Soundcraftsmen T6002
  • clearchris
    • Dec 2013
    • 687
    Hello.
    This project has been on the back-burner for maybe two years because it was way out of my skill level. Perhaps it's worth another look.
    Soundcraftsmen T6002 AM / FM Stereo Rackmount Tuner
    This is the most well put together piece of electronics I have opened. Top cover comes off, exposing a very well documented (printed, have no service manual) pcb with lots of jumpers for testing and adjustment. Bottom cover comes off for soldering the underside, while the frame stays in place. Old enough to still be hand-soldered and use proper Pb solder.
    Symptom: When the stereo / mono switch is in stereo position, a fuse will blow. Otherwise, operation is fine. Before I narrowed down the behavior, I completely recapped the power sections. I avoided recapping the rest of the board for alignment issues. Radio probable needs an alignment anyway...
    So, I know the stereo button leads up to the stereo section, and the stereo section drives an LED. Otherwise, I'm not sure of the interaction of the HA12016 chip
    What do you guys think would be the best first steps here?
    1. Obtain a variac and slowly bring up the voltage while checking for a short?
    2. Alignment be damned - replace the caps in the FM Stereo section!
    3. ???
    Picures in next post.
    Thanks!
  • clearchris
    • Dec 2013
    • 687
    Re: Soundcraftsmen T6002
    Whole board view:
    Fuse section. The fuse on the right keeps blowing. Btw, what are the fuse mounts on the left called? I need to add them to the fuses on the right.
    FM stereo section. What are the clear and silver components with the black glue on them?
    • redwire
      • 3912
      That's a nice old beast. Check the power supply +13.7V by C147 is within spec.
      Does the fuse blow if you are tuned to no station, and then hit "stereo"? (=stereo indicator off)
      I've seen a stereo indicator lamp shorted but you have no dial cord...
      I guess pin 9 on HA12016 connects to the fluorescent display. I'm thinking the display has a short, if the fuse pops when it lights.
      The silver parts with black glue are polystyrene capacitors.
      • clearchris
        • Dec 2013
        • 687
        Going off memory here, but IIRC, the fuse would blow within a day of the stereo button being selected. It wasn't immediate. This should be easy to test though, I could remove a jumper that links the FM stereo chip to the VFD.
        • delaware74b
          • Apr 2009
          • 628
          I am seeing a lot of the yellow glue beginning to degrade in your third and last photos. It's turning brown, which does make it conductive. The worst glue I am seeing is at the ends of the ribbon cables and the transformer wires where they are attached.
          I had a bad power supply in a HP EVO DC5100 mini desktop computer. Blew the fuse when plugged in, that yellow glue was brown. The power supply was FULL of glue, everything was covered. Took me 3 hours to get all that @%$ glue off the board and components. Glue removed, power supply was fine so I recapped it and it's been running 24/7 for 2 years as a fire/EMS scanner channel feed to broadcastify.com.
          Stupidity should be a crime, especially for drivers. I have NO patience for them.
          • clearchris
            • Dec 2013
            • 687
            Wow, i hadnt considered that.
            Any thoughts on heating it with hot air then scraping? Maybe soften it up some...
            • delaware74b
              • Apr 2009
              • 628
              I toughed it out and scraped/chipped the glue at room temperature. Probably why it took me so long.
              • clearchris
                • Dec 2013
                • 687
                I accidentally left it on overnight. No fuses blew.
                Today I removed what I'm calling "the glue transistor".
                I used the hot air station ar 120C to heat the glue and it came off relatively easy.
                Ill probably solder the jumper back on and see if it blows any fuses.
                Unfortunately, the test conditions are not the same. I was downtown within a mile or two of most stations, but I moved farther out. So I might not br getting a good enough signal to light the stereo vfd and blow the fuse. Also I notice the alignment is totally hosed, I think the front end needs adjusting.
                • corrize
                  A funny fuse story – Lumix LX100 II
                  by corrize
                  Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                  I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                  The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                  There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                  And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                  10-19-2023, 09:58 AM
                • jesterace
                  Samsung UE46ES8000 Blown fuse but no other signs of short
                  by jesterace
                  Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                  09-11-2024, 03:14 PM
                • jshhh
                  Help replacing fuse on my Mimaki CJV300-160 vinyl printer
                  by jshhh
                  Hi guys,
                  I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
                  How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
                  Anybody know how to remove this type of fuse?
                  (The fuse is toward the bottom of the image labeled F2)...
                  06-17-2025, 01:35 AM
                • Babbar
                  by Babbar
                  04-12-2024, 01:12 AM
                • piernov
                  Reminder: rules and organization of this section
                  by piernov
                  Activity on this forum has been increasing steadily and the workload for the moderation team as well in order to keep the place clean, so please make an effort to keep it organized.
                  I've been deleting more and more posts that make a mess, so take a minute before posting to make sure you make a proper request/offer.
                  Reminder about the rules and the organization of the "Troubleshooting Desktop Motherboards, Graphics Cards, and PC Peripherals" section.
                  This section and its subsections are about the following classes of devices:
                  • Desktop computers
                  • All-in-one
                  03-31-2023, 06:17 AM
