Powered subwoofers
  • glockstr
    • Mar 2012
    Powered subwoofers
    I have a collected couple of powered subwoofers in the garage over the years. Just couldn't make myself throw them away and always planned to fix them. I started that this past weekend and noticed both have the same problem or seem to.
    They both power on, red light when plugged in and green light when turned on. I suspect the input is working because the auto on trips the green light when a signal is fed from the receiver and I hear the relay click on. I know the receiver's sub line out is good. No fuses are blowing and nothing get's excessively hot, just warm. I get no sound from the speaker, no bumps pops or hums, just silent. I read many of the posts here and they all refer to hums or pops but I didn't see anything with my symptoms. No components look burned or appear to be leaking. Any suggestions on what to try would be appreciated.
    Thanks,
    glockstr
  • 999999999
    • Sep 2006
    • 774
    Re: Powered subwoofers
    First, supplying good top-down and bottom-up (not angled) pictures may help, and if you can find a schematic that would help too.
    Generally speaking you would trace and measure the signal path and power path. While you do have some portion getting power it isn't necessarily proof that all the power subcircuits are working. Often there are at least 3 separate supply sections including high(er) voltage positive and negative rails for the power amplification stage, lower voltage positive and negative rails for an opamp or equivalent input stage, and at least a single rail of lower voltage still for logic ICs or circuitry.
    A quick couple tests I would do with regards to these is trace back the speaker output path to the last IC or transistor before it, and measure whether the appropriate pins have supply voltage and audio signal. That last IC or transistor is a frequent failure point so if there's power and signal without output, AND you don't have a protection circuit fault or stuck relay, then it's probably a bad transistor or IC.
      Makes and Models?
      • glockstr
        • Mar 2012
        Thanks for the advice. I don't think I will be able to get a hold of the schematics as the subs are fairly old. They are a BIC V80 and an Aiwa TS-w35U. I will write the companies and see what they say. Anyway backtracking from the speaker wires shouldn't be too bad. There is plenty of room on the boards and not much surface mount stuff.
        *edit* Oops, spoke too soon. Found the Aiwa schematic under the model number tsw37 here;
        http:// (insert www here) .eserviceinfo.com/index.php?what=search2
        • dicky96
          Dynacord PowerMate 600 Powered Mixer - Protect Light On
          by dicky96
          Hi guys
          I'm trying to repair this powered mixer. Sorry this is a bit long but I want to give as much info as possible to help get an answer,
          As soon as it powers on the protect light comes on. There are relays that connect the speakers to each channel of the amplifier but they never click. If I connect a 60W light bulb in series with the mains supply it comes in bright then goes to maybe 30-50% brightness - it seems to dim a little further over time
          I have power to the amplifier, I think it was as about plus/minus 50-60V for the main amp, and plus/minus 15V...
          05-22-2022, 04:36 AM
          Lithonia Lighting versus Light of America Compact Fluorescent product quality
          I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
          I also have back when Light of America had these light bulbs available for yard lights
          The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
          While the Lithonia lighting fixture has all most certain bulb failure
          So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
          I have only had this light fixture for not more than a year if it...
          07-02-2023, 03:45 PM
        • duwane
          MacBook Pro A1278 - No charger light, no PPBUS_G3H, SMC_BC_ACOK short when powered
          by duwane
          Hi All.
          I have a very strange issue that I have been trying to fix for a few days now.
          Model: MacBook Pro A1278
          Logic board: 820-3115-B
          Laptop history:
          No visible liquid damage/corrosion, but found evidence of other rework (flux) so any signs of liquid may have been cleaned. The laptop went in for a battery replacement but wasn't working afterwards and was deemed unfixable (as told to me by previous owner). Not sure if this was by Apple, or another repair company. The flux found was found around ISL6259HRTZ, so can assume it was replaced...
          05-15-2022, 05:22 PM
          LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
          This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
          09-07-2024, 03:40 AM
          LG Gram Ultra-Light Laptop Notebook Specification for Upgrade or Repair
          This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
          09-06-2024, 09:10 PM
