Pioneer VSX-1022K not acting right
  • tibimakai
    • Jan 2012
    • 3680
    I have picked up this receiver from Ebay, it wasn't tested by the seller.
    It seems like it's working, there is audio and video, but I can't get audio from rear surround back speaker(tried the test tone also and still a no go), I'm having a hard time getting into the Network settings and I can't get into the service mode.
    Every time I try to get into the Network settings, it shows Can't Select.
    Eventually when I get in there, it will show Please Wait indefinitely.
    I'm suspecting firmware error/corruption.
    After many tries, I have managed to start the firmware update, but it ran for hours and never finished.
    I have a feeling that I will have to replace the EEPROM from the PC board which it seems to be a 24C16A IC. It's next to the CPU.
    Anybody has experience with flashing and EEPROM? I have never done it before.
    Any input would be appreciated.
    First I would like to repair the functionality of the receiver and then I would deal with the amp section.
    By the way, I have removed the amp section and I did not find bad components at the final stage.
    • 31024
    Re: Pioneer VSX-1022K not acting right
    24c16 is 2k, it's only for holding settings.
    • tibimakai
      • Jan 2012
      • 3680
      OK, then I will have to look into the schematics.
      Before that, I will try to update the firmware, with another USB stick(older 512MB).
      • Agent24
        I see dead caps
        • Oct 2007
        • 4953
        • New Zealand
        Checked that all the voltages are OK?
        -David VanHorn
        • tibimakai
          • Jan 2012
          • 3680
          I haven't checked yet, because I'm suspecting a firmware went wrong situation here.
          • Agent24
            I see dead caps
            • Oct 2007
            • 4953
            • New Zealand
            Bad power to the EEPROM\CPU could cause bad operation too, though.
            -David VanHorn
            • tibimakai
              • Jan 2012
              • 3680
              I will measure some voltages then. Thank you for your input.
              I don't know the history of this receiver, this way it makes it much harder to figure out what it could be the problem.
              • Agent24
                I see dead caps
                • Oct 2007
                • 4953
                • New Zealand
                Checking voltages is the first thing you should do, unless something else is immediately obvious. It may well be that you do have an EEPROM problem, but AFAIK EEPROM problems are often caused by bad power to begin with.
                -David VanHorn
                • tibimakai
                  • Jan 2012
                  • 3680
                  I have the schematic in front of me and I'm measuring the STBY board output connector, but I don't know how much should it show.
                  This is what I'm getting:
                  CPU_ST_VCC= 7.25V
                  STBY_RLY= 3.1V
                  PDN= 0.02V
                  STBY_VCC= 7.32V
                  CPU_3.3V= 3.28V
                  FLAC= 2.36VA
                  FLCT= 10mV
                  FLAC= 2.36VA
                    • 31024
                    jesus.
                    i'm damned sure VCC should be 5v or even 3v3
                    • tibimakai
                      • Jan 2012
                      • 3680
                      Do you mean the CPU_ST_VCC?
                      Soon I will get a VSX-1122K and I can compare these voltages, but for now we don't have a reference.
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 4953
                        • New Zealand
                        Can you upload the manual? Does it not give any indication as to what the voltage should be?
                        -David VanHorn
                          • 31024
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 4953
                            • New Zealand
                            Ahh, too big to upload I see.
                            -David VanHorn
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 4953
                              • New Zealand
                              I can't see where the CPU_ST_VCC comes from but it may not be too high. That rail does power IC101, a NJM2831F05 which is a 5v regulator, it would make sense to give it more than 5v.
                              However, it's a LDO with dropout of 180mV so who knows..
                              Found where CPU_ST_VCC comes from: Check Page 128 STBY ASSY board (W). Looks like unregulated supply and not much to go wrong, so that voltage is probably OK.
                              -David VanHorn
                              • tibimakai
                                • Jan 2012
                                • 3680
                                I had to do a second reset(paragraph 3.4), before the Preset arrow left+STBY.
                                If I manage to get to that screen, which is very hard by the way to get too and I start the update, it will never end. Last night, I have left it all night and in the morning it was still updating.
                                I think, I will just leave it this way, if there are no more input from you guys.
                                • mmartell
                                  • Oct 2013
                                  • 3189
                                  How about using ponyprog to read the eeprom (and save it) then erase it and see if the firmware is capable of writing a bootable copy to it ?
                                  • tibimakai
                                    • Jan 2012
                                    • 3680
                                    It would be nice, but I don't even know what is that.
                                    I'm all ears.
                                    It seems like I'm bumping more and more into EEPROM issues. I may have to buy soon a programmer and I need to learn using it.
                                    I'm working on a Vizio E371VL also, which most likely needs a new EEPROM.
                                    Kenwood nav units need a programmer, though not a basic one.
                                    MCUMALL soon is coming out with a new unit GQ-5x. I'm keeping an eye on that, Right now, it's on pre-order and it's $110 cheaper, then it will be when it will be available. There is also a TNM 2000+ and 5000+ that I may buy.
                                    • mmartell
                                      • Oct 2013
                                      • 3189
                                      Forum or phone crapped out and lost my response. Short version: locate the eeprom chip and test the caps around it with an esr meter. Flaky power is known to corrupt certain serial eeproms. Tbh though seems like a longshot with a newer device such as this.
                                      • Bushcat
                                        Pioneer PL-X9 motor speed control wobble
                                        by Bushcat
                                        I'm starting to re-cap a Pioneer PL-X9 turntable, specifically the motor control board, because although everything tests out OK according to the service manual, the speed wavers slightly despite the quartz lock light remaining on. So, I've decided to re-cap that board since it's the cheapest next step...
                                        Pioneer's passive component naming convention is clear to me. For example, CSZA R22M 35 is tantalum, radial leads, 0.22uF, 20%, 35V.
                                        BUT there are two capacitors on the board which have actual Pioneer part numbers: PCL-042. I can tell they are 0.1uF, 16V but don't...
                                        05-24-2023, 03:36 AM
                                      • EduCabral
                                        [Help Needed] Yatour YT-M06 (Pioneer 1) – Firmware or Schematic Request
                                        by EduCabral
                                        I'm currently working on reviving a Yatour YT-M06 CD Changer Emulator module for use with a Pioneer 1 interface (specifically with a DEH-P5950IB head unit).
                                        While the unit is recognized as a CD changer, none of the USB, SD, or AUX features respond, which leads me to believe the firmware may be corrupted or incompatible.
                                        🔧 Details:
                                        • Model: YT-M06
                                        • Interface: Pioneer 1
                                        • MCU: Fujitsu MB89F202
                                        • Goal: Find a valid .bin firmware file or memory dump from a working unit
                                        I'm happy to attempt flashing, analyzing memory dumps, or doing hardware-level...
                                        07-15-2025, 12:26 AM
                                        TF-FUSE Thin Film Surface Mount Fuses (Very Fast Acting), 0603 Size Datasheet
                                        FF Series (Very Fast Acting), 0603 Size
                                        Features
                                        ● Very fast acting at 200% overload current levels
                                        ● Low DCR
                                        ● High inrush current withstanding capability
                                        ● Fiberglass enforced epoxy fuse body
                                        ● Copper termination with nickel and tin plating
                                        ● Halogen free, RoHS compliance and lead-free
                                        Applications
                                        ● Notebook computers and tablets
                                        ● Digital cameras
                                        ● Memory cards
                                        ● Toys
                                        ● Bluetooth earphones
                                        ● Portable electronic devices​...
                                        10-07-2024, 05:50 AM
                                      • pixelcap
                                        Pioneer Kuro Pro 111FD 8 red blink error
                                        by pixelcap
                                        Pioneer Kuro Pro 111FD 8 blink red LED.
                                        I have been trying to solve the power-down 8-blink red LED problem with my Pioneer.
                                        So far I have replaced the power supply board, and the digital assembly board, I have reconnected the ribbons to all boards, ensuring the connections are good. Even though the problem is the 8 red light error and not the more common 8 blue light error code, I had Kcrownie,
                                        based in North Carolina replace the chips that cause the 8 blue LED problem (the main board and audio board) the plasma is still powering...
                                        10-06-2024, 11:26 PM
                                      • RatherLoopy
                                        Pioneer VSX-44 receiver HDMI dropouts
                                        by RatherLoopy
                                        I have an older Pioneer receiver (VSX-44) that's been dropping the HDMI output (black screen) for a few seconds every few minutes. Setup is HTPC -> Pioneer DVD HCMI in -> Pioneer HDMI out -> Samsung TV HDMI in, all with cheap HDMI cables that have never caused trouble before..
                                        I initially found a lot of play in the receiver's HDMI inputs and output so I kind of squeezed them back into shape and they're making a tighter connection, but the problem persists.
                                        And also, often, the HDMI will drop out in exactly the same way (black screen) just as my central air...
                                        05-26-2023, 03:54 PM
