Crate KX-80 Keyboard Amp fuse pops immediately
  • ajsemtb
    replied
    Re: Crate KX-80 Keyboard Amp fuse pops immediately
    Yes it did it before. The high pitched squeal that happened when you shut it off is gone, so that's good . But the pop is still there.
    replied
    If you can see the cone moves forward or backward at full cone extension, then you should fix it.
    Did it do this before? By the way, did you use the same value caps, it may be that the caps (in the pre-amp, which supplied by the resistors and the Zener Diodes) are charging up slowly due to higher values after the power amp section is already on.
    The rule of powering up sound system is to power up the preamp first then the power amp to avoid popping the speakers. Do in reverse order when powering down.
  • ajsemtb
    replied
    It "boofs" when turned on w master at 0 but no pop when turned off. The boof sounds like the speaker getting hit with voltage. I would think it shouldn't be that pronounced when turned on.
    replied
    There may be leaky audio stage coupling caps that no longer block out the DC voltage between audio stages.
    Does it pop when Master volume at '0'?
  • ajsemtb
    replied
    oh, and I used the barrel caps on those ones that I asked about because the axial caps had a factory ESR of 44ohm, and that was way more than what was in there before, and the regular caps, though required some creative bending of the contacts, they had a similar ESR to the one that was not damaged. (I replaced both so they matched, but used the non damaged one as a reference.)
  • ajsemtb
    replied
    update, it works! Replaced 8 caps, 4 diodes, 2 zener diodes, and put it back together. Now, it is functioning as well as it did before it died, however, it still "pops" loudly when turned on, and off. Is there any reason for that? If its not a "oh that's a problem with the ...... and you just have to replace ....." then I'm not going to tear it back apart. If its a simple thing, I'll open her back up. Thanks again for all your help! Again, you have fixed yet another piece of equipment, and saved it from the trash!
    replied
    if the audio coupling was 3.3uF, you can use 4.7uf (most of the 1. 2.2. 3.3, 4.7uF will be rated at 50Vdc which are fine) it will give more extended low frequency response. In the high end audio if they use electrolytic for coupling, they will also use a small value cap (0.01uF polyester, non-inductive type, or ceramic) in parallel with the coupling cap. I do not have golden ears, some people do not want to use any coupling cap between audio stage at all.
  • 999999999
    replied
    The voltage on those is "probably" irrelevant (measure voltage while unit is powered on to be sure), when the uF value is so low it is just easier to make higher voltage parts that cover a wide array of circuits. Use what physically fits on the PCB better then what has better specs like temperature, ESR, etc.
    If you were to reverse engineer the subcircuits and determine the role of the capacitors, then we might better determine if there's any realistic expectation that choosing a different capacitor type would be an improvement and then there could be a need to measure operating voltage since other capacitor types like film, ceramic, tantalum, have lower capacitance density per area and space available on the PCB would be more of an issue. For example in the signal path a film cap could be desirable or for decoupling, either film, ceramic, or tantalum. However since it is located in the speaker enclosure some ceramics may not be ideal as the vibrations can affect their performance.
  • ajsemtb
    replied
    OK, so I ordered the replacement caps, they will be here Friday. I ordered both the axial caps that are 3.3uF 63V (because the 50V were not available in axial) and I also ordered 3.3uF 50V "can" caps because they are the correct voltage. What I don't know, is which would be better? Anyone have an opinion? I know there shouldn't be anything wrong with going up in voltage, but can you use the radial caps in place of the axial caps?
  • ajsemtb
    replied
    and the 3.3uf 50v axial cap is not available. could I use a radial leaded cap instead?
  • ajsemtb
    replied
    *UPDATE* Ok, got parts in. Installed the diodes for the bridge rectifier, decided to use my new Atlas ESR70 meter and on the in-circuit caps to test before I add power... Glad I did. (or better yet, wish I'd had it when I ordered the last set of parts... >;F I found a cap that indicated >40ohms, removed it from circuit and retested. Failed miserably. It was a 3.3uf 50V axial cap. While desoldering it and trying to pull it out, I grabbed the wrong cap, and pulled the leg out of the cap. Its a 1uf 50V cap... So great. Now I need MORE Parts that I know frys won't carry.
    At Newark, the Multicomp caps are .06-.08. The NTE is .35. I was going to order extras, as I always do JIC. Any problems with the Multicomp caps, or stick to the NTE? No panasonics aren't available....
    Tested all the rest of the caps in circuit, most of them are <10uf and had ESR readings from 3ohm-6ohms. All different amount. None tested bad though. The ones that I felt were kind of high, I removed, retested, tested good, so reinstalled...
  • ajsemtb
    replied
    Just a short update, I got my Atlas ESR70 meter in. It confirmed the 2 "burned" looking caps were bad, as well as the 2 that weren't burned seemed awful high ESR. Glad I changed all 4. Still waiting on diodes.
  • retiredcaps
    replied
    Originally posted by ajsemtb
    (what are zener diodes anyway, and what do they do?!)
    http://en.wikipedia.org/wiki/Zener_diode
    Is there anyway to test the caps with a standard DMM that would tell me if they are bad?
    If the multimeter can't read capacitance, then there is no accurate way to measure uF. No multimeter can measure ESR.
  • ajsemtb
    replied
    ok, I got shipment #1 in. It had the caps and the zener diodes (what are zener diodes anyway, and what do they do?!) Installed those parts. The other 4 diodes had to be shipped directly from the manufacturer as they are not stocked parts anywhere, it seems. they should have been shipped out today so I'll have those in a couple days. Needless to say, i can't power on yet until those are in. Just wanted to give you all an update.
    Oh, and I originally ordered the Nichicon 35v caps that matched, but also ordered the 50v Panasonics that were supposed to be better. I installed the 50v caps. I replaced all 4 (they were the yellow ones). Is there anyway to test the caps with a standard DMM that would tell me if they are bad? My DMM doesn't have the capacitance meter. I did however order the Peak Atlas ESR70 that should be here next week as well, so I'll be able to test all these caps that I've been saving from other projects to see which ones ACTUALLY failed, regardless of changing them ALL out.
  • ajsemtb
    replied
    Thanks, order made. Now waiting on parts. Thanks for your help!!!
    replied
    You can go with higher Voltage and current rating for the Diode: 100v and 1.5A sounds kind of low to begin with.
    http://www.digikey.com/product-detai...ICT-ND/1228202
    http://www.digikey.com/product-detai...TPCT-ND/950500
  • mariushm
    replied
    Farnell (Newark) has them :
    1n5392
    http://www.newark.com/multicomp/1n53...00v/dp/01P4232
    http://www.newark.com/nte-electronic...-5a/dp/33C7847
    1N5353B
    http://www.newark.com/multicomp/1n53...lar%20Products
    http://www.newark.com/on-semiconduct...lar%20Products
    http://www.newark.com/on-semiconduct...7aa/dp/10N9629
    As for capacitors, I think you needed 100uF 35v - there's no 100uF 35v in the Panasonic FM series, there may be in the FR series but I'm too lazy to look it up now (later edit: nope, same with the FR, only 50v rated ones).
    Anyway, you can go up in voltage rating with no problems, so then you have more choices.
    Panasonic FR 100uF 50v will do:
    http://www.newark.com/panasonic/eeuf...ial/dp/74R3440
    This Rubycon ZLH 100uF 50v is relatively close in specs to Panasonic FM and Panasonic FR 100uF 50v, should have about the same specs as a hypothetical FM 100uF @ 35v :
    http://www.newark.com/rubycon/50zlh1...ial/dp/39K2793
    This 100uF 63v Nichicon PM should be acceptable... not as great as Panasonic FM or FR or the Rubycon above but i'd say good enough...
    http://www.newark.com/nichicon/upm1j...ial/dp/65R3647
    You may be able to use this Nichicon KZ 100uF 50v (Muse audio grade capacitors.. though doesn't matter where the capacitor is located):
    http://www.newark.com/nichicon/ukz1h...ial/dp/70R1183
  • ajsemtb
    replied
    i'm getting obsolete messages and not in stock messages at mouser, digikey, avnet, and a couple other sources from google... Any thoughts?
  • ajsemtb
    replied
    btw, the diodes are 1N5392 1.5A 100V
  • ajsemtb
    replied
    OK, after all the searching, Digikey does not have the diodes I need in stock... is there another website? I usually use Digikey, so I don't know of another supplier..
  • corrize
    A funny fuse story – Lumix LX100 II
    by corrize
    Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
    I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
    The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
    There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
    And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
    10-19-2023, 09:58 AM
  • jesterace
    Samsung UE46ES8000 Blown fuse but no other signs of short
    by jesterace
    Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
    09-11-2024, 03:14 PM
  • jshhh
    Help replacing fuse on my Mimaki CJV300-160 vinyl printer
    by jshhh
    Hi guys,
    I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
    How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
    Anybody know how to remove this type of fuse?
    (The fuse is toward the bottom of the image labeled F2)...
    06-17-2025, 01:35 AM
  • Babbar
    by Babbar
    04-12-2024, 01:12 AM
  • drykid
    Matsui 175S microwave fuse replacement
    by drykid
    I recently picked up a used Matsui 175S microwave that was powering up (starts, turntable rotates) but not heating. From looking online the most likely culprit was the fuse, but unfortunately in this one the fuse had heated up and fused with the (badly designed) fuse holder and couldn't be removed. I guess this might indicate further issues beyond the fuse itself but at this stage I just want to replace the fuse and see how I go from there.
    Anyway since I couldn't get out the fuse itself the easiest fix was to replace the fuse holder assembly that runs between the...
    12-21-2020, 01:15 PM
