Recapping an old pioneer amp
  • patra710
    • Sep 2009
    • 9
    Hi I am trying to recap a pioneer sa-6700 amp that was made in the 70's.
    I watch a few guys on youtube do this and they talk about different brands and series of caps in the audio and power circuits. I am a little confuse at what type to use. Any advice would be welcomed. Thanks
  • kaboom
    "Oh, Grouchy!"
    • Jan 2011
    • 2507
    Re: Recapping an old pioneer amp
    Don't pay any attention to such nonsense as "the caps change the sound." Ignore it. After 35+ years, the only way new caps would change the sound is by improving it. And keeping DC leakage between stages to non-existent levels, being much nicer to power transistors and other active devices.
    Panasonic FC, FM, FR, Nichicon PW, HE, PM, which even though low-esr, are just fine in hotter areas of an amp.
    Only in cooler places would I use 85 degree GP caps. And only for reasons of longevity, not "sound quality." For example, stand-alone tuners, tape decks, some CD players.
    Rubycons are also good, but I don't have series info at the moment.
    You've probably got large snap-in or can caps in the power supply.
    Replace any 2sc458 small-signal transistors- most all of them are noisy by now. Common subs are 2sc/ksc1815 or 2sc/ksc945, with 1815 preferred.
    "pokemon go... to hell!"
    EOL it...
    All style and no substance.
    guilty,guilty,guilty,guilty!
    guilty of being cheap-made!
    • redwire
      • Dec 2010
      • 3912
      Electrolytics with high ESR (above 10kHz) do colour sound in a bad way.
      The series kaboom mentioned are fine. The FC's are good enough. Avoid the overpriced audio-only electrolytics with silk dielectric filler and such, like the Nichicon Muse KZ, Blackgates etc.- they are about psychoacoustics and wasting cash.
      • kaboom
        "Oh, Grouchy!"
        • Jan 2011
        • 2507
        Because they're bad and need to go.
        Here's something I found a while ago:
        http://www.roger-russell.com/truth/truth.htm
        http://www.roger-russell.com/wire/wire.htm
        EOL it...
        • rhomanski
          nowhere man
          • 5157
          • U S of A
          I've done a lot of vintage 70's amps. What I use are two kinds, Nichicon PW series and Nichicon KL series. The general rule of thumb I use, if it's orange or sky blue or even tantalum, replace with KL series. Everything else use PW. PW are almost all 20% and 105degrees. KW can be found in 10% with 105 degrees. Mouser electronics has just about any size you need. The amp will sound new when your done.
          Don't forget to look for the bad transistors 725's, 726's, and 1313's. You should replace the thermal grease too while you are in there.
          sigpicThe Sky Is Falling
          • patra710
            • Sep 2009
            • 9
            Thanks for the repleys. This is my first attempt at rebuilding an old amp. I have 8 old pioneer and kenwood recievers that I want to do. This pioneer sa-6700 look like the easiest one to start. I will take your advice and hopefully do it right.
            • kaboom
              "Oh, Grouchy!"
              • Jan 2011
              • 2507
              Service manual attached.
              Edit- If the leads on the STV3s are corroded, they can be replaced with 3 1N4004s in series.
              If the STV3s should ever open, full bias will be applied to the output transistors, which will die trying to "short out" the power supply.
              Something to beware of.
              That Pioneer is a nice one to start with- have fun!
              EOL it...
              • rhomanski
                nowhere man
                • 5157
                • U S of A
                As Kaboom mentioned, the STV-3's deserve special handling. Usually they are held on the heat sinks by a screw with thin wires going to the circuit board. The wires are very fragile and like to break right at the body of the diode. The diode itself is very fragile and can be broken if the screw is overtightened. They are no longer made and the only way to get another is from a donor unit.
                If you wish to study up on it, AudioKarma is a good website for rebuilding these. Joining is free and you can search the Pioneer forum for tips and tricks. The old units are a lot alike, although each brand has it's own problem areas. You can read about other types of units and still learn a lot about yours.
                For the big power capacitors, I usually use Panasonic THA's. I end up going up in voltage to get the same physical size. If it comes with a 63V, I'll put in an 80V and it usually comes out right. You can get them from Digikey.
                • Logistics
                  • Apr 2007
                  • 721
                  If the main power caps are snap-in then I would replace with Panasonic TS-ED's.
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    seems i have seen a few with sonybond rot the leads off.
                    POOF!if you do the 3 1n400x be sure all 3 are in contact with the heatsink!that way the bias tracks temp.a bit of thermal compound for good measure.
                    • ChaosLegionnaire
                      by ChaosLegionnaire
                      09-13-2022, 09:02 AM
                    • LEECH666
                      Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                      by LEECH666
                      Good day ladies and gentleman!
                      I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                      This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                      I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                      01-19-2024, 05:46 PM
                    • Jaxxon0121
                      Pioneer PDP 436 SXE Strange Sound
                      by Jaxxon0121
                      Hi all, im new here and a complete novice with electronic repair so please bear with me. The problem i have is with my Pioneer PDP 436 SXE TV 43' plasma tv. Its recently started making a strange clicking/popping/electrical sound that is very loud and annoying. The tv works fine other than that. The sound doesnt happen straight away. After around 10 minuets of use, usually when the screen turns black on a tv program or if i exit a youtube video and the scrren goes black for a split second, that is when the sound begins and then doesnt stop at all until the tv is unplugged. The sound is coming from...
                      04-30-2021, 08:47 AM
                    • Christos Tsiligiannis
                      Marian Trace Alpha sound card repair help
                      by Christos Tsiligiannis
                      Hello to the forum.
                      My name is Christos, I am new to the forum here and i am posting from Greece.
                      So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                      To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                      So i tried asking for a schematic from the company and they would not give me one. Instead they...
                      11-18-2024, 05:26 AM
                      HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500 Specification for Upgrade or Repair
                      This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                      09-12-2024, 02:30 PM
