Harman Kardon AVR1700 won't power up
    Re: Harman Kardon AVR1700 won't power up
    Do you still have that Rigol scope? Now would be a good time to use it.
    • tibimakai
      • Jan 2012
      • 3680
      Yes I have it. It's collecting dust.
        Well, do you know how to use it? Download Audacity: http://audacity.sourceforge.net/
        Plug the AVR into your computer, and generate a sine wave (Generate > Tone). 1kHz (1000 Hz) is good, generate a few minutes worth.
        Set the volume on the AVR low and post a picture of what the output looks like. (Probe on RED, ground on BLACK for appropriate speaker terminals.)
        For comparison, probe the working stereo channel too.
        • tibimakai
          • Jan 2012
          • 3680
          Speakers have to be connected?
            Try with them connected and without. Will be useful to see if there is a significant difference.
            Press AUTO on scope -- will generally give you a decent setup with most signals.
            • tibimakai
              • Jan 2012
              • 3680
              OK, didn't notice a difference with or without speakers.
              Here are the two front channels, set to 2 Channel stereo at the receiver.
              The "bigger" reading is the good channel and the "lower" reading is from the bad channel.
                Something isn't right. Less than 10mV would not be audible. Tone should be audible, but not ear splitting...
                Is that what auto gave you? Generally it's pretty good about getting you most of the way, unless the source is noisy.
                Set scope to: 1V/div (VERTICAL), 500us/div (HORIZONTAL), probe on CH1, only CH1 lit up.
                Also, scope has USB port for images, that may work better.
                • tibimakai
                  • Jan 2012
                  • 3680
                  The Auto setting showed a very small sine wave, couldn't see it.
                  I had to increase to the max to be able to see it properly.
                  It could be in the volume settings.
                  There are three volume settings, PC, AVR, software volume settings. Not sure which one where to set.
                  Scope's probe, has to be on the 1x scale and single wave?
                  I assume, it should measure 1000Mhz and not 100Mhz(as it measures now).
                  On the good channel I should be seeing a nice sine wave, am I right?
                  The amplitude in the software should be 0.08?
                    1000Hz or 1kHz.
                    Can you hear a tone from the speakers? If you do, that is fine.
                    Amplitude 0.8 or 1.0 doesn't really matter.
                    • tibimakai
                      • Jan 2012
                      • 3680
                      I can hear the tone and I have lowered it from the AVR, but at the PC side it was at 75%. From the software it was pretty low also.
                        Show me how you've connected the probe then.
                        • tibimakai
                          • Jan 2012
                          • 3680
                          Alligator on the black terminal and the probe on the red.
                            Try using a bit of wire. I don't think your probe is making a good connection.
                            • tibimakai
                              • Jan 2012
                              • 3680
                              I'm trying to measure this amp, but I don't know how to set up the scope.
                              I have to be on the 1X scale and 1X on the probe and AC coupling?
                              My scope can only save on wfm type of file and the forum doesn't accept this type of file as an attachment.
                              • tibimakai
                                • Jan 2012
                                • 3680
                                Here are two more pictures.
                                The low one is the bad channel and the other is the good channel.
                                  You are just picking up noise. Please take a picture of how you have connected the scope.
                                  • tibimakai
                                    • Jan 2012
                                    • 3680
                                    Tom, I think that I will have to test out the signal coming out of my PC first, to see if I get the right wave at the source.
                                    I'm at work now. I have asked a colleague here about the problem I'm facing and he said that I may have a broken probe.
                                    I'm thinking of checking out the probe if it has any damages(I haven't used it for a long time and it was just laying on the work bench, so who knows).
                                    I could just check the signal at the RCA plug at the end of the wire, right?
                                    Should I use the same settings at the scope, since the signal it will be much lower?
                                      If you are hearing a tone, the cable is OK. The second pic shows some evidence that the probe is working though this may be inductive pick up. The DS1052E comes with two probes so please try with the second probe to rule out the probe.
                                      Do you have a camera to show how it is connected?
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        I'm suspecting the probe's cable.
                                          Try connecting it to probe CAL (point marked _|'''|_). Then press AUTO. What do you see?
                                          • PowellSkier
                                            Harman/Kardon AVR 645 returning to stand-by after a few seconds.
                                            by PowellSkier
                                            A Harman/Kardon AVR 645 repair has been a hobby of mine for the past several years. My latest attempt involved the purchase of a DOA unit for part swapping and testing. The original AVR would power up then shut down after a few seconds. I completely tore down both units, found a couple of bad components and reassembled one of them. Same issue, no speakers connected. After extensive research I found a repair document from Harman/Kardon that explains the protection circuit in fantastic detail and provides specific test points for each fault (power, DC detection, overload & power) and the voltage...
                                            06-17-2024, 11:43 AM
                                          • funky2x
                                            Harman kardon onyx studio 7 Smd code
                                            by funky2x
                                            Cant find what smd code Y0DVA.
                                            sitting in Harman kardon onyx studio 7. Appreciate any help.
                                            05-29-2025, 03:44 PM
                                          • PowellSkier
                                            Cement resistor swap in Harman Kardon AVR
                                            by PowellSkier
                                            Would I be able to swap a 0.27 Ohm Kx2 5W resistor for a 0.22 Ohm Jx2 5W resistor in a Harman/Kardon AVR? Cement type.
                                            06-04-2024, 06:41 PM
                                          • falafinasul
                                            Harman Kardon AVR 3700 Fonte queimada
                                            by falafinasul
                                            Harman Kardon AVR 3700 burned, it does not turn on and I have already changed the fuse and when turned on it burns again. It must be shorted.
                                            I made a new Diagnostic and verified that the input source is shorted.
                                            Someone help
                                            02-24-2023, 05:51 PM
                                          • BlackScreen_22
                                            Harman Kardon sub TS11 (ds15 amplifer) blows fuse and mosfets
                                            by BlackScreen_22
                                            Hi, I'll start by saying that I'm not an expert and I've reached a point where I don't know what to try/do anymore...
                                            Starting from the beginning: I opened this subwoofer for the first time with a very strong smell of burnt electrical components, I realize that on the amplifier board there is a hole between V+ OUT and GND about the size of a finger, the damaged components were the shorted mosfets, two damaged zener diodes and two capacitors. I bought everything, I fixed the hole by cutting the pcb and putting a piece of a perforated board.
                                            I had no problems connecting mosfets and capacitors,...
                                            08-27-2024, 12:46 PM
