California Electronics pro-8800a digital amplifier stereo
Nah, don't bother. It will work just fine. UNLESS the new ones are smaller (different wattage rating).Leave a comment:
So is better to find the identical resistor right..?thanksLeave a comment:
The difference between them both are that the tolerance of the old one is 5% vs 1% on the new ones. As long a the physical size is the same, the watt rating is the same. The blue resistor are metal film, the old one carbon film.Leave a comment:
Thanks man I didn't realise that was different band. Dammed I made mistake 🙄 but when I place the order I selected 4.7 R as you can see it's marked on it by penn.. my question is why on the board say 4.7R and I received different line of resistors... Maybe change the wat on it?? But I didn't know the wat ... 🤔 i add some pictures .. thank you again man...4 PhotosLeave a comment:
Just 4 band colour code vs 5 band. If I decode the blue 5 band resistor I get to 4.6 or 4.7 Ohm. Can’t distinguish on the second band being blue or violet.Leave a comment:
I guys I found the button ,but I found also a burn resistance, then I ordered it with the number on the board, it's arrived but it very different .. Someone can explain if I made mistake..? I really appreciate thank you all for the reply 🙏2 PhotosLeave a comment:
Hi guys my friend gives to me this thing, it works but the selector on of music is broken , I tried to do some research on Internet to change it but I didn't find anything. I hope that someone can help me to find it thanks all for the reply5 PhotosTags: None
by Sik_6ty_SixxSo like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...5 Photos
by HypersapienHowdy folks! I'm an artist in the video game industry, and my job entails making a lot of mechanical and sci fi assets. I thought it might be a good practice to start disassembling some electronics to be more familiar with how real electronics are manufactured and assembled, which is how i found my way to these forums.
When I started researching what tools I might need, I quickly encountered the warning "Some devices can maintain a potentially lethal charge in their capacitors, even up to years after last being powered on", which was enough of a scary thought for me to... -
by BOSCHNJAKABOUT ME INTRODUCTION FILE
2024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
2022 BEV, PROJECT ?
2021 BEV, PROJECT ?
2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIÄŚNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...-
Channel: Visitor Messages
12-28-2023, 02:09 PM -
by FuzzyOwlHi, I have a Denon AVR-X3600H I'm trying to repair. I have no electronics repair experience but I have a multimeter, service manual and a will to fix it (https://device.report/m/d5de8c00e617...f63147aba9.pdf)
Everything seems to work except for no sound even through the pre outs. However I will get sound using Zone 2 pre outs.
Only digital symptom I can tell is it will soft lock when in the Speakers/Test Tone menu and be unable to adjust +/- db during the test tone.
I've followed the trouble shooting guide, audio check...1 Photo-
by abajorI'm about to take a journey into repairing this 3 Channel ICE amp. It's got a bunch of fun components I am not familiar with like Direct Stream Digital chips. It also has some onboard Digital Signal Processor which I haven't identified yet.
I am not familiar with ICE amp circuits other than they are a type of PWM amplifier so I'm assuming they require a ton of high frequency filtering on the output. I'm also assuming that the output of the DSD chips probably directly feed the ICE amp signal since DSD is also essentially PWM or creating an averaged AC signal using high frequency ~2MHz...-
- Loading...
