Marantz DV7000 dvd / cd player switching off
  • aarty
    • Aug 2012
    Hi there guys,
    Just wondering if anyone out there has had issues with a Marantz dvd/cd player. When you switch it on it says "welcome" then goes to standby. I have checked the usual cd switches for door and sled and they are working as they should. Voltages seem ok. A couple of voltages should measure 12v but are 11.5v, which I don't think should be a big deal. I have checked the caps ESR and they are fine. Next I will check capacitance as now I getting desperate.
    I have also checked the "test" mode 1 and 2. Test mode 1 is ok. But I find test mode 2 doesn't do what the service manual says. Like after test2 ok I can press a sequence of buttons to reset the eeprom. I did change eeprom but still the same.
    Has anyone out there had the same issue as my unit??
    Regards,
    aarty
    07-01-2024, 06:34 AM
    03-31-2024, 02:12 PM
    MEDION AKOYA S15447 + ext. DVD Player Notebook Specification for Upgrade or Repair
    This specification for the MEDION AKOYA S15447 + ext. DVD Player Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S15447 + ext. DVD Player boardview and S15447 + ext. DVD Player schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
    09-06-2024, 05:30 PM
  • chth96
    How Can I test PWM DM0365R?
    by chth96
    Hello
    I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
    So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
    I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
    I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
    06-18-2025, 04:14 PM
  • khelane
    test active pfc power with lamp test
    by khelane
    Hello
    I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
    Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
    Is there a way...
    06-03-2025, 01:00 AM
