Onkyo-593 No power and now clicking sound
  • Sisko
    • Apr 2020
    • 10
    Hi all!!
    Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify this resistor and on the board it is marked with this symbol; "W" yep a w just as if it was a fuse but it's not that soldered par has an R. Ok just looked it up on the microscope and I can't see any writings at all BUT I do see 3 bands one is thin and the other two are bigger and since its burnt the bands are black as you can see in the photo. So now what? any help with this would be very appreciated!!
    UPDATE!!
    Ok Replaced a few parts but now getting a "clicking sound" when powered on and yes I am plugged with a dim bulb thing. For now I know it's in "protection mode" did lift pin 12 VCC on the IRS2092 and two big caps (and other parts in the red section) and I get 0V BUT when it's clicking I get very faint voltage readings. So right now I have no idea where to look for. I did ESR on the 4 big caps and all checks out ok and did voltage test on the longest 2 caps but not getting voltage because of the clicking sound. Before changing the parts (3 parts pic) that weren't good it wasn't clicking at all but after it started to click. I'm trying to learn to fix electronics as much as I can but this one is a bit hard to find the problem but I'm asking you PLEASE no jokes or stupid answers. I have provided schem, parts changed and a pic of the section that is causing the problem. Any help would be very welcomed.
  • madan1
    • Nov 2016
    • 713
    • Bulgaria
    Clicking usually means that the smps can't boot.
    Show on the schematics where is the "W" part.
    • Sisko
      • Apr 2020
      • 10
      Ok but what do I do from there?? and what is SMPS and where is it on the schem?
      Thanks!! ;-)
      • madan1
        • Nov 2016
        • 713
        • Bulgaria
        SMPS = switching mode power supply, lot's of info out there if you are interested.
        As I asked above - where was the burnt component in the schematics? If you can not locate it there, just post some good photos of the board (both sides) and point there the blown component(s).
        Otherwise start with the standard things - check the mosfets q951 q952 for short in diode mode.
        Check c954 c955 c963 c905 c902 c901 c912 c911 for short.
        • Sisko
          • Apr 2020
          • 10
          Ok here's the pics!! The big caps in pink have been checked with an ESR and they are good. The parts that I have changed are in blue. Hope this helps and THANKS for your help here!!!
          Sisko
          • madan1
            • Nov 2016
            • 713
            • Bulgaria
            All those blue components are on the secondary side. Were they blown?
            See above which components to check for short. Also check q901 c907. Check c963 out of the board for capacitance and esr.
            Remove the white goo.
            • Sisko
              • Apr 2020
              • 10
              Hi there
              Ok changed the 2 caps (c963, c907) they were bad and the q901 I have already changed, checked q951 and q952 all ok.
              Yes the 3 parts were blown (first message have pics with the 3 parts that weren't good, the q901 is there).
              That white goo is hard to take off though!! BTW that "W" on the schem is it a waveform if I check it with an oscilloscope?
              THANKS for your help with this!!!! I appreciate it very much!!
              Sisko
              • madan1
                • Nov 2016
                • 713
                • Bulgaria
                " resistor and on the board it is marked with this symbol; "W"" <-- show the W resistor on the photos or the schematics.
                So, if all replaced components were bad, this is no bueno. Most likely you gonna need to replace and IRS2092.
                Confirm that there is no short on c954 c955 c963 c905 c902 c901 c912 c911 + c503 c432 c431 c451
                p.s. if there is no short on that caps, try powering the unit without RFI4212H.
                • Sisko
                  • Apr 2020
                  • 10
                  Hi there, Sorry for not updating this I'm doing this in my spare time now it's a rainy day I had the time to do all the cap test you said and I had to change some
                  so now all are ok. So now you want me to desolder RFI4212H, and by doing so what should I expect to happen? BTW I see test points on the board is there
                  any thing that this could help me?
                  I just wanted to say that this speaker turns on by itself when the sound system is turned on and what happened to have "blown" this bad is that
                  someone had forgotten that the speaker level was at full and she turned up the volume to full on the sound system and he said that he saw
                  smoke coming out (it was a fried resistor R542). Hopes this helps a bit.
                  THANKS!!!!
                  Sisko
                  • madan1
                    • Nov 2016
                    • 713
                    • Bulgaria
                    Originally posted by Sisko
                    ... I had to change some so now all are ok.
                    what do you mean? At the moment we are not looking for bad caps. We are looking for shorted power rails. All listed caps are just easy access points to probe the rails. A capacitor out of specs will not cause such an issue, only a totally shorted cap would (apart from the cap near the smps IC, but given the blown components, it is not the issue)
                    if the power supply boots, this would mean that RFI4212h has died again and/or q501 is also bad.
                    check C542 for short.
                    • Sisko
                      • Apr 2020
                      • 10
                      QUOTE=madan1;n3741454] what do you mean? At the moment we are not looking for bad caps. We are looking for shorted power rails. All listed caps are just easy access points to probe the rails. A capacitor out of specs will not cause such an issue, only a totally shorted cap would (apart from the cap near the smps IC, but given the blown components, it is not the issue)
                      [/QUOTE]
                      Hi there!!
                      Ok for now I have never understood power rails and what to look for in a schem for this, yes I did try to look at YT vids but it's almost all laptop power rails and they have schem that shows where
                      they are, I have the schem for the subwoofer but they don't say where are the power rails. I don't fix electronics every day I do this now and then when I have the time so I can't learn all
                      that much when I don't have time to do this, I do have a normal job but I was always interested in fixing electronics since I was a kid but never got the time to do it often so I haven't learn
                      every thing. I took this sub thinking it could be just a blown fuse but I saw that burnt resistor so I saw it would be more complicated so hey I need to learn this "trouble shooting" for problems like this one.
                      This was something that I wanted to do as a job but at school I needed to be good in math and I wasn't so..... but I always had passion and desire to fix electronics and still have this "drive" for it.
                      So I'm sorry for not understanding you in some ways and I hope you understand me for this.
                      Ok power supply boots?? Ok you mean turns on, right? There isn't any power on light on the board BUT there is one in the front of the speaker that is unplugged.
                      Ok C542 no short. I didn't have time to recheck all the caps if they were shorted that you have mentioned earlier, will do it tomorrow.
                      Again THANKS and sorry if I don't understand what you mean sometimes.
                      Sisko
                      • B0r1s
                        Samsung UE49KS7000SXXH - fast clicking sound in standby mode
                        by B0r1s
                        PSU - BN44-00878A
                        Symptoms:
                        The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
                        A weak clicking sound was coming from the transformer.
                        Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
                        Progress:
                        After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
                        01-17-2023, 04:58 PM
                      • slimmy182
                        [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
                        by slimmy182
                        Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
                        I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
                        Looking on google I found this:...
                        01-14-2023, 11:55 AM
                      • ChaosLegionnaire
                        by ChaosLegionnaire
                        09-13-2022, 09:02 AM
                      • Solvik
                        XFX XPS 650w 3XS PSU making Ticking/clicking sound
                        by Solvik
                        Hello
                        i have a older powersupply from XFX that makes this wierd electronic ticking /clicking noise. Its not the fan thats making the sound. See video below. Is anyone familiar with what component this sound can come from?
                        All voltages are normal....
                        02-13-2025, 02:43 PM
                      • nbnb
                        Vizio VO47L FDHTV30A Picture but no speaker audio, clicking sound
                        by nbnb
                        I have a Vizio VO47L FDHTV30A. The picture works well, but the sound only works through the RCA output jacks. The sound does not work through the internal speakers or the headphone jack. The TV has a rapid clicking sound when the tv is on that occurs about 4 times per second. The clicking sound volume is fairly low and is not affected by adjusting the internal speaker volume level. The clicking occurs whether or not I disable the internal speaker through the Vizio setup menu. The clicking only occurs while the TV is on.
                        Any idea what is causing the clicking sound? Any easy way to...
                        11-23-2019, 12:03 PM
