Bass Guitar Pre-Amp - Assistance required from local geniuses please!
  • Ozyris
    • Apr 2014
    • 41
    • England
    Greeting fellow tinkerers!
    So I have this bass guitar to fix. Someone tried before and was unable to to do it. l Between us I think we could make a darned good effort!
    The preamp has been disconnected (I believe its a replacement that was not wired in properly). I have been unable to source a wiring diagram or even locate a supplier to ask for the connection schema. So its down to detective work.
    First obstacle: The board itself is hidden within an impenetrable layer of opaque black epoxy. All we have to go on are the wires coming out of it and the understanding of what it is supposed to do.
    It looks like this:
    It is supplied by a 9V battery via a single wire. It receives a single pickup-level input signal. It connects to two tone controls (treble and bass), each with three wires. It connects to a single volume/gain control via two wires. It connects to ground via a single wire. It outputs to the jack via a single wire. Total of 12 wires. They may not be grouped correctly in the picture.
    You may cheat and post the connecting schema if you happen to have one of these devices to hand. That would be good.
    I have checked every combination of wires with a (cheap) voltmeter / ohmmeter and developed a tabulation of what I found. I shall post this up next as a table and a scribbled diagram.
    Help, as previously will be deeply appreciated.
    (bows in humble appreciation of the genuises/genii hanging around this forum)
  • SteveNielsen
    Retired Tech
    • Jun 2012
    • 2327
    Re: Bass Guitar Pre-Amp - Assistance required from local geniuses please!
    What's the make/model of the bass guitar?
    edit: I'm not a genius but I know my way around electric guitars pretty well.
    • Ozyris
      • Apr 2014
      • 41
      • England
      Okay, so here is the table of measurements. As I suggested above, these are really very approximate. Where there is no number there is no measurable voltage or alternatively infinite resistance. To measure voltage I connected a 1.2V AA battery in series with my meter, then connected across pairs of wires.
      I will post a scribble diagram of my interpretation of this table shortly.
      Thanks!
      • Ozyris
        • Apr 2014
        • 41
        • England
        Hi Steve. Thanks for getting stuck in! Its a Crafter Cruzer four string (no snide remarks please = not mine!). No other identifying marks. I doubt this preamp is original.
        • SteveNielsen
          Retired Tech
          • Jun 2012
          • 2327
          No snide remarks from me, I'm no guitar snob. What model number? There are lots of variations in pickup and switch/control wiring.
          • Prop1
            • Jun 2014
            • 93
            I repaired guitars and amps back in the '70s. Looking at your picture and what is sold on the internet; they all, but a very few, come prewired to the pots, output connector, and battery connector. You either have a really cheap one that is worthless, or someone removed the other parts. You would likely be money, and headache, ahead by buying better quality with all the parts and wiring instructions. They all use different wire colours, so without the actual manufacturer; you'll never find a drawing.
            • Ozyris
              • Apr 2014
              • 41
              • England
              Hello Prop1! Thank you for diving in. Yes indeed, it may well be not worth the trouble. But sometimes puzzles are fun. Check out my repair job on my Alesis M1 MK2 Active Monitors for a little insight into that.
              I am afraid there is no further identification on the guitar.
              Regarding the pots etc they are all there. I have good clean signal on the output of the blend pots. That's where the board will get its input signal from.
              Here is my "scribble" layout of how the connections tie up. So each brown or grey line represents something that connects the wires together on the PCB. Brown for low resistance / higher voltage reading, grey for higher resistance / lower voltage reading.
              I figure the "no readings" ones need something inside the board fired up or something connected to one or more of the other wires to have a signal or voltage.
              Hmmm...
              • Ozyris
                • Apr 2014
                • 41
                • England
                ...I am thinking that 10 might be the ground?
                • Prop1
                  • Jun 2014
                  • 93
                  All blacks wires in this case will be grounds of some sort, but not necessarily to the battery for isolation purposes. Likely the 2 reds and the black grouped together went to the battery. I'm thinking the black, orange, yellow, and white are coming from the pickups. The rest would go to the pots and output connector. But that's just an educated guess.
                    • 31218
                    one word - nitromors.
                    • SteveNielsen
                      Retired Tech
                      • Jun 2012
                      • 2327
                      Yeah, Prop1 is probably close but without knowing the guts of the circuit it's impossible to tell for sure. Not sure if it's worth trying to dissolve the potting for but I'm not a big fan of magnetic-coil pickup on-board preamps anyway. They raise the noise floor and cause distortion. Even cheap pickups usually have sufficient output for the preamp in a guitar amplifier. There are better ways to get an "overdriven" sound without actually overdriving the guitar amp input, IMO.
                      • Ozyris
                        • Apr 2014
                        • 41
                        • England
                        Hello everyone and thanks for the input so far. Just had to dash off to Heathrow airport to fetch someone but back now.
                        Thinking in the car that my last diagram needs a tweak. Every one of the coloured junctions actually represents one of the wires coming out of the board. So here it is with that idea clarified.
                        It may not help anyone else's thinking but I think it helps mine.
                        It also occurred to me that it is probably only the hidden opamp that needs power, or am I wrong? As it is a dual stage preamp (treble and bass) there may be two power supplies to the opamp, but the division of power will be handled on the hidden pcb. Which might suggest that one of the "unconnected" wires is the power connection...
                        Regarding the idea of how the wires might be "grouped" (they are indeed grouped with shrink tubing as per the original picture), it is worth noting, I think, that the two tone pots have three wires each. One to each terminal and one for the sweep. As its an active tone preamp I suspect at least two of them will be connected to the opamps internally. There is a centre detent on each tone pot, which suggests cut below centre, neutral at centre and boost above centre for each one. Logical?
                        The blending is done external to the pcb. The signal is delivered to the board on one wire after the blend pot. As I mentioned,there is good strong clean signal at that point.
                        The volume pot may or may not get gain from the pcb. It has its own external ground in the normal way and only had two wires previously soldered to it. Both I think went to the pcb.
                        It may be a point to start at by assuming the existing grouping might have some value and go from there? It looks like this:
                        Hmmm...remember it could easily be wrong and what caused the other tech to give up...
                          • 31218
                          given that you dont even know or have not said if it's single-rail or split-rail power input,
                          i think nitromors is the best option.
                          • Prop1
                            • Jun 2014
                            • 93
                            1,2,3 are clearly power.
                            4,5 I suspect are output.
                            6,7,8 I think are tone related.
                            9,10,11,12 I think are inputs from the pickups.
                            I suspect there are more than 1 opamp on the pcb. One for amplification, and one for tone.
                            • Ozyris
                              • Apr 2014
                              • 41
                              • England
                              Hello stj. I am wondering as to the meaning of the word "nitromors"?
                              Prop1. Thanks for taking the time to think about this. Just to recap - there are two tone controls, one for bass and the other for treble, each needing three wires. The unit is a 2-band EQ preamp.
                              The pickups are connected to the blend pots which are not involved in the preamp other than supplying it with a pre-blended signal through one wire.
                              Two wires were previously connected to the volume pot suggesting there might be some gain activity in the board.
                              There will be a ground wire and a power wire, plus there will be a signal output wire. That's twelve wires accounted for.
                              • Ozyris
                                • Apr 2014
                                • 41
                                • England
                                So, as the power wire is often red on such circuits as your post suggests, then 1 or 2 may well be the 9v+ connection. Looking at my diagram it seems unlikely that it would be 1 as it doesn't make sense to me to have substantial voltages all over the pcb (relatively speaking). It seems more likely to me that 2 would be 9v and would go only to the opamps.
                                I agree that it is probably a dual opamp similar to the TLC074 or LM741.
                                Connection 1 may well be the signal output or input. Red is often used for the hot wires. Plus it is connected strongly to 10 but also through some resistance to 3, 6, 8 and 12. As we know, on passive circuitry the signal at the volume is connected to the two tone pots grounded via the caps and the pot resistance, and my tests in such a case would have revealed that. So perhaps that is what the diagram is telling us? That one of 3, 6, 8 and 12 will definitely be going to the treble and bass pots, maybe even the volume pot too?
                                Not sure how much more time I can afford to spend playing with this...got some replacement units on the way...
                                • Prop1
                                  • Jun 2014
                                  • 93
                                  This is just a guess, I've been out of electronics for years, but the 9v maybe going to a voltage divider to create a simulated +9v and -9v. That's why there are 2 red leads. If my memory serves me correctly; opamps require a + and - power?
                                    • 31218
                                    nitromors is a gel based paint stripper that can be used to break down epoxy-based potting compound.
                                    it's used a lot to remove resin from chips in laptops and "security" modules.
                                    • Ozyris
                                      • Apr 2014
                                      • 41
                                      • England
                                      Aha. Thank you stj. I learn so much here. Sounds expensive. Relative to the preamp...
                                        • 31218
                                        it's about £6 a liter i think from diy shops.
                                        • zzpkcq@gmail.com
                                          Squire bass guitar amp PB 15 no sound
                                          by zzpkcq@gmail.com
                                          Looking for a schematic for this amp to help solve no output problem.
                                          Power input ok no shorts, signal tracing for me is why I could do with a schematic.
                                          thanks in advance...
                                          05-25-2024, 02:31 PM
                                        • Nevillet
                                          Bass guitar output level
                                          by Nevillet
                                          I am repairing a bass guitar amp and need a test signal to drive it.
                                          Can anyone tell me what that would be in mV or μV?
                                          Many thanks.
                                          03-23-2022, 07:44 AM
                                        • eduaqa
                                          Amplifier - bad sound when loud sound on bass
                                          by eduaqa
                                          I'n trying to fix a M&S SYSTEM DMC-1which have following problem:
                                          I'm using FM station to do this fix, I works perfect if volume below around 8 or if bass is set to zero, the sound can go to 20 without problem, but if I set bass to maximum and try to go over 10 the sound comes distorted ... I saw a video on YouTube the person saying about the main capacitors on the power portion, but I disconnect the main transformer and inject direct to the capacitors PINs my bench power supply -23v 0v +23v, but still distorted so I think the problem is not the capacitor neither the transformer...
                                          08-06-2022, 11:28 AM
                                        • Zonzi
                                          Telefunken L70 speakers, one has a nasal sound with less bass
                                          by Zonzi
                                          Hi everyone !
                                          Once again I have an issue with old stuff I found for cheap, guess I have a taste for these.
                                          I bought these two Telefunken L70 speakers for 20€ (https://www.radiomuseum.org/r/telefu...r_box_l_2.html), and they are in a superb state, component-wise. The box is scratched but I couldn't care less, I'm interested by whether it works or not.
                                          They do work, and have a really nice sound, but one of the two has a problem with its 8" woofer. It's got practically no bass, and the mids are really pushed...
                                          05-31-2023, 12:34 PM
                                        • pfl
                                          The box pro - Achat 108 sub A troubleshooting
                                          by pfl
                                          Hello Everyone.
                                          The issue with this audio device was a very low bass level ; tracking the bass signal path on the preamp module i discovered a missing component (resistor R98) on the inverting input of op. amp U14 (allegedly active low pass filter) (see picture).
                                          I put a 1k resistor but now R/L passive speakers sound level is too low compared with bass level ; i guess resistor value is wrong
                                          Can someone tells me what's the correct value of R98 on preamp pcb
                                          or
                                          can someone provide me with schematics / service manual
                                          pierre...
                                          06-23-2025, 08:53 AM
