I have an RX-V2400 and another RX-V I can’t remember the model number at the moment. Both have very dim VFD displays. Both have been factory reset with no change. This seems like a common issue. Lots of talk about possible bad caps but I’ve never actually heard of anyone fixing the problem. Is it just bad caps or something else? Thanks!
Dim displays on Yamaha RX-V receivers
by jjneI have an old Yamaha RX V675 receiver which is starting to develop issues with the sound, although it doesn't quite match up with what folk normally report with these.
From cold, the sound cuts in and out. When this happens the amp is losing sync with the optical input (speaker graphic disappears from the front panel). But this is not resolved by putting the unit into pure direct mode. After a couple of minutes this resolves, although there are occasional clicks from the speakers after that.
At first I thought it was either a speaker relay or the DSP, but I don't think...-
by AlexVGHi.
I have an old YAMAHA CLP-550 without sound. (Some times I can get some kind of noise or distorted sound)
I have replaced all green marked elements, but it gave me nothing.
The IC12 chip LC9116A-105 (red marked) remains under suspicion yet.
But it is custom YAMAHA's chip, and I can't find any information about it.
Maybe somebody came across with the same issue?
Any information will be very useful. I will be very appreciated.
Thank you....-
by ashr88Hello, I have an Lenovo Thinkpad E590.
It displays the bios splash screen then displays the following error and turns off.
"BAD CRC of Security Settings in EFI variable"
Bad SVP Data, stop POST task....1 Photo -
My friends Yamaha RXv-485 receiver has stopped communicating on network and Bluetooth, we decided to make a firmware update from USB stick but after a while it comes up with the message "unknown".... Its the latest 1.87 version we are trying to load and it seems like the is no firmware in it at the moment as it does not state the old version ?
Any ideas how to resolve this issue?-
by hemant_2222Hello Guys,
Greetings!
Hope you all are doing well.
I am looking for suggestion on Yamaha 2064. The problem with this receiver is that it has no sound however when the test tones are activated it does outputs from all the speakers. It is working in two channel stereo mode but when you select other sound modes, it doesn't. The last time it had a problem, I had replaced the DAC
PCM1681DBQR - IC263 and it worked fine.
Other issue with it is one of the STK ICs is getting more heated then the other one but that can be looked at later.
- Loading...
