Onkyo TX-NR616 won't stay powered on
  • tibimakai
    replied
    Re: Onkyo TX-NR616 won't stay powered on
    Yes I can confirm now that there is no video on any of the video outputs.
    I have tried HDMI, component and composite. TV recognizes that there is something connected at that output, but there is no signal found.
    The audio is working.
  • tibimakai
    replied
    I have re installed the finals, placed two multimeters at the bases and turned it on.
    Did not replaced the emitter resistors.
    I have turned it on briefly and I have seen around 0.5Vs and then I turned it on and left it on.
    To my surprise, it was working and those voltages were exactly the same, 0.59V.
    So, the unit it's working. The only problem I'm having, is that I can't get video signal to my monitor. I will have to try it out on a TV.
    Thank you very much for all your amazing help.
    I still don't know what caused the blow, but the final result matters.
  • rievax_60
    replied
    Originally posted by tibimakai
    The bases shouldn't have the same voltage, as the good channel? It doesn't seem balanced to me.
    The feedback loop acts to control the point that its sensing, to zero volts.
    there is no true center point to connect to in the output's driver stage.
    It is the voltage difference at the finals' Bases that's more important.
  • rievax_60
    replied
    These resistors should have a high wattage?
    High wattage would be best but maybe difficult to fit. Small resistors will be ok while there is no faults. The small resistors should also allow the amp to be run at very low volume into speakers, too loud will burn them out.
    The main reason is to protect the finals while one last check is done on the bias.
    Have you noticed and design differences compared to the schematic? Is R5476 really 82 ohms?
  • tibimakai
    replied
    Originally posted by rievax_60
    Did you check the bias transistors for cracked solder joints?
    Not yet, I have to take apart the whole receiver for that.
    Next step, it will be that and re-installing the finals and maybe those emitter resistors.
  • tibimakai
    replied
    All you can do now is fit the finals. If you want to take one more precaution, temporarily replace the emitter resistors with something from 10 to 100 ohms, then take some more voltage readings.
  • tibimakai
    replied
  • rievax_60
    replied
    I just spotted something that bothers me. If the bias adj pot, R5445, develops poor wiper contact, the bias voltage will abruptly increase. Bias circuits are usually designed to be fail safe. If the pot fails, the bias reduces.
    This can be checked by measuring between the final bases while adjusting the bias pot. The voltage should vary smoothly, not be jumpy. Leave it set to 1v for now.
    A drop lite oil like sewing machine oil makes pots work better.
  • rievax_60
    replied
    At a good channel, at both bases similar to Q5436/Q5446 I'm, getting exactly +/-1.24V.
    At the same channel at the final's bases, I'm getting exactly +/-0.53V.
    That channel is perfectly balanced.
    I have removed the link and the voltages at the Q5446/Q5436 bases and the final's bases jump up to around 20-24V.
    Not good.
    When you remove the link, the feedback path becomes open, look where R5036 goes to.
    It all should be ok when you fit the finals. But we still dont know why the last pair failed. All you can do now is fit the finals. If you want to take one more precaution, temporarily replace the emitter resistors with something from 10 to 100 ohms, then take some more voltage readings.
  • tibimakai
    replied
    Not good.
  • tibimakai
    replied
    At the Q6066 base is -0.001V and at the Q6056 there is 1.2V with the resistor removed and link left there.
    The other voltages did not change.(-0.64V and the 1.8V)
    I will continue later.
  • rievax_60
    replied
    That is -.064V you are right, forgot to put it there.
    I didn't had to much time today, to measure at the finals.
    I have to solder two wires at pin#2 and #3 at the connector, to be able to measure those base voltages.
    I still leave the link and resistor in place, right?
    I hope I didn't do something stupid and that is why it blew those parts.
    I appreciate a lot your help. I'm new in this field. I have repaired three Harman Kardon AVR1700 with Tom's help an Onkyo with your help(transformer fuse) and now this Onkyo.
    I have picked up a Yamaha HTR-4065 and tomorrow I'm picking up a Pioneer VSX1022-k.
    The Yamaha seems dead, only the power button blinks a couple of times and even that blinking goes away.
    Transformer doesn't get 120V. I will start another thread with these receivers.
    Leave the link in for now.
    Remove the 1K resistor, its job was to prevent the bias voltage going too high if there was a fault in the bias circuit. Confirm that the bias voltage has not changed by much.
    There still could be an intermittent fault in the bias circuit. Check Q6006 , Q5446 and associated components for fractured solder joints.
    Ill wait until you have measured the bias voltage on the good channel then you will have to fit the finals. A precaution can be taken by temporarily replacing the emitter resistor with something higher in value to protect the finals incase there is still something wrong. The link will need to be removed.
  • tibimakai
    replied
  • rievax_60
    replied
    OK, at the Q5436 base I have 1.8V and the other only 0.64V.
    I'm not sure how to measure another channel? As is, or I have to place the same link with the resistor there also?
    Those voltages would be close to correct if the 0.64 was really -0.64v
    I would like to have seen the voltages that would be going to the Bases of the finals also.
    So far I dont see a strong reason for the last set of finals failing.
    The 2.4v between the Bases of Q5446 and Q5436 is higher than the 2v I calculate it should be.
    Measure this voltage on the good channel. There is no need to modify anything on the good channel
  • tibimakai
    replied
  • rievax_60
    replied
    If the voltages at the bases of Q5446 and Q5436 look ok. The next thing to measure are the voltages that would be applied to the bases of the finals.
  • rievax_60
    replied
    What we have discussed here.
    Today I had a little bit of time and I did what you have told me. Removed the link and added a 1k resistor.
    I wasn't sure about the other link, so I have removed it. Should I put it back?
    Yes, you should have left the other link in.
  • tibimakai
    replied
  • rievax_60
    replied
    I got you to fit two links originally. What have you done since?
  • tibimakai
    replied
    Yes, I have removed it and soldered in that 1K resistor.
    Should I solder back that link?
  • Hannibal_Hector
    Samsung UN39EH5003FXZA won't stay powered off
    by Hannibal_Hector
    Purchased a broken Samsung UN39EH5003FXZA (Version CD01) to have fun fixing. When I first acquired it, I did not connect any video signals and only plugged it into the wall. The unit booted and showed the “no signal” window and I could navigate all menus and change sources. I unplugged it, connected my over-the-air antenna to the coax, powered it on, got the unit to scan the HDTV channels, and I think then the TV self-shutdown with the melody. When I powered back up (melody), it would show the channel selected on the OSD and after a couple of seconds, it self-shutdown...
    03-02-2021, 07:57 PM
  • cmlewis89
    LG 47LB5DF blown power supply board
    by cmlewis89
    Hi folks,
    I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
    09-03-2024, 07:50 PM
  • beetle1303
    Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
    by beetle1303
    I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
    On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
    01-13-2025, 08:49 PM
  • drscoot
    HP X360 convertible battery blown fuse error, not charging
    by drscoot
    HP Modelnumber: 14-dh0061nb​
    This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
    The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
    I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
    And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
    All these 3 batteries are charging...
    12-15-2023, 05:54 AM
  • swerg
    Part selection for possible blown inductor on ASUS GX531-GW-AB76 laptop mobo
    by swerg
    Hey everyone,
    I'm a novice trying to repair my laptop. The LCD screen has an image, but no LED backlight for the image. It also produces an image when connected to an external monitor.
    I have found what I believe to be a blown inductor labeled "L4502" and "120 Ohm" in the schematics (zoomed in image, blue arrow to blown component). I have included an image of the general area of the mobo and an excerpt from the schematics as well.
    I am having trouble selecting a replacement component, which I believe to be a 120 Ohm ferrite bead, from the components...
    06-06-2024, 03:39 PM
