Marantz SX72
  • Evets
    • May 2024
    • 28
    Marantz SX72
    I've acquired a marantz sx72 that doesn't work, looks like the power supply side is a fault but I can't locate a schematic. Does anyone have experience of this model?
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8352
    Post some high resolution, straight shot pictures from top and bottom of that turkey and post them using the attachment function. Maybe we can figure it out and don’t need a schematic.
    • Rictech
      Panasonic SA-MAX770PU SMPSU board fault....
      by Rictech
      Hello everyone. 😀
      As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
      Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
      Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
      This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
      There are no devices that have exploded or otherwise show signs...
      08-26-2024, 01:05 AM
    • ohren
      What problems could this blown cap cause in a Marantz SR5400?
      by ohren
      I'm looking at a vented C513 in a Marantz SR5400 (photo included), in the FR section on page 24 in the service manual (https://audiocircuit.dk/downloads/ma...400-avr-sm.pdf).
      R533 right below it in the photo is charred, but measures the correct value.
      1. I'm not familiar with amplifier circuits (at all — don't know the difference between classes, etc.) so I was wondering what problems would manifest from a supposedly non-operational C513? I didn't hear anything odd when testing the output channel with a speaker. Is there a simple test that can be done...
      10-21-2025, 09:02 AM
    • howardc64
      Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
      by howardc64
      • Prior owner tried a replacement main board. No difference.
      • Samsung 2x red blinking standby LED = panel fault
      • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
      • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
      • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
      07-19-2025, 10:54 PM
      ESR meter came to the rescue again today with a PLC I/O card fault
      I have been having a fun time at work with two pieces of equipment that had shorted components or shorted component cables to machine frame
      I would check what my multi meter was telling me about how many ohms I getting with the multi meter was telling versus the ESR was telling me about weather or not it really was a short to machine ground or not
      One note at first we thought that it might be a bad I/O card or a malfunction PLC including me as well but I thought I would try and see if removing the I/O cables would make a difference or not and this time it did make a difference...
      12-18-2023, 08:17 PM
    • dbuergi
      Any helpful Apple Airpods Max repair tutorials?
      by dbuergi
      title says it all. I have Airpods Max which no charing light. Reset lights show up when i connect a USB charger and push the buttons but not loading or bluetooth reaction. USB meter shows 5v, 0,6a and 1,8-3,2w (differs on used charger).
      The videos i found about repairs are more something like a try and error with changing parts or battery replacement but no direct fault analysis.
      So maybe anybody here has experience in repairs or can help me to locate the problem? My stomach tells me that i need a new battery but 50€ for a feeling is too much.
      07-16-2025, 01:07 AM
