Sony RDH-GTK33iP no display, no panel buttons work except for power
  • WHaThEFLuX
    • Feb 2015
    • 277
    Since my last boombox repair was successful I figured I'd try another! I have a Sony home audio mini system that I got off ebay for $1. The power button was sunken in so that it wasn't making contact, after fiddling with it I got it to turn on to what seemed to be the AM/FM function. I can hear static coming from the speakers, but the volume adjustment does nothing to change it and there's nothing on the display. I assume it's the AM/FM function because when I play with the antenna pins in the back the static sound gets louder and changes.
    I haven't attempted any repair yet since this unit has a much more extensive tear down than the last one, so I figured I'd post up on here and see if anyone has a place for me to start!
    As a side note, all LED functions seems to work and there's also power to the Ipod and USB connections.
    I've included the service manual , if anyone would be willing to take a look it'd be greatly appreciated!
    "You can only learn so much doing simple recapping and fixes. Ideally you want a really hard one to fix where you end up with a lot of dead ends and frustration. Then, and only then, do you learn how things really work."
    -retiredcaps
  • WHaThEFLuX
    • Feb 2015
    • 277
    Re: Sony RDH-GTK33iP no display, no panel buttons work except for power
    Well I found the problem:
    -retiredcaps
    • Longbow
      • Jun 2011
      • 623
      Nice to have the complete manual, but its a bit early in the process. Everything depends upon following a method. Now's the time to make good habits. Start with what you know, which is quite a lot actually. The power button was pushed in and nothing on the front panel is working. That suggests to me that someone bashed the front of the unit and may have cracked the pc board that holds the power button and other front panel devices. Start there, looking for damage to the front pcb or parts on the pcb. If the power button now works and the unit wakes up, your main control micro is working - good sign. Another good sign is hiss in the speakers that indicates that the audio output stage is probably working. Grab your tools and tear it down. You will get your $1.00 worth!
      Oops, looks like you already did what I thought. Super glue will repair the broken board, then you have some fun with #30 wire-wrap jumpers to fix the broken traces. Don't try to repair them using solder bridges.
      Is it plugged in?
      • WHaThEFLuX
        • Feb 2015
        • 277
        So after discovering that it's impossible to find a replacement board, I decided to try my first ever cracked board repair.
        It was by far the most intricate soldering work I've ever done, and after many hours of staring through a jeweler's loupe until my eyes were strained, I ended up with this.
        This is currently my finest soldering achievement and perhaps the sloppiest job in rework history, but I'll take function over form any day!
        Even after the last trace was patched, I was certain I had wasted an entire evening attempting something I thought couldn't be done with my skill set/equipment (or lack thereof), but when this thing lit up and was fully functional I was like a little kid on Christmas morning!
        I have absolutely no expectations of longevity out of this repair, but the experience gained was well worth the $1 and sore eyes!
        -retiredcaps
        • WHaThEFLuX
          • Feb 2015
          • 277
          Longbow, I probably should've waited for someone to respond on here before attempting the repair!
          I wasn't even aware that wire jumpers existed(shows my experience level), that probably would've saved me a ton of frustration and eye strain.
          If anyone wants a good laugh, the trace bridges are single strands of speaker wire that I sanded and tinned one by one!
          -retiredcaps
          • rhomanski
            nowhere man
            • 5157
            • U S of A
            I keep a spool of solid wire for old stereos. A lot of time you'll find the boards turning dark, they tried to run too much current through the copper traces. I parallel the runs with wire. Pioneer in the late 70's would run two lines of solder down the sides of some runs. That solved the problem. The early ones though, they'll turn black and brittle if you don't do something.
            sigpicThe Sky Is Falling
            • Longbow
              • Jun 2011
              • 623
              Thanks for your photos. That's how its done - good work. Many techs will try to solder bridge each connection to avoid using jumpers, but it is never reliable. Also keep in mind that you do not have to jumper the cracked trace right at the point of breakage. It may be much easier to leave the break alone and connect the jumpers further back from the area of the crack, rather than fighting with the glue. My reference to wire wrap - #30 wire wrap is a convenient size for this type of work because it is insulated, flexible and the circuit does not require high current traces.
              Is it plugged in?
              • r3vsEngIT
                Sony Panel Swap Experiment 65x900h with the panel from a 65x930d
                by r3vsEngIT
                65x900h with the panel from a 65x930d.
                900H: model yr 2020, Samsung panel
                930D: model yr 2016, Innolux panel
                spec wise the panels are the same. the drivers and tcons are obviously different but what made me want to give this a try is that the wiring diagrams for the data signals going into the tcon for each tv were nearly identical. there are only a couple pins that i am unsure about and that is what brings me here.
                the 930d has the DPS board where the 900h has none, however, if you follow the pins to the BM1 it would appear that the signals...
                07-11-2023, 11:11 AM
              • guidodroid
                Bad Panel in Sony Bravia X850G
                by guidodroid
                Hello all,
                I'm trying to understand what is the issue with my 26 months old Sony Bravia KD-65XG8505 (XBR65X850G).
                It is just few months out of warranty, so Sony doesn't want to do anything, and the local replacement shop also tells me that it's not worth repairing (alhtough this model costed almost 1000 euros just 2 years ago...).
                Few nights ago the TV started showing some horizontal lines and distorted colors/geometries in the bottom part of the screen (see attached photos).
                The issue is not as bad as others that I've seen around, but is indeed noticeable...
                03-19-2022, 12:08 PM
              • EazyBone
                Un70TU7000b Backlights work, no picture, has sound, panel shorted caps
                by EazyBone
                Picked up this Samsung above thinking it'd be backlights but it isn't. Now MAYBE I'll get lucky.
                Found some shorted caps among the panel boards. Each cap along the line is shorted. On every board (3 panel driver boards)I disconnect each side right and left ribbons and they are no longer shorted caps and have about 1.5Mohm resistance (on left and right boards). The middle board has the main board disconnected and the caps are shorted. Last 4 pics show arrow to caps.
                Now what exactly do I need to do in order to attempt to fix this issue?
                do I have to take each one...
                12-24-2023, 06:59 PM
              • PlanB
                Sony KDL-55W828B Hotspot in LCD panel
                by PlanB
                Hello everybody,
                I need your expertise if my asumption about the failure of this TV is correct.
                A Sony KDL-55W828B only shows vertical red stripes that vanish to the top when switched on.
                When only the right side of the LCD is plugged into the T-CON board the right side shows a good image, while the left side is white.
                When only the left side of the LCD is plugged into the T-CON board the LCD shows a complete white image.
                I checked some signals on the T-CON board but was not able to find something strange. Then I checked the the caps...
                02-05-2022, 09:46 AM
              • swrb898
                Sony KD-70X690E Bravia; Bad TCON? Bad panel?
                by swrb898
                What's wrong with my TV: the TCON, the panel, or something else? I'm stuck.
                Problem:
                Last week, my Sony KD-70X690E 70" stopped displaying a picture. The TV powers on, and the back lights power on. However, the TV doesn't seem to boot up. I say this because the SONY splash-screen logo does not display, nor does any picture display, nor can I invoke a menu by pressing "Menu" on the remote. Other than back-light bleed, the screen is black.
                My troubleshooting got me this far:
                With the left-hand TCON to bottom-board ribbon cable...
                12-28-2021, 08:12 PM
