YAMAHA CLP-550 without of sound
  • AlexVG
    • Apr 2022
    • 135
    • SPAIN
    Hi.
    I have an old YAMAHA CLP-550 without sound. (Some times I can get some kind of noise or distorted sound)
    I have replaced all green marked elements, but it gave me nothing.
    The IC12 chip LC9116A-105 (red marked) remains under suspicion yet.
    Click image for larger version  Name:	CAPs.jpg Views:	0 Size:	1.06 MB ID:	3654925
    But it is custom YAMAHA's chip, and I can't find any information about it.
    Maybe somebody came across with the same issue?
    Any information will be very useful. I will be very appreciated.
    Thank you.
    • 31058
    forget that.
    read the roms - they are compatable with 27c040
    these old yamaha keyboards are all losing their memory now.
    if you search the forum their is a long thread where we dumped several keyboards to get a single good set of chip dumps.
      • 31058
      here:
      https://www.badcaps.net/forum/troubl...eyboard-output
      and
      https://www.badcaps.net/forum/troubl...p550-rom-codes
      • AlexVG
        • Apr 2022
        • 135
        • SPAIN
        Yes. Thank you!
        • AlexVG
          • Apr 2022
          • 135
          • SPAIN
          Hi, I replaced all of 27c040 and programmed with the dumps from here.
          Something changed, but not sound yet.
          I guess IC6, IC7 must be also replaced.
          Do you have any suggestions?
          Maybe dump from IC6, IC7 helps?
          • jjne
            Yamaha RX V675 sound issues
            by jjne
            I have an old Yamaha RX V675 receiver which is starting to develop issues with the sound, although it doesn't quite match up with what folk normally report with these.
            From cold, the sound cuts in and out. When this happens the amp is losing sync with the optical input (speaker graphic disappears from the front panel). But this is not resolved by putting the unit into pure direct mode. After a couple of minutes this resolves, although there are occasional clicks from the speakers after that.
            At first I thought it was either a speaker relay or the DSP, but I don't think...
            06-24-2025, 07:01 AM
          • ChaosLegionnaire
            by ChaosLegionnaire
            09-13-2022, 09:02 AM
          • maleksa
            Yamaha MOX8 boot freeze and distorted sound
            by maleksa
            My Yamaha MOX8 synthesizer recently developed two issues.
            Firstly, after booting up, it operates as normal. However, after about 5 minutes, the sound starts to get distorted (broken up screeching sound) almost like putting it through a guitar distortion pedal. After a while, the distorted sounds will go away for a while and comes back. At times, the synthesizer will also freeze I need to power off and on again.
            Secondly, when powering off and on again, there will be times where the synthesizer will freeze during the boot sequence (freezes at the MOX8 Opening Screen),...
            11-07-2024, 03:28 AM
          • Rupsenkind
            Yamaha RX-A1030 working, no sound output
            by Rupsenkind
            Hi all, I've started this new thread in order to avoid further polution of thread "Yamaha RX-A3010 working, no sound output"
            Just to recap:
            No sound through Audio and AV analogue inputs, only sound when 2ch stereo or pure direct is activated (so no sound when I e.g. choose 7ch of Hall in Munich etc.). Hoever when I connect HDMI I've sound in all options (movie, music, eyc.) First suspicion was the DSP chip/PCB so I bought a scrap 1030 with a good functioning PCB (in this one a driver stage was defective (PRT DC: 67), after I swapped the PCB I've performed a factory...
            07-10-2022, 03:15 AM
          • daigs
            Yamaha P-115 turn on but No sound - Doesn't turn off
            by daigs
            I need to repair a P-115 yamaha digital piano with a strange behaviour.
            When I power on the piano from the dedicated on/off switch, the power led go to ON (red led), but the keyboard doesn't produce any sound, nor in the speakers nor in the headphones.
            When I try to power off (pressing the switch for at least 1 second), the keyboard doesn't power off, the red led remains ON. I need to unplug the adapter cable to switch off the keyboard.
            I checked the 12V voltage rail on the input PCB, after the power plug and it is OK.
            I checked also the...
            07-18-2023, 03:47 PM
