Squire bass guitar amp PB 15 no sound
  • zzpkcq@gmail.com
    GT
    • May 2024
    • 12
    • United Kingdom
    Looking for a schematic for this amp to help solve no output problem.
    Power input ok no shorts, signal tracing for me is why I could do with a schematic.
    thanks in advance
  • CapLeaker
    Leaking Member
    • 8193
    Google finds nothing anymore. Staring to wonder why people still use it.
    Anyway, here ya go!
    • zzpkcq@gmail.com
      GT
      • May 2024
      • 12
      • United Kingdom
      Thanks for the reply CapLeaker
      But (there’s always a but) that schematic doesn’t seem right as it has less op-amps and more transistors than the bass version of this amp has. Another clue is this has a gain pot where the one I’m looking for has none.
      tough ask I know that’s why I turned to BadCaps 👍
      • CapLeaker
        Leaking Member
        • 8193
        Post some pictures of your amp and the boards so we can maybe find the correct schematic or something close. Maybe we don't need a schematic. It is just a little guitar amp, nothing too special. Just has a few op amps and a TDA something or other 15W brick. Common issues are broken input solder joints, cold solder joints in general everywhere. Blown primary winding on the transformer (no power), broken trim pots (I think last time I got them from Ali and they fit perfect).
        I think it is based on the TDA2030.
        • zzpkcq@gmail.com
          GT
          • May 2024
          • 12
          • United Kingdom
          Some pics of the board to help identify it
          Anyone suggest what to look at first.
          I've satisfied myself transformer and rectified power is ok and can trace signal input from jack to first component.
          I have multimeter, oscilloscope and bench power supply to help diagnose problems + can solder and unsolder components. So where to look first, schematic would help.
          thanks in advance
          • CapLeaker
            Leaking Member
            • 8193
            First make sure there is nothing in the headphone and the external speaker jack. If the contacts inside aren't up to snuff, there is no audio out. Try a set of headphones and see what you get. Clean those jacks with deoxid and ram a puff in and out all the the time. You can put your scope there to see if there is any audio. IC3 with that metal piece attached is your main amplifying IC. It should be a TDA2030. Make sure it gets power, input sound and output. Download the spec sheet and use your scope. If you have input and no output, the IC is bad,
            I don't know what IC1 and IC4 is.The other three JRC 072D’s are op amps. If you got a negative voltage on the output, it’s bad, you should be seeing stuff on your scope.
            • CapLeaker
              Leaking Member
              • 8193
              While I am unable to find the correct schematic, I did find something similar made by Fender. It will at least tell you how this thing works.
              • CapLeaker
                Leaking Member
                • 8193
                Try this service manual from a Fender Frontman 15B (Bass). This looks awfully like your Squier BP-15. This should do.
                • redwire
                  • 3910
                  OP what really helps is measuring the voltages on the IC pins (without slipping and shorting something out!).
                  If you can measure DCV with the multimeter (-) lead connected to ground, use the (+) probe write these readings down and post them here.
                  At this point, you could even have an open speaker....
                  • eduaqa
                    Amplifier - bad sound when loud sound on bass
                    by eduaqa
                    I'n trying to fix a M&S SYSTEM DMC-1which have following problem:
                    I'm using FM station to do this fix, I works perfect if volume below around 8 or if bass is set to zero, the sound can go to 20 without problem, but if I set bass to maximum and try to go over 10 the sound comes distorted ... I saw a video on YouTube the person saying about the main capacitors on the power portion, but I disconnect the main transformer and inject direct to the capacitors PINs my bench power supply -23v 0v +23v, but still distorted so I think the problem is not the capacitor neither the transformer...
                    08-06-2022, 11:28 AM
                  • ChaosLegionnaire
                    by ChaosLegionnaire
                    09-13-2022, 09:02 AM
                  • Zonzi
                    Telefunken L70 speakers, one has a nasal sound with less bass
                    by Zonzi
                    Hi everyone !
                    Once again I have an issue with old stuff I found for cheap, guess I have a taste for these.
                    I bought these two Telefunken L70 speakers for 20€ (https://www.radiomuseum.org/r/telefu...r_box_l_2.html), and they are in a superb state, component-wise. The box is scratched but I couldn't care less, I'm interested by whether it works or not.
                    They do work, and have a really nice sound, but one of the two has a problem with its 8" woofer. It's got practically no bass, and the mids are really pushed...
                    05-31-2023, 12:34 PM
                  • LEECH666
                    Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                    by LEECH666
                    Good day ladies and gentleman!
                    I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                    This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                    I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                    01-19-2024, 05:46 PM
                  • Christos Tsiligiannis
                    Marian Trace Alpha sound card repair help
                    by Christos Tsiligiannis
                    Hello to the forum.
                    My name is Christos, I am new to the forum here and i am posting from Greece.
                    So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                    To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                    So i tried asking for a schematic from the company and they would not give me one. Instead they...
                    11-18-2024, 05:26 AM
