yamaha cr-640 vs soundesign 5466
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    today i got a lot of two receivers, a yamaha cr-640, and a soundesign 5466, for $15, which one is better? the soundesign feels lighter and cheaper despite it having an 8-track in it and no vents, and the yamaha feels like it will break your foot if you drop it despite having vents and no 8-track. which one should i keep? is the weight a good sign that the yamaha is better? i haven't had a chance to go get some speakers to hear for myself.
    Follow the white rabbit.
    Re: yamaha cr-640 vs soundesign 5466
    YAMAHA.
    The soundesign with 8-TRACK? They are junk form the 70's, fixed many of these junk. Look to see if it has the output rating with the word like instant peak to peak output over 100W. They made a lot of compact units with 8-TRACK and with BSR turn table on top with big output rating claim.
    YAMAHA: good unit. You can get free owner and service manuals.
    http://www.hifiengine.com/manual_lib...a/cr-640.shtml
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      oh, yeah, thanks for reminding me, the yamaha has the owners manual and all the light work too.
      • sanalelevenstar
        Yamaha RX-V485 Wn9711 Update
        by sanalelevenstar
        Help Needed: Yamaha RX-V485 Network Issue After Firmware Update (WN9711 Error)
        I'm facing an issue with my Yamaha RX-V485 receiver. During a firmware update, the process failed, and now the USB, Bluetooth, and network functionalities are not working. Occasionally, the receiver displays the error code WN9711.
        I came across Yamaha Technical Bulletin No. 0103, which describes a similar issue for models like the RX-V4A, RX-V6A, and RX-A2A. According to the bulletin, the issue can be resolved by shorting soldering points (e.g., J260 for RX-V4A or...
        12-04-2024, 04:32 AM
      • fitz301
        Looking for a seemingly obscure schematic written on unobtainium parchment... Soundesign 5595
        by fitz301
        I'm really hoping somebody on this forum, who have way more expertise than I, can help me with something.
        I am searching for the schematic to hopefully repair my 83 yr old mother's console stereo system, it's a 1979 Soundesign 5595 w/ turntable, AM/FM stereo receiver, cassette and 8-track tape, everything works but there's a loud bass hum when using the cassette player and the FM radio needs to be turned up to full volume to hear it, every other part seems to work like it should with the exception of burnt out dial lights and needing new belts.
        I've been...
        10-19-2025, 06:16 PM
      • sanalelevenstar
        Yamaha RX-V485 receiver. After encountering a "version error"
        by sanalelevenstar
        I'm having trouble with my Yamaha RX-V485 receiver. After encountering a "version error", the USB, Bluetooth, and network functions have stopped working, making it impossible to perform a firmware update through normal methods.
        After doing some research on forums, I found that earlier Yamaha models with similar issues (like the internal error message) could be fixed by shorting or soldering specific pads—such as R896—and then powering on the unit to enter a service/boot mode that displays the model info and allows recovery.
        I managed to find the service...
        09-10-2025, 01:54 AM
      • jjne
        Yamaha RX V675 sound issues
        by jjne
        I have an old Yamaha RX V675 receiver which is starting to develop issues with the sound, although it doesn't quite match up with what folk normally report with these.
        From cold, the sound cuts in and out. When this happens the amp is losing sync with the optical input (speaker graphic disappears from the front panel). But this is not resolved by putting the unit into pure direct mode. After a couple of minutes this resolves, although there are occasional clicks from the speakers after that.
        At first I thought it was either a speaker relay or the DSP, but I don't think...
        06-24-2025, 07:01 AM
      • AlexVG
        YAMAHA CLP-550 without of sound
        by AlexVG
        Hi.
        I have an old YAMAHA CLP-550 without sound. (Some times I can get some kind of noise or distorted sound)
        I have replaced all green marked elements, but it gave me nothing.
        The IC12 chip LC9116A-105 (red marked) remains under suspicion yet.
        But it is custom YAMAHA's chip, and I can't find any information about it.
        Maybe somebody came across with the same issue?
        Any information will be very useful. I will be very appreciated.
        Thank you....
        06-08-2025, 09:29 AM
