creative inspire t6100 losing loudness
  • ChaosLegionnaire
    HC Overclocker
    • Jul 2012
    • 3264
    • Singapore
    firstly, i want to state that this is NOT a problem with the volume fluctuating up and down as is the commonly reported problem/complaint with this speaker model. that problem has been fixed on my set. its the speakers (all of the 5 satellites) no longer sounding as loud as before and i have to crank up the volume to max to get sounds to be audible.
    i have opened up the front right control speaker and checked the variable resistor volume knob with a multimeter. the resistance changes normally.
    tested the speakers on another pc and its still not loud as before. also tested the speakers on my mp3 player with the mp3 player's volume at max but still not as loud as before. plugged in my earphones and got my ears blasted by music. so i've ruled out any fault with the motherboard's sound card or mp3 player audio jack.
    all of the three audio jack input male connectors on the speaker system are shiny and not tarnished.
    the external power brick for the unit is 230V ~ 50Hz 550mA for the input and 13.5V ~ 5000mA for the output. do note that this unit uses ac for the output as evidenced by the ~ symbol for the output rating. so the power brick is more like a step down transformer rather than an ac-dc adapter as is common with most other speaker power adapters. i pulled out the power plug from the amp/subwoofer and measured the output voltage when not connected to the amp/subwoofer using a multimeter. the reading was 15.2V AC. hmm, bad power brick going out of spec?
    i've also tried to measure the resistance/impedence of the satellite speakers using a multimeter. the satellite speakers all measure 5.5 Ohms except for the center which measured 8.5 Ohms.
    i also tried to measure the resistance/impedence of the whole unit via the power input jack like in the logitech z506 thread but i was unable to get a reading via the power input jack even though i was making good contact with the terminals. the multimeter kept saying the resistance/impedence was infinite regardless of the max resistance measurement setting of the multimeter. might have something to do with the fact that the unit requires ac input as opposed to dc input on the other speaker system? or am i measuring it at the wrong place? should i be measuring it at the audio jack instead?
    so what can i do to fix this speaker system? bad power brick? or are the caps in the subwoofer/amp failing? i would hate to have to buy new speakers as the local retailers here have got a crappy selection of surround sound pc speaker systems. the only one they carry in abundant quantities is the logitech z506 which is utter crappily designed power supply wise.
    thanks for reading my grandfather's speaker's story.
    • 30997
    Re: creative inspire t6100 losing loudness
    foto's of the board please.
    • ChaosLegionnaire
      HC Overclocker
      • Jul 2012
      • 3264
      • Singapore
      cant. i dont even know how to open up the power brick or the subwoofer. much less have a camera to snap pictures lol
      • ChaosLegionnaire
        by ChaosLegionnaire
        09-13-2022, 09:02 AM
      • Xenon-Codex
        Volume potentiometer loudness tap bypass?
        by Xenon-Codex
        I salvaged a Sony TA-F170 with broken volume potentiometer. It has a special pot with a loudness tap in the middle, of course not available anymore.
        Is the loudness somehow possible to get to work, at least constant instead of variable? I have a regular potentiometer which works, but the loudness does not.​
        01-16-2024, 01:53 PM
      • Psionic
        Creative Gigaworks ProGamer G500 troubleshooting
        by Psionic
        Hi
        I have system Creative Gigaworks ProGamer G500 (production 2006 year). Last two months sound began to disappear, triger: use remote but wired volume controller. Sometimes sound system return back to correct mode but after changing volume problems return again. All LED indication concontroller corrects work - but sound absent.
        Syndrome : if power off and connect headhones to wired controller - sound in phones play (looks like capicitors discharging) short time.
        In google similar problems absent : present solution for unexpected cutting off or damaged amplifier chip....
        07-02-2024, 04:19 PM
      • Dukenukemx
        Creative SB1350 identify component
        by Dukenukemx
        Front headphone connection stopped working on this soundcard of mine and I started checking for shorts and found some that go to this thing. I tried to Google it but nothing. Anyone know what this component is?
        01-13-2024, 08:43 AM
      • SkullKill
        Creative GigaWorks T3 2.1-Channel Speakers
        by SkullKill
        The Creative GigaWorks T3 2.1-Channel Speakers keeps turning on and off in a loop.
        open it up, and there was a swollen Decon SAII 2200uF 25V 85°C Capacitor in it. (the one on top right, next to the diodes)
        replaced it with a 2200uF 50V 105°C Cap (just because this is what i had on hand, and there was space for it) , and it is back up and running. ...
        03-05-2022, 06:01 AM
