California Electronics pro-8800a digital amplifier stereo
  • petehall347
    replied
    yes replace with same . also be sure the bias tracking tracking transistors are good .
  • labello
    replied
    this one here .. and what is that silvery mess in the other pic ?
    Hi don't worry it's just dirty, anyway thanks for the reply, I found those cable almost broken then I resolder them, but in one side the resistor doesn't getting hot anymore, then in the other side blown up another resistor and two transistor in the heatsink circled red on picture, now they are different, 2 marks on it TOSHIBA 2SA1943 and the others are TOSHIBA 2SC500 . Can I replaced all whit the same mark or i must replaced different like they are now? Thanks for the reply 👍
  • labello
    replied
    Originally posted by R_J
  • R_J
    replied
  • petehall347
    replied
    Originally posted by labello
    Hold on you just know Where's the problem?( i see what might be a burned capacitor next to a driver transistor) how can you know that through a picture ..? Really...
  • labello
    replied
    what is getting hot ?
    looking at the pics i see what might be a burned capacitor next to a driver transistor .
    have you measured dc voltages at the speaker outs ? and also the voltages across the low ohm emitter resistors next to the outputs ?
  • labello
    replied
    Hi, thanks for the reply, the resistor that I marked with arrow yellow, then I changed both transistor red colour but nothing changed (also I changed also that resistor still getting hot about 100/150 degrees. No i didn't take measurements, I just go ahead with testing transistor mosfet on the heatsink...
  • petehall347
    replied
  • labello
    replied
    is it possible the input is too hot ?
    do any vol controls work ?
    Hi that's right! But if can't find what cause this problem, I mean I already checked all of transistor out of circuit with a peak meter and those are good... So what components can cause the resistor getting hot! There's schematic board for this model? Or it's too holder?? Thanks all of you foto the reply
  • labello
    replied
    Guys I just received the thermal camera, finally I've been waiting for a month. Anyway there's something that get really hot!! See Guys
  • labello
    replied
    Hi, I really don't know, I only change a little capacitor (blown up) and a resistor (a little big than the original one) in the front pannel I replaced the little bottoms (on off) ..
  • labello
    replied
    maybe something is wrong with the volume knob itself?
    Hi, at the front pannel anything control volume or mixer work, except the large bottom on/off
  • petehall347
    replied
  • CapLeaker
    replied
    Yes I can't , i turn the bottom down but it still very high
  • labello
    replied
    What do you mean? You can't turn down the volume?
  • CapLeaker
    replied
    Hi the problem is when the amplifier turn on the volume is very heavy I tried to turn it down but it remains higher. Thank you
  • labello
    replied
    Nah, don't bother. It will work just fine. UNLESS the new ones are smaller (different wattage rating).
  • petehall347
    replied
    resistors dont burn for no reason
  • labello
    replied
    you need to see how many transistors are damaged and replace or you will keep burning up resistors .
    Thanks man I will check you can be sure but the amplifier was okay..
  • petehall347
    replied
