Record Player Buzz
  • pentium
    • Mar 2006
    • 2778
    Record Player Buzz
    I found an absolutely ancient GE "transistorized" record player and aside from an unbalanced and excessively cheap pickup arm it has a real bad buzz. It's trying to amplify but more than anything the buzz overwhelms it. The amp circuit itself is very simple. Me being near the needle also seems to change the volume of the buzz indicating a ground loop, I believe.
    Black cylinder on the right takes 120v in, there's four transistors, three capacitors and a bunch of resistors. It receives a signal straight from the needle and outputs straight to a speaker. Knobs control power and tone.
    Never worked with amps before but my assumption is that after 40 years all the caps require replacement, correct?
    Find Nedry!
    Check the Vending machines!!
    Re: Record Player Buzz
    Have not work on one of these since the very early 70's. I thing it get the low voltage AC from the motor winding otherwise you will see big resistor to drop the 120Vac to about 12V. That large cap sitting between the two pots is the DC filter cap. The little black transistor sitting between the two push-pull out put transistors ( with heat sink on them) is for phase splitter/driver for the push-pull output section. The second medium size electrolytic cap is the DC blocker for the out put circuits to the speaker. The smallest electrolytic cap on the left is the input cap from for the phase splitter transistor. The small ceramic disk on the top left by the tone control pot is for the tone control circuits.
    Yes, recap first. This amp may use Germanium transistors which has very high leakage which can cause a lot of problem such as low gain and draws a lot of current.
    • kaboom
      "Oh, Grouchy!"
      • Jan 2011
      • 2507
      And one side of the AC line goes right to that board- hot chassis. Look at the insulated pot shafts.
      Check the carbon comps- they can drift upwards in value.
      "pokemon go... to hell!"
      EOL it...
      All style and no substance.
      guilty,guilty,guilty,guilty!
      guilty of being cheap-made!
        MEDION AKOYA S15447 + ext. DVD Player Notebook Specification for Upgrade or Repair
        This specification for the MEDION AKOYA S15447 + ext. DVD Player Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S15447 + ext. DVD Player boardview and S15447 + ext. DVD Player schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
        09-06-2024, 05:30 PM
      • redwire
        Honeywell/Ademco Wave2 two-tone siren - recap, sch, pics
        by redwire
        My garage alarm siren was sounding a bit quiet and the tone was weird, like mixed with another tone.
        Powered up it draws about 14V 300mA with a spike to ~1A briefly during the low pitch yelp, seems normal.
        Teardown reveals only two electrolytic capacitors inside, so I replaced them. 100uF 25V for the warble ramp, and 47uF 16V for decoupling.
        The old ones tested OK sort of? - 100uF reads 68uF (-32%) ESR 0.80Ω, and 47uF reads 41uF ESR 0.87Ω as well so it was a bit confusing if the caps were to blame.
        The tone caps are green film caps I left alone. Newer...
        07-30-2023, 08:21 PM
      • unimatrix93
        LG BH6420P Home theather blue ray player repair
        by unimatrix93
        Hello everyone, I'm trying to troubleshoot this LG hometheater player.
        The customer forced her USB drive reversed into it's USB socket and since then the player won't work properly, only shows "Please wait" error forever on it's display.
        Now I started diagnosing the USB socket and the mainboard where it's connected.
        I found 20ohm resistance to ground on the 5V line of the USB.
        5V is missing and I found the buck converter of the USB line, TPS65252 IC.
        After measuring the pins I realized that both VIN and 3V3 is correctly present...
        12-10-2024, 10:31 AM
      • FZG
        Panasonic AG-1000B VHS player with bad picture quality
        by FZG
        Hello!
        I recently got an old VHS player from Panasonic and just for fun I want to try to repair this device. It is an AG-1000B portable VHS player from 1990 and it has a problem with picture quality in playback mode.
        Picture in playback mode is very noisy and often loses sync but the still images are nearly perfect.
        I want to know, is this something that could be solved by recapping or is the video head likely gone?
        Also, what mechanism is this?
        Any feedback is appreciated!...
        05-06-2024, 07:16 AM
      • harp
        Needle protection for small current instruments
        by harp
        Just want to know is there some common method to protect needle from crashing to end, if the meter is galvanometer or microampermeter with both side movement, needle in center?
        If it comes to fast and high unbalance on bridge, the needle was smash and bent. Some electronic circuit might help but it should not interference with measurement if value is in ok range....
        01-16-2023, 12:11 PM
