i have searched nearly everywhere, and asked the company directly and they refused. i have negative 14.5 volts coming out the speaker out. they refused to RMA cause i am out of warranty. which is of course their right to do so, but unfortunately due to family circumstances i was unable to use it until now and it was DOA straight out of the box. i was hoping they would take pity on me but they don't care. you can't even download the user manual from them its crazy. i intend to fix this myself but i think it might be helpful if i had a schematic. as always any help is greatly appreciated.
can anyone help me find schematics or boardview for MM1500KFD (down4sound amp)
ill check if i can pull that out and take some pics. what is it? a discrete op amp? .. yah i am not too happy with the company. like i said it is my fault for not testing it before the warranty expired but they out right refused to even make a suggestion as to what to check in the circumstances i described and it coming DOA.. i.e. what is statistically most likely to be the problem.
*edit*
man is that vertical thing stuck in there, had a glob of hot glue on one side i cut away with a knife but still it is stuck. its pushed into those black jumper things (not sure what they are called right now) which means i should just be able to pull it out. i think.
another note, i have this thing mounted separate from the sub-woofer, so it will be isolated as much as possible. also since it never worked in theory it hasn't ever been vibrated.. unless they broke it with a test or something.Comment
this is the best i could do without taking it out. its very stuck, i am worried about causing more harm than good. i don't see anything on it that looks bad. if you think i should continue to try to take it out i will. or maybe desolder the 'single row female pin header' (i figured out what it is called)Comment
Not a car audio expert, but I see a TL494 in that daughterboard, it's for the power supply of the amp, the circuit there boosts the 12v from the input to whatever positive/negative voltage is needed for the audio amp section
That pinheader is soldered to the board
Post a picture of the bottom side of the board
Flip the board, connect the 12V supply, and wire in a switch from the middle terminal marked REM to +12v, carefully measure tbe voltage on the 2 big caps with the amp turned on, warning: high voltage there,don't touch the caps or the MOSFETs on the PSU section, the caps are rated 100V, expect something close to that, the voltages on both caps should be similar to each other
After removing power, to discharge the caps use a 1K 5W wirewound resistor across the caps for around 10 seconds, check voltages with multimeter, repeat until you get less than 1v on each big cap
The + output looks like it goes from that thick wire
The section marked in yellow looks like the power supply, the orange section looks like audio related, except the big cap circled in yellowLast edited by m1ch43lzm; 08-21-2025, 02:15 PM.Comment
that is some excellent info thanks. i haven't done it yet. here is what i have done. i checked as best as i can the mosfets and it looks like all the IRF 3205 on the audio side as you have laid it out are bad(or seem to be)and the far left RF B4227 is bad. i am going to try to source some of these parts to see if it is worth fixing.Comment
by McWhitePinkCan anyone help share the boardview for Z590i?
or help me find the value for these components, many components are missing-
by DorbinarHey all,
I am new to this forum. I often find myself searching fort schematics and boardview. I used google but often I end up on pay site. What is the best option? Is there a way to get them for free? Is there something ZI am missing that I cannot find free schematics and boardview. Any directions as to how would be appreciated. I do not want to constantly posting need hep finding...
Thanks-
by GfilipeZHi,
I'm diagnosing a machine that won't turn on.
When I did the visual inspection under the microscope, I detected a blown IC next to the USB-C connectors.
But i can't find this IC on schematic neither boardview.
I send attached pictures of the IC and its location.
Does anyone know if there is another version of Logic Board, which has this IC on schematic and boardview?
Best regards.... -
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
Channel: BIOS Requests ONLY!
- Loading...
