Technics Service Manuals
  • JEWilson
    • Sep 2007
    • 369
    • Scotland, United Kingdom
    Hi
    Can anybody help with Technics Service Manuals?
    I live in the UK and have acquired;
    1 of SL-P222A CD Player with optical O/P
    1 of SA-GX200L Receiver
    The CD player appears to be ok
    I have serviced the decent Philips CDM4/19 transport
    Will probably use a modern DAC with it, if it O/Ps S/PDIF - should do.
    The receiver is only playing mono.
    Appears the balance control is not working correctly
    It is a bit scratchy - so deoxit or replacement
    Any help appreciated
  • larrymoencurly
    • Oct 2004
    • 960
    Re: Technics Service Manuals
    ElektroTanya.com ?
    • 999999999
      • Sep 2006
      • 774
      Replace or clean, or disassemble then clean and retension the pot wiper arms and tracks it wipes if external spray cleaning is not enough. It could be that only the balance, or maybe volume pot also needs cleaned and tensioned.
      I'm suggesting maybe you don't need a service manual at all. For pot replacement just note the pin spacing, pot values, and order some equivalent part rather than the original.
      If that doesn't solve the problem then the next suspicion would be the output transistor on the channel that doesn't play, trace back from that jack to the transistor and see if there is output there, or an input (drive) on it's base pin. If no drive current, trace back to the prior transistor in the chain or IC chip, whatever it's using.
      • redrooster
        • May 2011
        • 114
        HiFi manuals.com and elektrotanya.com for free manuals.
        HP P6-2203a desktop,AMD CPU A8-5500 with Radeon HD7560D,3.20Ghz. Radeon HD 6670.8Gb Ram.2TB HDD. WIN 10 64 bit O/S.
          LCD LED TV Service Menu Codes
          ALL LCD LED TV SERVICE MENU CODES
          Service Menu Code with Board Name
          China Universal Board / Jumper Board Service Menu Code
          Changhong Ruba Service Menu Code
          Ecostar LED TV Service Menu Code
          Orient LED TV Service Menu Code
          Haier LED TV Service Menu Code
          TCL LED TV Service Menu Code
          Samsung LED TV Service Menu Code
          LG LED TV Service Menu Code
          Videocon LED TV Service Menu Code
          Supra LED TV Service Menu Code
          Toshiba LED TV Service Menu Code
          Symphony LED TV Service Menu Code
          Veste/ LED TV Service Menu Code...
          10-31-2024, 03:58 AM
        • Med-Tech
          Medical Devices Service Manuals
          by Med-Tech
          Hallo, anybody know where to get service manuals for Medical devices (other than Franks hospital)? The problem I have is with a physiotherapy machine it shows nothing on the display and the green LED flickers.[
          Thanks in advance....
          05-24-2025, 05:43 AM
        • mscottdoran@gmail.com
          Realistic 31-1975A Receiver service manual
          by mscottdoran@gmail.com
          Hi, I’m looking for the service manual or schematic for a Realistic 31-1975A Stereo Receiver. If anyone has a PDF they could post I would greatly appreciate it. Thanks
          02-13-2025, 01:56 PM
        • AustinCER
          Dell XPS 8940 | Manufacturing Mode? | No Service Tag
          by AustinCER
          Hello, I currently have a Dell XPS 8940 in our office for repair.
          Service Tag: HG1Y673
          The most recent BIOS is pictured below -- being available as an .exe on Dell website.
          Needed a new motherboard due to power surge. The motherboard replacement was installed and upon power up it was booting to a display message - Manufacturing Mode Active -
          Have not dealt with this issue before or what the proper steps are. I booted to the BIOS and manually entered the Service Tag, but upon each reboot -- the service tag is wiped and shows the Manufacturing Mode display message,...
          07-15-2025, 05:28 PM
        • Yanleb
          Panasonic part number in service manuals
          by Yanleb
          In the Panasonic service manuals, both in the board schematics and in the part listing, the part numbers that are given are Panasonic part numbers instead of the actual part numbers.
          This is especially annoying for small SMD components like diodes and transistors when you only have 1-3 digits printed on the component body.
          For an example, look at the attached PDF.
          Do you have a way to cross reference the Panasonic part number with the actual part number?
          Thanks....
          07-03-2023, 08:16 PM
