Yamaha RX-V459DAB not powering up
    Just fixed this amp.
    Same fault as many other RX-V amps, bad 22nF/630V capacitor on standby circuit.
    Will have a video up soon.
    Re: Yamaha RX-V459DAB not powering up
    https://www.youtube.com/watch?v=J42wDUzgx7s
    • bialag
      Lenovo ThinkPad E14 Gen 5 - Not Powering On - 3 Blinking Lights - 20 volts 0.224 amps
      by bialag
      I have a Lenovo here that does not want to power on. The motherboard appears to be clean, no sign of corrosion or obvious fried components. When plugged in, I see 3 blinking lights and then off. It would cycle the 3 blinking lights every 10 seconds or so as long as I have the adapter plugged in. Amp meter shows 20 volts, 0.224 amps, no fan spin, red light indicator near the charge port.
      Thermal camera shows a section of the motherboard that is warmer than the rest. It is near the connector labels JRTC1 (CMOS battery). Diode measurement to ground for pin 1 = OL,...
      03-25-2025, 05:56 PM
    • Rupsenkind
      Yamaha RX-V373 not powering up
      by Rupsenkind
      I've a Yamaha RX-V373 which does not power up, only main relay clicks and then falls back, already checked the following:
      - DIAG or Advanced menu does not work
      - All relevant sub voltages are available (5-7-12V)
      - According to the SM,IC's 268-262 and 261 should give 1.3V, 1.2V and 3.3V but at all I measure around 7V at pin 1 (so output voltage is equal to input voltage 7V)
      - As a try I swapped IC-262 for a new one but still measuring 7V output.
      - As these 1.3,1.2 and 3.3V voltages are feeding processors (a.o. uP and DSP) I assume this is...
      10-18-2022, 10:27 AM
    • Stephen
      A2991 Logic Board issue, 20volts 0 amps help!
      by Stephen
      Customer plugged in samsung monitor into the board and used it as a power supply, killed UG800 and UG400. I replaced those two with an exact donor board we had In stock and working, board pulls 5volts and then gets like 2.89 amps on the left side. The singular port is the port that failed. Used a perfectly working chips from donor (board was locked) Now I only get 5volts 0 amps on that power and then 20volts 0 amps on the two left side ports, I checked for DFU and nope nothing, computer not turning on. No shorts present anymore. I am confused as I used the exact components from an identical...
      09-10-2025, 03:16 PM
    • Stephen
      A2991 logic board issue, 20volts 0 amps help!
      by Stephen
      09-10-2025, 03:15 PM
    • sanalelevenstar
      Yamaha RX-V485 Wn9711 Update
      by sanalelevenstar
      Help Needed: Yamaha RX-V485 Network Issue After Firmware Update (WN9711 Error)
      I'm facing an issue with my Yamaha RX-V485 receiver. During a firmware update, the process failed, and now the USB, Bluetooth, and network functionalities are not working. Occasionally, the receiver displays the error code WN9711.
      I came across Yamaha Technical Bulletin No. 0103, which describes a similar issue for models like the RX-V4A, RX-V6A, and RX-A2A. According to the bulletin, the issue can be resolved by shorting soldering points (e.g., J260 for RX-V4A or...
      12-04-2024, 04:32 AM
