Numark Party Mix Headphone Issue
  • nams2590
    • Apr 2023
    • 10
    • France
    I recently bought a Numark Party Mix Controller, but I don't have any headphone working.
    I've already replaced the headphone connector and the headphone flex cable, but this is still not working.
    Do you have any idea about what to check or does someone has the schematic?
    Thanks a lot for your help.
    Fabien
  • CapLeaker
    Leaking Member
    • 8264
    Sounds like something is open or dead shorted. Did it quit all of the sudden or loss of volume over time?
    • nams2590
      • Apr 2023
      • 10
      • France
      I don't know because I bought it like that.
      Everything works fine except the headphone.
      I've checked short circuit and open circuit close to the headphone, and from the motherboard.
      The thing is, I don't know from which part it comes.
      I think I'm going to check if the audio signal is present with an oscilloscope.
      • CapLeaker
        Leaking Member
        • 8264
        Oh boy! That’s not nice to trace with. If you do see a, electrolytic capacitor in series with the audio (DC blocker) check the audio going in on one side and the audio going out of the other side too. If the audio isn’t equal, replace that cap.
        A headphone only has 3 wires. A audio left and right and GND. That’s it. You check between GND and the other 2 (left and right audio).
        if you go backwards from the jack, I think it goes like this: jack, lowish ohm resistor, a dc blocker cap and audio amp. Find that dc blocker cap and check the audio there. Whatever the problem is, it affects both channels left and right. It could be the IC is dead for one reason or other. It also could be a couple of transistors switching the audio to GND close to the headphone jack. Maybe call Newmark and ask for a service manual. They seem to be all right giving out a service manual.
        • madan1
          • Nov 2016
          • 691
          • Bulgaria
          It shouldn't be that hard.
          From what I see, there are two analog audio outputs (rca and headphones) so there must be 2 analog audio amps, which should not be hard to find...
          • nams2590
            • Apr 2023
            • 10
            • France
            After a new verification, Left and Right headphone traces goes to U18.
            I've already reflowed U18 chip and all of the parts around it.
            With my oscilloscope, when I touch U19 pins, sometimes headphone works again but just for a few seconds and disapear again.
            I can see that capacitors are not shorted.
            I've found +3,3V, -3,3V and a PWM signal around this chip.
            However, I notice that C78 and C79 remains at 0V.
            => Maybe this is the issue.
            Otherwise, I've desoldered the 2 resistors which are on the left and right headphone lines.
            It is written 01X on it, which means 10ohms as far as I understood.
            But I can't read correct values, even if I try to read these out of the PCB.
            So I've just ordered SMD resistors to replace these.
            Hopefully, this will solve the issue.
            • madan1
              • Nov 2016
              • 691
              • Bulgaria
              What is the U18 ic?
              • nams2590
                • Apr 2023
                • 10
                • France
ID:	3719210 I can't find this chip over internet.
                • madan1
                  • Nov 2016
                  • 691
                  • Bulgaria
                  Originally posted by nams2590
                  Click image for larger version  Name:	20250905_182553.jpg Views:	0 Size:	1.70 MB ID:	3719210 I can't find this chip over internet.
                  How about this https://www.onsemi.com/pdf/datasheet/ncp2811-d.pdf
                  ps: TBH I expected a more generic classD amplifier IC.. but anyways - go with the standard things - check the power rail, signal enable pin, input analog audio and audio output audio pins
                  • nams2590
                    • Apr 2023
                    • 10
                    • France
                    Thanks a lot, I confirm it is the correct datasheet.
                    OUTL and OUTR are at these locations, and the 10 ohms resistors are also here.
                    It should be easier to troubleshoot now.
                    Thanks a lot
                    • rounin
                      MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                      by rounin
                      🛠 Original Issue
                      ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                      04-19-2025, 01:18 AM
                    • ugamazing
                      by ugamazing
                      12-17-2024, 07:05 PM
                    • shahnld
                      Lenovo legion 5 pro startup issue
                      by shahnld
                      Good day Experts
                      I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
                      A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
                      And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
                      08-24-2025, 12:31 PM
                    • ahmarzo
                      Acer laptop battery draining issue
                      by ahmarzo
                      Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
                      Help me to diagnose this issue as there is no shortage in the inputs MOSFET
                      08-02-2025, 06:39 AM
                    • elmark
                      HP 15-cw1002ua strange keyboard issue
                      by elmark
                      HP Pavilion 15-CW1002UA
                      S/N 5CD0251CBC
                      P/N 7KE54EA
                      Hello guys!
                      I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
                      It powers on OK and has no other issues except the following:
                      • CAPS LOCK does not work at all
                      • Fn button toggles Flight Mode
                      • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
                      • (with SHIFT pressed: 't%' and 'y^' respectively)
                      I initially thought it was a keyboard malfunction (internal short, etc.),
                      but when I press and hold...
                      06-27-2025, 01:10 AM
