Sony STR-DH100. Puffing smoke and flashing protected.
  • tucocaps
    • Apr 2013
    • 331
    • United Stated
    Picked up this broken unit a long time ago, and thought I would take a stab at fixing. When I got it, it was clicking on and then off with no display. The main power fuse was blown. 6.3A 125 V. I replaced with a 7 amp, 250V fuse, and plugged in. Shortly after I saw some smoke, and looked at the front panel, and it was flashing "protected" or something like that.
    Unplugged right away, and fuse didn't blow. After pulling out the main board, I notice there is a strange layer of residue under it. I thought it had come from the transformer, but it appeared clean. Don't see any other obvious damage on the main, but I think there may be some near the fuse area after seeing that smoke.
    Thanks for any ideas!
  • tibimakai
    • Jan 2012
    • 3680
    Re: Sony STR-DH100. Puffing smoke and flashing protected.
    Probably somebody spilled something on it.
    Clean the board very well first.
    • fzabkar
      • Mar 2009
      • 772
      Service manual:
      • stav242
        Sony KD-55X8509C white flashing/pulsing LED
        by stav242
        I was asked to look at a Sony KD-55X8509C as it was not powering on, no lights.
        On inspection, there was no physical issues.
        I seated all cables and repowered the TV, then the LED light flashed Green / Amber.
        - this seems to indicate repairing required, done by Firmware update.
        so downloaded the latest Firmware from Sony website and wrote to 4Gb USB drive.
        Inserted the drive and repowered the TV.
        LED changed to white flashing/pulsing ... and it sat there for over an hour.
        i was unsure what was happening so repowered the TV and now it just...
        01-08-2024, 07:39 AM
      • Richi777
        Sony KD-49x8505b flashing Red Led
        by Richi777
        Hello guys , i have one Sony kd-49x8505b with flashing Red Led anyone know common faults or this problem
        Thanks in advance...
        12-10-2024, 06:57 AM
      • STKR123
        Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
        by STKR123
        As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
        I wonder if re-flashing the BIOS might be of any use here.
        As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
        There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
        11-03-2024, 06:58 AM
      • rabbituk
        Sony HCD BX7700dbi CMT flashing standby
        by rabbituk
        I have got a Sony HCD-BX7700dbi that isn't worth a lot but I'm keen to learn how to repair and would appreciate some help with my train of thought. The protection circuit is kicking in and the standby light is blinking. It goes into protection mode within a second of powering it on.
        So far the relay on the power board that enables the main transformer clicks on and then off when powering on the unit. Looking at the schematics, the permanently enabled power rail called 'unreg sub' provides about 13.5VDC. Where the power comes into the main board on connector CN303, there is a diode...
        02-11-2025, 05:05 PM
      • Carlos#2003%
        Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
        by Carlos#2003%
        Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
        02-15-2024, 07:52 PM
