Sony 5disc player and disc recorder RCD-W500C
  • jose6326
    • May 2013
    • 707
    I am having an issue with the recorder/burner side of this unit
    I was able to connect my phone to the unit via the analog input jacks and burn music to blank discs
    Now it does not want to work
    I can still play music thru the the same ports but can not record
    Also the digital optical ports do not light up as well
    All caps are physically ok there is no ruptures or bulging
    What would be the first steps to diagnose?
  • redwire
    • 3912
    Re: Sony 5disc player and disc recorder RCD-W500C
    I checked and found the service manual for a Sony RCD-W500C; it's about 10.1MB
    The player has a test (diagnostic) mode to help troubleshoot what it's doing.
    I would try that. It's kinda cool, it will tell you laser burn power, and you can connect to a PC with a special serial cable for alignment.
    Generally, I find dirty lenses, bad spindle motors, and alignment/laser problems.
    Sony does silly things like have IC440 run hot so it fails... and it's a TA7807
    One thing to check would be the power supply voltages with the unit running.
    It should have optical out working during playback, though.
    • jose6326
      • May 2013
      • 707
      redwire
      thanks for the help
      but the unit actually works
      my dumb ass friend does not know how to use this unit
      i posted this for him so i can try to fix it
      i told him to bring in all the cables and phone to show me how he hooks it up and to show me the problem
      well when he connected everything and pressed record it was not recording
      reason being is that he never pressed the "input" button on the front of the unit
      now it records with no problem
      the only issue i did find with the unit is that the 5disc tray is not opening, it does not move up and down correctly, it looks kind of misaligned
      and you are right the digital optical "out" does light up
      thanks again
      • ahmedtou
        HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
        by ahmedtou
        help me please
        I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
        When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
        I will share all the details with you, including the disc information.
        Code:
        HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
        Current Profile: BD-R
        Disc Information:
        Status: Empty
        State of Last Session: Empty
        Erasable: No
        Free Sectors: 12,219,392
        Free Space: 25,025,314,816 bytes
        Free Time: 2715:27:17 (MM:SS:FF)
        Next
        08-27-2025, 08:49 AM
      • bogosort
        Sony DVD player stuck tray (DVP-SR310P)
        by bogosort
        I have a Sony DVD player with a stuck tray. It seems that moving or pressing on the tray makes it work.
        Anyone knows why?
        Thank you....
        05-11-2024, 04:29 PM
      • Junior††
        PS5 Disc Not Supported/ Disc Not Recognized Board Num: EDM-020
        by Junior††
        Good Afternoon fellas,
        Issue:
        Disc is showing as not supported when a disc is put in.
        Here's what I've done, you can skip this if you just wanna know the question:
        - replaced with a disc drive from a donor ps5 (honestly questionable if this is known to work)
        - reflowed the disc drive connector
        -reflowed the chip in question (shown on image)
        - I will say this console was very dusty so it's conceivable that it got so hot that it made the chip joints cold and potentially other things on the board
        Question:
        I...
        02-19-2025, 12:48 PM
      • Carlos#2003%
        Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
        by Carlos#2003%
        Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
        02-15-2024, 07:52 PM
      • mikey5791
        Sony CFS-5000S radio cassette player no FM reception
        by mikey5791
        Hi forum members,
        In the past i have had many helpful hints from generous forum members in diagnosing and solving issue related to most of my electrical things.
        Fyi, i have been keeping this unit of Sony radio cassette player as the cassette belting has worn off but the radio has been working fine before. Recently, out of a sudden i found out i can't get any radio reception at all (no signal from FM,MW or SW band) except some buzzing warp noise from the speakers.
        I opened the casing inside and checked for any dry solder, burned component or loose wires...
        02-24-2023, 03:48 AM
