Fisher RS-851 ... No FM, bad amp.
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Well, I bought a Fisher RS-851 as a gamble as I want to replace my dying and annoying Sony stereo that I probably will toss (though it still works, it has mechanical failures: all rubber parts need to be replaced and all the switches need cleaning). I lost the "bet", the Fisher is broken - but no matter, I wonder how bad it is to fix it. I pretty much knew this thing was bad, but did not know how bad.
    Oddly enough there are two things that I can tell are wrong with it. It powers up at least, but FM reception is nonexistent - all I hear is static. Trying to receive AM, I can hear the local stations but the sound is terrible - really scratchy. Feeding in some line-in signals produces the same scratchy sound. The graphic equalizer however seems to sound like it's working but hard to gauge without without some real music samples.
    I am sort of mad because of the multiple failures, I wouldn't be so upset if it had a single failure like if the FM worked and amp didn't or the other way around - but perhaps both issues are one and the same? I hope?
    Anyone with a schematic?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: Fisher RS-851 ... No FM, bad amp.
    It's a bad sign when Google starts pointing to BCN back to my original post
    Anyway this looks like an Sanyo LA1266 (RF/IF mixer) / LA3400 (Detector) / TC9172P (DPLL?) digital tuning system. Now I wonder how the digital PLL is fed back in, all I'm familiar with are varactor diodes used to change capacitance to do tuning, however, PLL you can get the exact frequency you want to mix into IF and the varactor isn't really needed except perhaps for the initial antenna tank circuit tuning...
    Ah analog. I've been doing too much digital *sigh*
    • rievax_60
      • May 2012
      • 897
      • australia
      Try to find the VT rail. It applies tuning voltage to the center pin of the vaicap diodes via resistors, usually 100k. If the voltage on the VT rail increases with increase in tuned frequency, the PLL is working.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        Now the hunt for the varactor diode(s)... Hmm...
        I do see some output on the DPLL in AM but I only have a slow analog scope (20MHz). I'm not sure if it's fast enough to catch intermediate frequency info and/or
        I did notice that the detector output (LA3400) is pure noise, with a small external amp (and a 0.01uF cap to DC-decouple) it sounds just like the noise coming out of the loudspeakers, so yes, the FM radio problem is the RF/IF/PLL/tuning stages Of course that doesn't narrow it down much... The same detector output in AM radio mode sounds like it's working though and does "match" the speaker output. Unfortunately the AM detector and FM detector are unique circuits...
        Need to do some more research on analog tuning PLL circuits, all I've ever looked at is digital PLL clock frequency synthesis. I do wonder how well analog phase detectors work with a sinusoidal VCO versus a square wave digital signal with its harmonics... Might work just fine perhaps? Hmm...
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          The radio board...
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            Hmm. I think the FM VCO is borked. But now I'm not exactly sure why or how it's generated. Probing around the TC9172P, which is most of the PLL guts minus the VCO, I see a related frequency coming in when it's in AM mode on the AM input, but no signal on the FM input. I do wonder if it should be the IF or the actual FM frequency that should be fed in or not, but in either case, it looks kind of dead.
            I'll need to take a back shot of the board to figure out how this is connected... and where the VCO really is... Could it be discrete? Not sure...
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              I found the tuning voltage finally, with the help of a similar RS-911 schematic. This tuning voltage works as expected in AM mode as I can see the voltage go up and down as I tune different stations. When in FM mode, the tuning voltage is stuck at 12+ volts.
              I still think the VCO is borked but I can't imagine how it could have broke. That, and how the VCO actually works... it looks like a tank circuit hooked up to the base of a common collector transistor amp, but doesn't totally look like a Colpitts or Hartley oscillator. Hmm. (and this circuit is underneath the metal shield...)
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                I pulled up the tuner board and suddenly it started working! I don't know if it was perhaps a bad connection or a bad solder joint somewhere. The tuning voltage now works as expected and no longer stuck at 12V. The amp output is still crappy. Oddly enough through headphones it sounds OK... this is a key point because I think the headphones are hooked up to the speaker output with a resistor network.
                I fed the receiver's line output into my computer speakers and it looks like the tuner and mux are working well - so now I have to consider that the amplifier chip is perhaps fried. It does boggle why both channels are not sounding well. One thing I did notice, though the 30W amp uses a STK-4151-II chip, I see the voltage rail at 48V (!) ... The spec sheet says max voltage is 42.5V. I wonder if this is why it fried - it could very well be. I did notice a few STK-4151-V's and even STK-4191 pulls for sale, I wonder if I can swap these in, perhaps the 4191 will survive the higher voltages...
                The PSU for the amp is just a transformer and rectifier - no regulation as far as I can tell so I can't adjust it - and probably doesn't need it if the amplifier was designed to be supply voltage independent up until the signal has to hit the rails...
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  Err...it was already a STK4191-II, so now really unsure why it broke. Oh well. Ordered a STK-4191-V that has a slightly better input stage and lower THD. Hope this fixes this thing other than that FM which I think I narrowed down to a flaky inductor, I can now get it to stop and start working by jiggling it a bit. May need to reflow it to see if it helps, but the solder looks OK...
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    Well, problem solved. My Fisher is now working pretty much perfectly now. I replaced the amp module with the new module. While removing the module I noticed one pin was broken (it was an easy desolder with a vacuum pump, but the pin apparently broke before I removed the module.) The pin was #13... which may explain why the amp was not working properly.
                    Now 50W per channel is a lot more than any of my speakers can handle...
                    • joshnz
                      • Feb 2011
                      • 969
                      • New Zealand
                      very nice
                      My pc
                      CPU : AMD PHENOM II x4 @ 3.5Ghz
                      MB : ASUS M4A89TD PRO USB3
                      RAM : Kingston ValueRAM 16gb DDR3
                      PSU : Cooler Master 850W Silent Pro
                      GPU : ATI Radeon HD 6850
                      • ChaosLegionnaire
                        by ChaosLegionnaire
                        09-13-2022, 09:02 AM
                      • LEECH666
                        Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                        by LEECH666
                        Good day ladies and gentleman!
                        I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                        This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                        I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                        01-19-2024, 05:46 PM
                      • Christos Tsiligiannis
                        Marian Trace Alpha sound card repair help
                        by Christos Tsiligiannis
                        Hello to the forum.
                        My name is Christos, I am new to the forum here and i am posting from Greece.
                        So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                        To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                        So i tried asking for a schematic from the company and they would not give me one. Instead they...
                        11-18-2024, 05:26 AM
                        HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500T Specification for Upgrade or Repair
                        This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                        09-12-2024, 02:30 PM
                        HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500 Specification for Upgrade or Repair
