Yamaha RX-A1040 internal error
  • Tom_x
    • Aug 2018
    • 33
    • Hungary
    Hi
    I have yamaha rx-a1040 with internal error message, when i plug ac cord.
    In the service menu show No Model Info! The service manual say, if the ic78 eeprom changed or corrupt, need rewrite model name
    Eeprom is renesas R1EX25512ATA00A 512kbit spi eeprom
    I readed eeprom maybe possible to repair....
    I need good dump, or procedure for program model name (i did it with htr2071 by shorting testpoint and set model name), but i can not find info for this avr
    thx
    Tom
  • R_J
    • 9602
    This is for RX-V1077/RX-A1040 Firmware Update Version 1.98
    Maybe this will work, it should reload the firmware from a usb drive
    • Tom_x
      • Aug 2018
      • 33
      • Hungary
      Thanks, i tried it before, not working bcoz no model info
      First need repair model info
      • R_J
        • 9602
        When it displays "No Model Info" do ANY of the front buttons change the display to show different model numbers?
        • Tom_x
          • Aug 2018
          • 33
          • Hungary
          I tried all buttons, combinations, no any reaction,onlyl No Model Info
          Power button pressing reset the unit and Internal Error message
          • Tom_x
            • Aug 2018
            • 33
            • Hungary
            No idea, how to restore Model Info?
            • SidneyCanadas
              93C46 and 93C56 EEPROM
              by SidneyCanadas
              I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
              https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
              Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
              06-14-2023, 01:16 PM
            • dmccul2698
              Pioneer DEX-P99rs "No EEProm " diagnostic code.
              by dmccul2698
              Hello, My head unit developed strange behaviors so I ran the built-in diagnostic package which returned "No EEProm". The service manual says there is no EEProm connected. I approached Pioneer and they said to swap out the DSP board. All said and good but the DSP board is $860 USD. I am hoping someone can help me
              1). Understand the schematic and check the connections between the EEProm and DSP
              2). Check the functionality of the EEProm
              I don't know if this is the unit's problem but it's a place to start.
              I have little to no electronic experience...
              04-08-2024, 05:32 PM
            • joshAU
              How to trick notebook into thinking internal panel is connected?
              by joshAU
              Hi all.
              I have an asus F505DV that has a smashed screen, broken hinges, bezel and top cover.
              The customer cannot afford to repair it, so they wanted me to remove the top of the unit and will just use the base as a desktop and plug into a monitor via HDMI.
              However, for some reason, with this model, it REFUSES to display on the external monitor unless there is also an internal LCD.
              If there is a internal screen, then the external displays fine.
              This is running the latest BIOS.
              I have set the display properties in windows 10 using...
              10-06-2022, 11:04 PM
            • lanovey
              SF314-41 BIOS without internal display
              by lanovey
              Hello there,
              I have a SF314-41 motherboard that i bought impulsively recently, the problem is that i only bought the motherboard only, nothing else. When i tried powering on the board with 19V (soldered on the DC IN port), and then shorting the pin 1-2 of the keyboard, the board is turning on (as indicated by the fan), however it seems like the board is displaying on the internal display as connecting to a display on the HDMI (external) does not display anything.
              I tried connecting a USB keyboard, the keyboard is powered on, however pressing numlock do nothing (supposed to toggle...
              06-13-2025, 02:38 AM
            • Rangry
              Razer Blade 15 2022, No internal display, Error Code 43
              by Rangry
              Hi! I have a Razer Blade 15 2022, with a RTX 3060.
              One day, while using Linux, the internal display suddenly stopped working.
              On Windows, it says that the internal GPU has stopped working (with error code 43).
              I have tried removing the coin cell and the battery, and replacing the RAM, with no success on fixing anything.
              I'm looking for directions to fix this problem, and, first of all, I would like to be able to access the BIOS and change some settings (which is currently impossible as it is always shown on the internal display). There is a setting...
              05-29-2025, 07:01 AM
