Sony SA WMS5
  • revoldius
    • Aug 2014
    • 6
    • Belgium
    Sony SA WMS5
    I've bought this subwoofer really cheap, works great but have a question. It has an auto power off, which is usefull because that way it uses a little less power. Now I would like to modify the time it stays of. So I want to know which component is the one that regulates the time.
    Schematic:
    Re: Sony SA WMS5
    "Now I would like to modify the time it stays of" Can you clarify that? You wan it to stay OFF and not turned on automatically when audio signal is present?
    The circuit right now will make the unit stay on as long as it detects the audio signal, when the signal is not detected, then after fixed period of time is timed out then it will go into standby mode.
    The signal detection and the ON time is done by IC602 NJM2072 and the timing cap C609 (1000uf 6.3V).
    • revoldius
      • Aug 2014
      • 6
      • Belgium
      Re: Sony SA WMS5
      That opening post sounded a lot better in my head, now it just seems like garbage...
      What I wanna do is change the time the unit stays on. Because some movies have quiet scenes and then suddenly a deep base scene. Problem is the sub isn't fast enough in switching on. So I needed to find out how to change the time.
      Can I change the value of the capacitor to any value, or do I need to stay within a certain range?
        Re: Sony SA WMS5
        OK, that makes more sense now.
        Right now the stay-on time is done by that 1000uF CAP C609.
        Typical sub woofer will stay on after the quiet period from 10~15 Minutes (my JBL does).
        So it can be that C609 lost its value, or the jumper on the connector CN603 is missing.
        The larger the value of C609 the longer will will stay on after quiet period.
        Did you try measuring the time how long it stays on after the audio signal is removed? you can see the LED status light.
        • ahmedtou
          HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
          by ahmedtou
          help me please
          I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
          When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
          I will share all the details with you, including the disc information.
          Code:
          HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
          Current Profile: BD-R
          Disc Information:
          Status: Empty
          State of Last Session: Empty
          Erasable: No
          Free Sectors: 12,219,392
          Free Space: 25,025,314,816 bytes
          Free Time: 2715:27:17 (MM:SS:FF)
          Next
          08-27-2025, 08:49 AM
        • Carlos#2003%
          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
          by Carlos#2003%
          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
          02-15-2024, 07:52 PM
        • dkneyle
          Sony KDL-46HX850 Can't upgrade/update firmware
          by dkneyle
          Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
          Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
          09-25-2024, 10:44 PM
          Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
          This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
          09-06-2024, 05:27 AM
        • titomno2
          Gaming Laptop Zephyrus S17 TFT not detected every time !
          by titomno2
          Hi guys,
          I post my problem here because I think it could be a capacitor related issue (Asus support on this particular subject is non-existing).
          So the computer is a Zephyrus-S17-GX735LXS-26T and the strange behavior is seen.
          On cold start most of the time the internal screen is detected and a picture it works fine until shutdown, sleep or deep sleep.
          Then the screen won't work for a long period of time.
          If I wait 1 or 2 hours it work again most of the time.
          When it doesn't work the batterie indicator blink 3 times white stop and the same schematic is repeated...
          01-19-2025, 08:27 AM
