Behringer Pro Mixer DJX-750
  • Longon
    • Jul 2025
    • 46
    • United Kingdom
    Hi all....I have been using my Behringer mixer quite comfortably for a number of years now and generally it's been trouble free apart from a replacement crossfader. Recently input three channel fader began to bleed a little and causing the mixer to light up like a Christmas tree! I realise the unit is ageing now and although I'd put some hours on it over the years it's not been abused. Following the issue I planned on replacing the faders and ordered the necessary parts. In the meantime whilst awaiting the replacements I continued to use the mixer up until the channel fader started to give feedback as if there was an earthing problemand as mentioned lit up like a Christmas tree but with a gentle tap would return to normal operation except for a little bleeding and crackling. I decided best not to use any further as could begin to cause damage. Having received my parts I powered up prior to starting the repairs and to my surprise the problem had become worse. After opening up the mixer I thought it best to check some of the components with my multimeter and discovered that a number of capacitors had for some reason shorted around the suspect input three...aaarrrghhhh bo##ox...gutted! Now I have new parts which I am now reluctant to exchange until I have traced the culprit/s that caused the caps to blow. Am now awaiting replacement SMD caps prior to even beginning to think about the faders.
    I expect it maybe time to retire my old faithful to mixer heaven but without first identifying what caused the problem to begin with it will send me a little 'off key' with the not knowing even if I'm chasing a lost cause...plus I'm stubborn.
    Therefore if anyone has any input I'll be happy to receive, also the possibility of locating the whereabouts of a schematic would be helpful and much appreciated.#
    Stay safe all.
    Long
    • 31278
    you forgot to attach
    the pictures
    • Longon
      • Jul 2025
      • 46
      • United Kingdom
      the pictures
      Hey STJ sorry I'm a newbie here so am still having to work out the process here!
      I'm not even sure if your message is directed to me 🤪...
      if you are referring to my comments then please ignore my ignorance as have messages from others that have nothing to do with my post!? Need to somehow change my notification settings.
      long
        • 31278
        no worries.
        we like to see pictures here so we can see the quality of the product
        • Longon
          • Jul 2025
          • 46
          • United Kingdom
          Hopefully clear enough ......caps 255/281/282/284 have shorted?
          If need to see anything else then let me know STJ..
          Thanks for your interest and time.
          long
            • 31278
            i would be verry surprised if those are shorted
            remove one to confirm it
            • Thermaltake
              Power button on Behringer Xenyx 1204USB mixer dead ?
              by Thermaltake
              Hi, I got Behringer Xenyx 1204USB mixer, and in the morning mixer was working fine, but when I came home from bike ride I turn it On but nothing happend. Phantom switch is working because red light is On, but other switch no respond.
              I brought mixer to my friend today who is electronic expert and he will tell me if it's the button or something on power supply that died. But I am 90% sure that it's power button. My question is, is it possible to put some better quality switches on that mixer than the ones mixer came with, I found them very cheap and low quality.
              08-16-2022, 03:22 AM
            • Transformer man
              Fader replacement on 1980s mixer - help with this schematic
              by Transformer man
              Hi - I am looking to replace faders on a mixing desk from the early 1980s. They are tired and worn. I'm new at looking at schematics and would really appreciate your help and expertise on replacements.
              The current faders are 88mm long with 60mm fader movement and are 10K B (which I think is a linear fader). They have been swapped out at some point (tell tale signs of additional screw holes a few mms below the top screw hole).
              I think the schematic suggests 5K B faders (but as a newbie I'm not sure if I am even looking at the correct part of the schematic!?). I have...
              04-22-2023, 04:13 AM
            • dicky96
              Behringer Europower PMP3000 Mixer - LED Bar Meter sticks at high level
              by dicky96
              Hi guys
              I have this faulty mixer here. Basically the owner says it worked fine at one gig, then the next one it didn't
              When I power on, both the L & R LED Meters go to +4 and stay there. This is without any input and with all sliders Level Set knobs set to zero
              Also the LED meter on the 24-bit dual engine DSP goes to red (clip)
              I didn't connect an speakers but if I use headphones I can hear what I can best describe as a purring noise on both channels
              I found a schematic for the PSU There is a 10 way ribbon cable going from the PA/PSU...
              10-29-2021, 03:56 AM
            • Bektronics
              Schematic Digital Audio mixer RCF type M18
              by Bektronics
              Hello dear audio friends.
              I am feverishly looking for the full electronic schematic (not a block diagram) of the RCF type M18 digital audio mixer.
              The device does not make a WIFI connection with my Apple tablet and yet I have already installed the recent app on it.
              I suspect that there is a problem in the mixer itself with the WIFI card and of course I would like to see this on an extensive schedule before opening the device.
              Thanks in advance if anyone can help me with this schematic.
              Of course, all information about this digital mixer and possibly references...
              07-24-2023, 06:40 AM
            • Thermaltake
              Behringer xenyx x1204usb mixer
              by Thermaltake
              Hi, I have few questions
              1. few of my pots on mixer are turning so hard, I tried to clean them and spray some DeoxIT Fader spray in it, but it didn't help. Is there any way to put some grease inside that pots whole that is on the side instead of spraing in it ?
              2. Or is it just simpler to replace them all with same ones ? I am not into pots, so am I able to put some better quality ones or it needs to be same one as they were default ?...
              09-17-2024, 10:57 AM
