Peavey PV23XO Crossover Repair and Enhancement
  • clearchris
    • Dec 2013
    • 687
    This crossover was bought new about 12 years ago, and has probably been powered on for at least 3/4 of that time. It also has a recently developed horrible sound on the second channel, sometimes it's a wub-wub-wub, sometimes it's just a hum that comes and goes. It's not noticable if something is playing (it may be gone), but it's quite noticable if there is silence.
    Because of age and problems it's due for a recap. I'm also strongly considering putting in sockets to potentially replace the 12 ST TL072 opamps. For such a small device, it's still going to be over 30 screws to take out the pcb, so while I have it out...
    Does anyone have an opinion on replacing the TL072 opamps? From my research, the TL072 are very common, and also very commonly hated. However, they aren't always easy to replace because they are JFET.
    Also, anything else that should be replaced while I'm in there? I think the film caps should still be good, pots are nice and smooth, resistors have no discoloration.
    Thanks!
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8352
    I just would replace all electrolytic capacitors, check for (potentially) bad solder joints, take a few measurements, clean the sucker (clean and lube switches and pots) and put it back together. If it is something important that needs to be fixed, I take pictures and have spares on hand, Would I go as far and socket now all the JFET's simply because I am there now? No. It ran for a long time already.
    It all depends on how important this amp is. I've got a few amps in a commercial application and I do have a spare amp and spare parts.
    • clearchris
      • Dec 2013
      • 687
      It's actually the youngest, cleanest piece of equipment in my rack aside from the raspberry pi. šŸ˜‚ Non smoking house, and the box is pretty well sealed. Kind of surprised it needs a repair already.
      Everything looks hand soldered, so you have a good point about checking solder joints. I hadn't expected this to be a hand soldered, through hole board, but it is (and that's a good thing imho). I'll see what's under there after I take out the 30 screws...
      Thank you!
      • clearchris
        • Dec 2013
        • 687
        In case anyone wants to do a recap, here's a listing of the caps in my Peavey PV23XO Crossover. My stock didn't quite cover me, I had to put an order in, so I don't have results yet.
        Code:
        6x  10uf  50v
        10x 22uf  25v
        2x  47uf  25v
        2x  100uf 16v
        2x  470uf 35v​
          • Jul 2011
          • 6070
          Code:
          6x 10uf 50v
          10x 22uf 25v
          2x 47uf 25v
          These capacitor values are prone to failure because of the value and there physical size especially in switching power supply and if see these values I replace them on site even sometimes if they are brand name capacitors especially if the device is giving trouble just to rule out the possibility that this is issue
          • clearchris
            • Dec 2013
            • 687
            Yeah, I replaced all of them with higher voltage rated caps, turns out one of the TL072CN opamps is gone, or at least that's what I suspect. The pots feel buttery smooth, and the distortion doesn't sound pot induced. I added DIP sockets yesterday, haven't gotten a chance to swap some opamps to different sockets and test to confirm my suspicion.
            My dillema now is, since the TL072CN is obsolete, what do I replace it with? In further research I have found that people speak highly of the TL072ACP, but there are a few different values that concern me, particularly output current per channel going from 40ma with the tl072cn to 10ma with the TL072ACP. Thoughts? Spec comparision below.
            • 30Cal
              Peavey SP5 Speaker Crossover.
              by 30Cal
              Greetings. Having an issue with extremely low output to tweeter. Replaced driver and fuze. As far as I can tell every component has relatively low ohms and no opens. I only use the speakon connection. Woofer operation is OK. Tried tweeter on woofer connection and sounded fine. Jumped the resetting fuze, no difference.
              Considering speakers are 20+ years old (MADE IN USA) and been through hell and back I really can not complain.
              Redid a few years back with Eagles influence.
              Any information would be greatly appreciated.
              Thank you for your time.
              09-07-2025, 03:53 PM
            • Sinnyone
              Recapping a Cerwin Vega Crossover help
              by Sinnyone
              I have included a few pics of the caps on my crossovers on a pair of Cerwin Vega 311p speakers. They are well over 40 years old, so I thought new caps might help with their sound, and would be fun also. So, I have attached pics of the caps, but was wondering. Is it better to replace the caps, what caps would be best, and should I just buy a new crossover at parts express or something like that. The problem wikth buying a whole new crossover is i dont know where these particular speaker drivers fall off or which crossover to get. Im good at electrical work and soldering so no problem...
              08-11-2022, 12:36 PM
            • PennyLane
              Trying to locate a capacitor for a Skytec Crossover filter
              by PennyLane
              Hi
              I'm trying to locate what i believe to be Radial Electrolytic Capacitors 100v 82uf Non-polar for a Skytec Crossover filter.
              02-19-2025, 06:47 AM
            • UL161
              Need Help Identifying Parts on a crossover and a few other newbie questions
              by UL161
              Hi I am trying to refurbish this crossover with some higher quality poly-caps/parts... The speaker is a in-wall Polk 65-RT... Key questions I have are:
              1) What in the world is the yellow part on the board (label is MET 1.0J 100V)?... Should I even consider replacing it?
              2) The 470uF cap.... Does anyone know have a suggestion as to where I can find a reasonable audio quality polycap near that value? (or at least 3 160s or the like?) { I don't want to spend $70 just to replace this one if I can) (maybe even someone looking at this circuit could even tell if this cap is important...
              09-29-2024, 03:17 PM
            • diazald
              Searching for a Peavey XRs schematic
              by diazald
              Searching for a Peavey XRs Schematic. A SMD capacitor with no values cracked on me. I have searched off and on for months with no luck.
              Any help would be greatly appreciated
              11-24-2023, 02:49 AM
