Rotel RA-940BX distorted sound
  • holmzy
    • Nov 2009
    • 99
    Hi guys I failed miserably on a teac amp recently and decided to try this rotel out.
    The problem is the sound on both channels is distorted. you have to turn it up max and all you hear is crackles on speakers and via headphones sounds half decent but at high volumes struggles and starts distorting.
    I have service manual and its really confusing. The voltage seems right for one side but the main voltage is wrong but everything checks out ok?!?!
    The part is also not the same on sm is 802 bridge diode. but its actually an PBPC803 installed but it checks out ok. everything there seems to check out diodes, resistors, caps. sm manual states 41v but im getting 36v. on the other end it states 17v and i am getting 17v
    • 31046
    Re: Rotel RA-940BX distorted sound
    that description sounds like a chip is bad.
    • holmzy
      • Nov 2009
      • 99
      op amp chips? I have tested them. the voltage coming out of them are fine and sound also is fine.
        • 31046
        got a schematic? - other than on that xp desktop i mean!
        • holmzy
          • Nov 2009
          • 99
          lol yes
          • holmzy
            • Nov 2009
            • 99
            As you can see right have very little dc off set with the bias turned all the the way down and left has a little more. I think the setting is millivolts. so right is 0.004 v and left is .040 v
            The one things I did notice was when headphones connect dc off set set at highest rating I could hear half decent sound. When dc off set was set lowest like now I could only hear distortion via headphones. Alo I get 0 volts across the test terminal for bias adjust, adove dc adjust. dc off set adjust is closest to big yellow cap.
            • R_J
              • 9549
              You did check f601 and f602? they are both good correct?
              • holmzy
                • Nov 2009
                • 99
                Hi yes I changed fuses twice. once with 6a then with 4a. no difference!
                  • 31046
                  about the 17v and 41v - did you check both + and - lines wih the meter grounded to the frame?
                  • holmzy
                    • Nov 2009
                    • 99
                    yup. gives me 36v. according to sm should be 41. the main bridge diode gives me 36v. should be 41v bridge diode gives me >560 reading on diode setting and does not appear to be faulty.
                    • holmzy
                      • Nov 2009
                      • 99
                      the 17v line gives me 17v just fine
                        • 31046
                        +17 and -17?
                        • holmzy
                          • Nov 2009
                          • 99
                          Q903/4 have 36v going in and 17 and 17.5 as per sm manual. its suppose to be 41v but everything else checks out.
                          I just measure the transformer and it said 27.1v! the markings on the unit itself say 28.3v. so it was never going to be 31.7v input ac!?!?
                            • 31046
                            what country are you in? what's your mains voltage - both official and metered?
                            • holmzy
                              • Nov 2009
                              • 99
                              You may be on to something here. Im in UK. the back states for 240v. but inside is set on 220V. The ac input measured is indeed 240v
                              • holmzy
                                • Nov 2009
                                • 99
                                I have just seen that ac4 is actuay connected directly to ac3. so should be already set on 240v right?
                                  • 31046
                                  well mainland Europe was 220v, and the u.k. was 240v
                                  they were supposed to settle on 230v but there is no timeline for this.
                                  what does your meter find on your sockets?
                                  mine is 235v right now. (just checked)
                                    • 31046
                                    btw, if the unit was wired for 220v your secondary voltages would be high - not low.
                                    • holmzy
                                      • Nov 2009
                                      • 99
                                      inside the unit itself where the mains wire goes in measure 240 exactly. could it be the bridge rectifier? its a PBPC803 on the sm manual its suppose to be KBPC802. could that be limiting the voltage? I really dont understand what could be causing the power loss!
                                        • 31046
                                        it's the transformer - maybe the manual is wrong.
                                        unless it's not being smoothed much because the main caps are worn.
                                        where your getting 36v, set your meter to AC and check again - it should only show the ripple.
                                        the rectifier is not the problem - the difference is just the maximum voltage 300v vs 200v
                                        • LEECH666
                                          Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                          by LEECH666
                                          Good day ladies and gentleman!
                                          I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                          This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                          I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                          01-19-2024, 05:46 PM
                                        • maleksa
                                          Yamaha MOX8 boot freeze and distorted sound
                                          by maleksa
                                          My Yamaha MOX8 synthesizer recently developed two issues.
                                          Firstly, after booting up, it operates as normal. However, after about 5 minutes, the sound starts to get distorted (broken up screeching sound) almost like putting it through a guitar distortion pedal. After a while, the distorted sounds will go away for a while and comes back. At times, the synthesizer will also freeze I need to power off and on again.
                                          Secondly, when powering off and on again, there will be times where the synthesizer will freeze during the boot sequence (freezes at the MOX8 Opening Screen),...
                                          11-07-2024, 03:28 AM
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
                                        • televizora
                                          HP 8470p - distorted sound and noise when playing audio
                                          by televizora
                                          Hello.
                                          I have an issue with HP 8470p - rather strange one.
                                          I have a noise and sound distortions on both internal speakers and external speakers, when I plug such into the 3.5mm audio jack.
                                          Seems like the noise is present especially when I play audio, where there are parts/sections where the volume of the actual recorded sound is low.
                                          Interestingly, when I play the windows sound test, everything seems to be almost okay. The sound/distortions are similar to when you have interference from some other piece of equipment nearby or when you have an audio receiver with bad amplifier...
                                          12-31-2021, 10:25 AM
                                        • Christos Tsiligiannis
                                          Marian Trace Alpha sound card repair help
                                          by Christos Tsiligiannis
                                          Hello to the forum.
                                          My name is Christos, I am new to the forum here and i am posting from Greece.
                                          So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                                          To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                                          So i tried asking for a schematic from the company and they would not give me one. Instead they...
                                          11-18-2024, 05:26 AM
