audio distorsion for about 30 minutes....
    05-16-2023, 10:05 AM
