Sony RDH-GTK1i/HCD-GTK1i boombox iPod dock volume barely audible
  • WHaThEFLuX
    • Feb 2015
    • 277
    Hello All, I acquired a Sony home audio docking system from a friend who no longer wanted it. He explained to me that while he was using it with his ipod connected all of a sudden the volume became muted. Upon further inspection I discovered that music was playing, but the volume was so low it can barely be heard. The volume control does have an affect on the volume level, it goes from inaudible at any setting to barely audible at max.
    Every other function concerning iPod control works perfectly, and any other input plays music at the correct level.
    My first instinct was to pull the iPod board and check for anything suspicious, but I couldn't find one bad joint or broken pin.
    The easiest thing to do would be for me to spend $60 on a replacement board, but I'm worried that it might not resolve the issue.
    So badcaps vets to the rescue! Input? Thoughts? Suggestions?
    I've included a picture of the iPod board along with the service manual for the system....tell me what you think, any advice would be greatly appreciated!
    "You can only learn so much doing simple recapping and fixes. Ideally you want a really hard one to fix where you end up with a lot of dead ends and frustration. Then, and only then, do you learn how things really work."
    -retiredcaps
    • 31002
    Re: Sony RDH-GTK1i/HCD-GTK1i boombox iPod dock volume barely audible
    does it work o..k. with the tuner or phono inputs?
    • WHaThEFLuX
      • Feb 2015
      • 277
      Tuner and aux/phono work perfectly.....I've gone over the schematics with a fine tooth comb and I just can't seem to figure out what could be causing the volume loss. I'm almost certain it's the board but the usb port is also attached to the same board and it works fine as well.
      -retiredcaps
        • 31002
        try injecting audio into pins 27/28 of the ipod connector.
        it's using analog.
        that will tell if it's the audio stuff, or the digital control of the ipod.
        • WHaThEFLuX
          • Feb 2015
          • 277
          That's a great idea, I'll definitely try that.......any specific method of doing it?
          -retiredcaps
            • 31002
            well i would try to solder a few thin wires to the back of the connector the ipod fits into - that will also test any interconnects.
            • WHaThEFLuX
              • Feb 2015
              • 277
              so solder the L & R wires of a RCA to headphone jack cable to pins 27 and 28?
              Or just plain old speaker wire?
              -retiredcaps
              • WHaThEFLuX
                • Feb 2015
                • 277
                Also, will I have to jump the ipod-detect pin so the unit thinks the ipod is connected?
                -retiredcaps
                • WHaThEFLuX
                  • Feb 2015
                  • 277
                  Ok here's an update:
                  I connected an iPod to the dock on the board so the system would power up the speakers, and used an RCA to headphone jack cable connected to a playing iPod to inject audio into pins 27/28.
                  The result? The same barely audible music that was made when using the iPod dock normally.
                  I believe this would indicate that the board is bad and should be replaced, but I'm not 100% convinced. Is it possible that something is faulty on the pathway from the iPod dock connector to the amp?
                  -retiredcaps
                    • 31002
                    look at the schematic, there is a chip that switches between the inputs.
                    • WHaThEFLuX
                      • Feb 2015
                      • 277
                      Are you suggesting that the input selector chip (IC201) is faulty? I also see a few line muting transistors, could they be coming into play here as well?
                      -retiredcaps
                        • 31002
                        i'll have to go back and look at the schems again.
                        • WHaThEFLuX
                          • Feb 2015
                          • 277
                          Thanks, I really appreciate it! I know I can test the line mute transistors for resistance but I'm not too sure about the IC.
                          -retiredcaps
                          • WHaThEFLuX
                            • Feb 2015
                            • 277
                            So it seems the line mute transistors are good, anyone know of a reliable way to test a SMD IC?
                            -retiredcaps
                              • 31002
                              link the input pins for the line and ipod on the selector chip,
                              then see if playing sound into the line while the ipod is selected reaches the amplifier.
                              • WHaThEFLuX
                                • Feb 2015
                                • 277
                                I know the ipod pins are 6 and 8 on the selector chip, not sure about the line pins?
                                By line do you mean aux? Like the jump the aux/ipod pins on the selector, then play sound into the aux lines with ipod selected?
                                -retiredcaps
                                  • 31002
                                  yes, exactly - so sound we already know works right though the system is injected into the ipod input of the selector.
                                  if it still dose not output loud sound then i am 95% sure it's that chip.
                                  • WHaThEFLuX
                                    • Feb 2015
                                    • 277
                                    After linking the aux and ipod pins on the input selector chip, I still get barely audible sound when ipod is selected with music being played through the aux ports.
                                    I believe we've narrowed it down to IC201 so I'll order one and see if that does the trick!
                                    -retiredcaps
                                      • 31002
                                      is it locatable?
                                      my experience with sony stuff is they like to use unusual or rare part numbers!
                                      • WHaThEFLuX
                                        • Feb 2015
                                        • 277
                                        If it exists, I can find it. I discovered on the sony site that they use a company called Encompass as a parts distributor(http://www.encompassparts.com), typed the part # into the search field and it popped right up, if it works it'd be a real nice $7 fix!
                                        -retiredcaps
                                        • karthur
                                          Vizio D65x-G4 Volume changes on its own
                                          by karthur
                                          On this Vizio D65x, the volume will change on its own. I don't mean like during commercials where the volume will increase. I mean its like the (+) volume button on the remote is pressed and the actual volume dialog is displayed on the screen going up. It will do this, then the volume may start going down. It might go all the way to "0"or it might stop at a different number, then start going back up. The whole time its doing this, the volume dialog is shown on the screen.
                                          It wont do it until it has been "ON" for 20 or 30 minutes, so it does seem to be heat related....
                                          06-05-2025, 08:13 AM
                                        • crackedprint
                                          Sony HCD-HX80R Amplifier Volume Control Problem
                                          by crackedprint
                                          I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
                                          I have tried a Cold Reset as per the service manual.
                                          I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
                                          I have looked all the way through the service manual and tried many online...
                                          01-21-2025, 12:18 PM
                                        • BigOof
                                          Marantz SR5007 popping on volume change and mute in Direct Mode
                                          by BigOof
                                          I bought a used Marantz SR5007 and it's giving me some issues that I can't seem to really place. It functions well in most settings, ARC mostly works, it has no issues driving my speakers in any of the digital input modes, but I'm having issues running analog inputs in direct or pure direct mode. For some reason in this mode there's distortion for every volume increment I give it, but once the volume is stable it has no issues. Muting creates a loud pop, switching to another source also causes a pop and so does turning off the amp in that mode. Again, no issue in the digital modes....
                                          12-12-2024, 06:15 AM
                                        • Storyteller12
                                          Samsung Soundbar Q900T Cuts Off if Volume above 30
                                          by Storyteller12
                                          I have this soundbar and when I turn it on it works until I turn the volume above 30.
                                          Then the display show “PROT” protection and shuts off.
                                          I can turn it right back on and it works until volume hits 30 again.
                                          There is a little static on the surround speakers so I unplugged them but still have same problem. I tried unplugging all speakers also and when volume goes above 30 it shuts off.
                                          I can turn the volume above 30 if nothing is playing but as soon as I play something it shuts off.
                                          It will play fine for hours with volume...
                                          03-21-2023, 12:31 PM
                                        • Norrecito
                                          iPod nano G3 - alternative soldering point for the white battery wire
                                          by Norrecito
                                          A friend of mine gave me an iPod nano G3 to see if I can fix it for him.
                                          The device had a faulty battery and he tried to replace it but failed. In the process he managed to pull off the pads that corresponds to the white battery wire (marked with a red circle in the images)....from both sides of the PCB. Fortunetely he didn't damage anything else.
                                          This is usually an easy fix HOWEVER, on the PCB, I see no traces coming from the VIA and after searching the internet, I've found no schematics nor boardview for this device. With the pads gone from both sides I seem...
                                          09-07-2024, 03:54 AM
