Yamaha HTR-5630RDS
  • Khron
    • Sep 2006
    • 1350
    • Finland
    Yamaha HTR-5630RDS
    Ok, so, i got this 5.1 AV-receiver off ebay, as faulty.
    Micom seems to be dead - despite it being powered fine, power button does nothing. No worries, i can still use the amps themselves, "hard-wired"
    Here comes the nasty (and/or confusing) part: upon plugging the receiver in (after jumpering over the main trafo turn-on relay), the power rails all come up fine, just as they should (roughly +/-41v), but on the signal inputs, the feedback inputs AND on the amp outputs, i get a slowly rising (about 1v per second) negative DC voltage Ends up around -30v on all five channels.
    Nothing gets unusually hot; the main heatsink starts warming up after a couple minutes, but not out-of-the-ordinary (the amps have 10/40/80mA idle current min/typ/max).
    The amps themselves are two STK402-120 (front+rear left / front+rear right) and an STK404-120 (center).
    The service manual can be found HERE (just ~100KB over the forum limit, unfortunately ); amp schematics are on page 59.
    I've removed the five muting transistors, and the output relays, and replaced them with wire jumpers.
    I'm stumped...
    Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
  • Khron
    • Sep 2006
    • 1350
    • Finland
    Re: Yamaha HTR-5630RDS
    Mystery solved
    The "signal ground" (amp input ground, feedback ground, muting ground etc) was AC-coupled to the "power ground" (output stage, main filter caps etc) through a 2R2 resistor and a 10nF cap.
    Right next to those, there are two wire jumpers, TP101 and 102, parallel to each other, and with a hole in the PCB right underneith them. TP001 = signal ground side, TP002 = power ground side. With my multimeter probe on an output pad, i stuck the tip of a pair of tweezers in between the two jumpers (shorting them together) and ta-daaa! The +17v DC i had at the outputs (this time) instantly dropped to about -30mv
    So... yeah...
    • Stephen
      A2991 Logic Board issue, 20volts 0 amps help!
      by Stephen
      Customer plugged in samsung monitor into the board and used it as a power supply, killed UG800 and UG400. I replaced those two with an exact donor board we had In stock and working, board pulls 5volts and then gets like 2.89 amps on the left side. The singular port is the port that failed. Used a perfectly working chips from donor (board was locked) Now I only get 5volts 0 amps on that power and then 20volts 0 amps on the two left side ports, I checked for DFU and nope nothing, computer not turning on. No shorts present anymore. I am confused as I used the exact components from an identical...
      09-10-2025, 03:16 PM
    • Stephen
      A2991 logic board issue, 20volts 0 amps help!
      by Stephen
      09-10-2025, 03:15 PM
    • sanalelevenstar
      Yamaha RX-V485 Wn9711 Update
      by sanalelevenstar
      Help Needed: Yamaha RX-V485 Network Issue After Firmware Update (WN9711 Error)
      I'm facing an issue with my Yamaha RX-V485 receiver. During a firmware update, the process failed, and now the USB, Bluetooth, and network functionalities are not working. Occasionally, the receiver displays the error code WN9711.
      I came across Yamaha Technical Bulletin No. 0103, which describes a similar issue for models like the RX-V4A, RX-V6A, and RX-A2A. According to the bulletin, the issue can be resolved by shorting soldering points (e.g., J260 for RX-V4A or...
      12-04-2024, 04:32 AM
    • Fisher8865
      MacBook Pro A1990 stuck at 5v .592 amps
      by Fisher8865
      Hi guys
      I have a MacBook Pro A1990 that takes 4.9 Volts and .592 to .615 amps on one port. The other port on the left side power cycles with about the same amount of volts an amps but quickly power cycles. The same thing happens on the other side but opposite. So on the left side the bottom port stays on and on the right side it's the top one. I think it is a CD3215 chip but I am not sure how to test it or where to get one. I have checked for voltage at ppbus_g3h and it has 12.6 V which is also on fuses f7000 and f7001 I checked pp1v2_s3 and it has 1.2 V then...
      05-30-2024, 07:36 PM
    • chazzo
      CH341 programmer advice, including jumpers seemingly reversed
      by chazzo
      I’d appreciate some very basic advice on CH341x programmers. I know this topic comes up from time to time, but stuff changes, so I hope a refresh is in order. In particular, I see some unexpected things happening with jumper positions.
      [My plan is to learn to read and write 24CO2 EEPROMs via I2C. The first target is the one in my Uni-T clamp meter, but before tackling that I have some brand-new EEPROMs to practice on.]
      I have two basic Chinese programmers. One is the blue board with a CH341A and two rows of pin headers. To my untrained eye it looks like all the others....
      10-12-2025, 08:15 AM
