MARKBASS MINIMARK 802 - What is that relay ?
  • smurtz
    • May 2012
    • 54
    • farfarfaraway
    I got hold of a non working bass amp Markbass minimark 802, witch stays dead when turned on.
    Before checking anything else, when opening, the first thing I see is a broken relay:
    What would be the replacement part ?
    I tried to look on the schematic of a similar markbass amp >HERE< but nothing is mentionned except "RL1".
    On the remaining part of the relay we can still read "8A" but thats about all.
    Would it be a G2RL relay (>HERE<) but which one ? (a G2RL-24 DC24 ?)
    Thanks a lot for your help.
    Yves
  • madan1
    • Nov 2016
    • 718
    • Bulgaria
    Re: MARKBASS MINIMARK 802 - What is that relay ?
    Seems to be on the amp side and I would guess it disconnects the speaker from the amp so that there is no pop sound when the amp is turned on.
    PS
    Here https://cdn.badcaps-static.com/pdfs/...ceb5b3feac.pdf page 14, RL1 right next to the speaker connection. Just shunt it for troubleshooting and if it is the cause, then anything that fits the footprint and the control signal level (18v) should do the work.
    • petehall347
      • Jan 2015
      • 4440
      • United Kingdom
      check voltage at the 1 meg resistor R68.ideally 0v . i guess protect kicks in about 3v . maybe less .
      • CapLeaker
        Leaking Member
        • 8331
        Speaker protection relay? Should be normally open.
        If you turn an amp on you should hear a click (if everything is o.k.)
        The relay you chose is normally closed.
        • smurtz
          • May 2012
          • 54
          • farfarfaraway
          Thanks a lot, I ordered the relay.
          Tried to shunt it, but no effect. Current goes to transformer TRANS5_1_1 but not past it.
          I first thought the transformer was dead and unsoldered it to test it, but it seems ok.
          However since enough room was left without the transformer I was able to test capacitor C68 (1uF/250V) which (unsoldered) reads 209nF.
          Hopefully it'll work again once that capacitor+relay changed. More news when I receive the parts.
          Yves
          • lotas
            • Jan 2016
            • 4760
            • Russia
            Photo from the Internet, 12v relay.
            • smurtz
              • May 2012
              • 54
              • farfarfaraway
              excellent, thanks!
              Yves
              • smurtz
                • May 2012
                • 54
                • farfarfaraway
                I changed C68, switched on, and tada ! Well, tada, now the fan starts, the on led is off.
                On the board I have the +15V.
                the led clip is on. I did not reconnect speakers when switching on.
                I had to order a new relay since I ordered a 24V before seeing lotas' message.
                Once I receive the relay I'll do some more checks.
                Yves
                • smurtz
                  • May 2012
                  • 54
                  • farfarfaraway
                  Replaced the relay, but nothing new.
                  When I switch the amp on, the fan starts and I hear the relay click once (r68 voltage is 0).
                  The led "clip" is on, the led "on" stays off.
                  When I turn the amp off, I hear the relay click once
                  On schematic page 15:
                  near C53 I have +15V -> ok
                  near C59 I have +12V -> ok
                  near C41 I have +19V (marked +18V on the schema)
                  near C62 I have 0V (marked -15V on the schema) ->I have -20V measured at Vin on regulator RG2, I checked regulator RG2, seems ok but I'm going to change it to be sure.
                  near C45 & C46 I have +58V and -58V (+80V & -80V on the schema)
                  Could the +/-58V be ok ? or the 4 RF2001s (D24/D25/26/27 marked BYV32E on the schema) should be replaced ?
                  Yves
                  • CapLeaker
                    Leaking Member
                    • 8331
                    Either you got a bad 7915 regulator RG2 or something is shorting the -15V rail to GND.
                    • smurtz
                      • May 2012
                      • 54
                      • farfarfaraway
                      Thanks,
                      I changed the 7915, checked for shorts, switched on and it immediately got me a fume.. Fuse F1 is now broken.
                      However C65 (2200uF capacitor) seems to be the one that was causing the problem, I'm going to change it as well.
                      Any clue of what is the value of the fuse / what kind of fuse it is ? It looks like a resistor.
                      Yves
                      • CapLeaker
                        Leaking Member
                        • 8331
                        F1 is probably same as F2 and may be a fusible resistor. Size makes the wattage. Make a picture of it?
                        • smurtz
                          • May 2012
                          • 54
                          • farfarfaraway
                          Unfortunately, contrary to what is mentioned on the schematic there is no F2 or F3 fuses !
                          EDIT: seems to be a R = 0,22 Ω ±5 % 250 ppm/°K​
                          • CoinCoin88
                            Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                            by CoinCoin88
                            I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                            Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                            09-15-2025, 03:36 AM
                          • jm1234
                            9V relay temperature 40C
                            by jm1234
                            Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
                            I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
                            05-09-2024, 03:03 AM
                          • edugimeno
                            Biomass Boiler not driving cleaner motor relay. ENERTRES BIOMASA BI-650
                            by edugimeno
                            Hi everyone!
                            I have this board that suddenly stopped supplying power to an output that drives an interchanger cleaner motor.
                            I checked while the board was in place with all wires attached and there's no AC voltage on the corresponding plug X5
                            This X5 is driven by fuse F8 (tested OK) which comes from the second orange relay
                            To make sure there are no charcoaled contacts inside the relay, I got a 24VDC power supply and got it ready to manually power up the coil side of these relays.
                            I respected the polarity, positive to cathode of protecting diode
                            So provided all...
                            04-18-2024, 01:15 PM
                            Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                            by sam_sam_sam
                            I was working on this CNC machine today found no keyboard functioning no control relay powering on
                            The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                            Found shorted diodes on main controller relays there are 3 of them that...
                            01-07-2023, 05:43 PM
                          • fadi90
                            PILZ PNOZ X4 Safety Relay
                            by fadi90
                            I'm working on repairing a Pilz PNOZ X4 safety relay module. When I opened it up, I found some of the connector pins detached from their pads. I replaced the connector with individual wires, but the issue remains.
                            The module is set to dual-channel mode with manual start. In this mode:
                            • Y36-Y37 and Y1-Y2 are bridged.
                            • 24VDC is applied across A1-A2.
                            • It monitors two emergency circuits (S11→S12 and S11→S52).
                            • When both are closed (24V present on S12 and S52) and the start button is pressed (S33 connected to S34), the NO contacts (13-14, 23-24, 33-34)
                            06-07-2025, 01:21 AM
