ASHLY LX-308B line noise (and noisy mic channels)
  • theokretes
    • Jul 2013
    • 49
    So the main mixer I like to use is an ASHLY LX-308B. It worked great, except the following:
    #1 the first two channels (which were also mic channels), had awful white noise hissing constantly.
    #2 there was a general line hum that was annoying (and yes I followed all of the precaution, all devices run into an 8-port ISOBAR).
    #3 the bass response could be better.
    Well upon cracking the thing open, I saw what the problem was. It uses 100uF *chemicon* GP decouplers. 100uF is a pretty dinky amount, and chemicons are some of the flattest sounding capacitors-- they're great for motherboards and power supplies, but NOT audio circuits. Yuck!
    Obviously the Ashly engineers didn't have experience with the way different capacitor brands and series behave.
    Here's a picture of the dinky chemicons (it's so pathetic looking):
    You'll also notice some other random cheap chinese caps between the brown chemicons. barf-o-rama.
    So since I had some 220uF RX30s and 10uF RE3 ELNA caps, I popped them in:
    Ahhh much better. I bent them in that pattern to look more tidy.
    I also did the same for the main output:
    You'll note the VERY nice chemicons on the power supply.
    After the recapping, the white noise on the first two channels is gone. The hum has been silenced by 80%. And the bass response is better.
    ALL FIXED!
    (I also changed some LEDs, but that's minor, I thought the power LED should be red instead of blue)
  • tony359
    by tony359
    11-28-2023, 05:18 AM
  • MegaZAC
    Onkyo TX-SR805 noise in one channel
    by MegaZAC
    Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
    Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
    There's some logic behind it. As soon as I select an input I get only left...
    04-23-2025, 10:09 PM
  • Francesc V.
    Rotel RSX-1056 amplifier. Troubleshoot a noisy channel
    by Francesc V.
    Hi:
    I've realized that one of the channels of this amplifier has no proper sound.
    This is the signal at the speakers output.
    As long as the audio coming in to the amplifier board (blue) looks ok although with some noise due to the wire, I think that there's nothing to look at the preamp section.
    Now, I could start looking at components to see whether I find the guilty one.......but I would rather prefer to ask for advice. Here there is the amp. schema. Which points would you check with the oscilloscope to gather...
    07-15-2025, 01:33 AM
  • r2digital
    Harmon Kardon AVR340 no sound on 4 channels
    by r2digital
    Hello, i had this amp sitting in the closet knowing that none of the channels were working. After taking it all apart i found 4 bulging main filter caps so i went ahead and replaced those with low ESR kmet caps. However after doing this it only restored sound to Surround L, Surround R, and Center channel. The main speaker fuse on the transformer F905/F906 keeps blowing so i decided to remove all of the transistor's on those 4 channels and measure them. All transistors appear to be in good working order(turned receiver on with none of them installed and fuse still blows). Checked dual emitter resistors...
    03-09-2024, 01:33 PM
  • jason123
    Agilent 33220A 20 MHz Function Generator
    by jason123
    I can't find a forum to discuss "instrumentation Troubleshooting", but PS maybe the closest.
    So, I'm having an issue with about 13 year old Agilent Function Generator. it works, passes self-test, but it has an annoying "audible" noise, that changes as I change the output frequency setting of the instrument. Prominent around 600 Hz and up (at least that's what my ears are picking up.) I saw on some forms that it could be fan, linear regulator, dried up caps,... I can't seem to find the source of audible noise. Here is what I tried:
    1. Turn the output off - still...
    07-01-2025, 08:12 AM
