35v DC at speaker terminal!
  • onejay09
    • Nov 2011
    • 67
    #41
    Re: 35v DC at speaker terminal!
    ive got driver transistors being delivered as a complimentary pair so ill change those with the outputs, might start replacing the resistors that are like the jumper, corroded...
    • onejay09
      • Nov 2011
      • 67
      #42
      the jumper went from + from rectifier to r512 and r503
        Glad to hear that you found the problem, the black glue, was it soft? it looks like they use regular silicone RTV which is corrosive instead of using electronics grade silicone RTV.
          That explained why you did not get enough bias to the positive drive section.
          Now one thing is that you had -28VDC on the speaker terminals, that would have badly damaged speaker.
          • onejay09
            • Nov 2011
            • 67
            #45
            its an 8inch very heavy sub speaker! it seems fine.
            im worried that something is a miss, if not the fact that the mica insulater slipped from behind the tip36c, why wouldnt this cause both to blow?
            i have took them out and theyre both dead short
            • onejay09
              • Nov 2011
              • 67
              #46
              it ran great for about 1 minute.
              well the black stuff where not charred to a crisp was more like tar and where it was hot it was more like burnt plastic.
              after i blew the outputs i decided id pass the time by cleaning the board where i could, replaced all the jumpers that were brown and crispy, also pulled some bigger parts off to get the last of the RTV off. went over all the solders, made some traces bigger.
              noted the resistors id like to replace..
              just waiting for these parts
              • SteveNielsen
                Retired Tech
                • 2327
                I don't like the looks of that cap below Q603. The R906(?) resistor, and that black near the top of the white block on the left above it looks like it might be from a flame-flash. Does that Resitor check out ok?
                • onejay09
                  • Nov 2011
                  • 67
                  #48
                  i have recapped the board all except 1 or 2. the black stuff is glue, but yea one of the poly caps blew near there.
                    I do not think any speaker can handle 28VDC on the Voice coil., @ 8 ohm, that will be about 3.5 DCA, almost 100W of steady state of power.
                    • onejay09
                      • Nov 2011
                      • 67
                      #50
                      ill check its impedance when i get home but it sounded ok, im wondering if the new outputs arent matched then could i increase the value of r524 and r525, if i understand right these are emmiter resistors? would it give some lee way if the power transistors are not matched up well, what would the side effects be if i increased the values?
                      • onejay09
                        • Nov 2011
                        • 67
                        #51
                        just got the outputs today, what should i be checking before i put these in?
                        0.4 v dv at r519/r520.
                        • ben7
                          Capaholic
                          • Jan 2011
                          • 4059
                          You should check all the other transistors in the amplifier circuit, and the resistors too. Unfortunately, amplifier circuits can suffer cascade failures, where one component blows and causes more to blow with it!
                          Muh-soggy-knee
                          • onejay09
                            • Nov 2011
                            • 67
                            #53
                            its fine it turns on and runs, just waiting for new vbe and driver trans delivery
                            • onejay09
                              • Nov 2011
                              • 67
                              #54
                              put the new output transistors in and a new (q507) vbe in, turns on but no sound nothing!
                              • onejay09
                                • Nov 2011
                                • 67
                                #55
                                nevermind its working again, it was the q507
                                • rievax_60
                                  • May 2012
                                  • 897
                                  • australia
                                  #56
                                  The only way for Q507 to cause no sound without resulting in permanent damage is if its Collector or Emitter pin was in contact with the grounded heatsink.
                                  If any of Q507's pins become disconnected from its circuit, it will cause both output transistors to turn on hard, drawing excessive current from the rails and then likely to both go short.
                                  R523 going open will have the same result.
                                  • Adder
                                    • Jan 2017
                                    • 3
                                    • Great Britain
                                    #57
                                    Hi. I have a dead VW-8 which seems to have failed components in the AC power supply.
                                    The circuit diagrams which have been posted don't seem to match mine.
                                    The main AC input seems to go to a control relay which isn't pulling in (no AC getting to the mains transformer). It also goes to a large resistor (R1 4.7ohms I think) which seems to be open circuit. This resistor seems to feed into a bridge rectifier which has a failed inductor on it's output side (casing cracked) and a diode also looks like its overheated.
                                    None of these components seem to show on the schematics here!
                                    Does anyone have any different schematics for this amp?
                                    • Agent24
                                      I see dead caps
                                      • Oct 2007
                                      • 4953
                                      • New Zealand
                                      #58
                                      It would be greatly helpful if you can post photos of your unit, the blown components, etc.
                                      The soft-on relay circuit may be simple enough that you won't need a schematic anyway.
                                      -David VanHorn
                                      • Adder
                                        • Jan 2017
                                        • 3
                                        • Great Britain
                                        #59
                                        Here should be some photos of the board which seems to have the fault:
                                        https://drive.google.com/open?id=0B5...ndMQ2NkWmpRQVk
                                        Resistor R1 seems to be open circuit (8Mohm across it)
                                        Inductor L8 has a cracked case but seems to have continuity still.
                                        I thought diode D2 looked overheated but it still measures 0.5v drop across it ok.
                                        There seems to be around 24 ohm across the output of bridge BD1 (seems a low value)
                                        The mains switching relay doesn't pull in (hence no AC to transformer).
                                        I didn't see any of these parts on the schematic which had been posted for the VW8.
                                        Connector at end of board is marked as CN3A.
                                        Any ideas?
                                        • Agent24
                                          I see dead caps
                                          • Oct 2007
                                          • 4953
                                          • New Zealand
                                          #60
                                          I've attached your photos here so that 1) they're easier for everyone to view and because 2) external links have a habit of disappearing after some time
                                          Anyway - replace R1, obviously.
                                          D2 may test OK but it's definitely been stressed and should be replaced.
                                          Maybe a good idea to replace the bridge rectifier for the same reason.
                                          L8 may still have continuity but may have lost inductance (shorted turns) so replace that too.
                                          Probably with that low resistance reading you will find the LNK364PN controller IC has shorted. This may have been caused by D2 going bad in some way - it appears to be part of a snubber network which protects the IC. Or maybe the IC went bad and burned D2.
                                          Check C2 is not bad, check any SMD parts (R2 underneath?) connected to D2\C2 as well. Check C1 does not have reduced capacitance. Check\Replace D1.
                                          You may find that the U3 optoisolator has been blown up as well, if the LNK364 has died spectacularly enough.
                                          After doing all that, power up with a series lightbulb to the mains supply and see what happens.
                                          -David VanHorn
                                          • falkikowski
                                            NuPro A-20 Active Speaker burnt LNK 606
                                            by falkikowski
                                            The LNK 606 on the power board for my active speaker just went to hell.
                                            I would like to replace it, but this very model is hard for me to get. Can I replace the LNK 606 with the LNK 616 or the TYN 266?
                                            I also attached a picture of the back side. The burnt part above R2 is a bridge, that is connected to the COM of two chunky electrolytic condensator (82 micro Farad, 400 V). I just tidied that up. Or should I worry about that?
                                            Thanks​
                                            falkikowski...
                                            10-03-2024, 03:09 AM
                                            HP ProDesk 600 G5 + Bluetooth Speaker 400 ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                            This specification for the HP ProDesk 600 G5 + Bluetooth Speaker 400 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + Bluetooth Speaker 400 boardview and ProDesk 600 G5 + Bluetooth Speaker 400 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                            09-12-2024, 02:30 PM
                                            HP EliteBook 840 G6 + Bluetooth Speaker 400 Notebook 800 Specification for Upgrade or Repair
                                            This specification for the HP EliteBook 840 G6 + Bluetooth Speaker 400 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G6 + Bluetooth Speaker 400 boardview and 840 G6 + Bluetooth Speaker 400 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            09-06-2024, 06:00 PM
                                            HP EliteBook 830 G6 + Bluetooth Speaker 400 Notebook 800 Specification for Upgrade or Repair
                                            This specification for the HP EliteBook 830 G6 + Bluetooth Speaker 400 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 830 G6 + Bluetooth Speaker 400 boardview and 830 G6 + Bluetooth Speaker 400 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
