Noble potentiometer assembly
  • Vinylbeast
    • Oct 2023
    • 5
    I had taken out the pot for my Denon DAP-5500 as it was scratchy and would sometimes drop a channel til I would work it and would come back for few days. Decided I had time today and would just desolder from board and disassemble and clean properly. My only issue is I forgot to take a pic of the orientation of each of the white parts and how they were aligned. Due to the shape of the rod and the cutouts on each white piece they can only go one of two ways. I did have frame of mind right after I took off the first (back) and I know how that last white piece was orientated, note the main shaft is turned to "max volume" in that photo. Does anyone know if the other three white pieces are in same orientation or if not which way each should be orientated on shaft when reassembling from front to back.
    Here is a pic of everything for reference
  • Vinylbeast
    • Oct 2023
    • 5
    Re: Noble potentiometer assembly
    Basically I just need to know if all the wipers are oriented the same way when reassembling on the shaft.
    • redwire
      • 3910
      I think it's like this pic. Like a sandwich - all layers are the same, just stacked.
      Make sure to eyeball the spring height(s) on the wiper, they should all be the same unless one got bent. Especially the lone one. If there is any oxidation on them, I wipe them on a piece of paper lightly to clean that off.
      I use DeOxit Faderlube on the pot internals and then oil or grease the shaft depending on the feel wanted. Usually oil lube is there that can get thick.
      • Vinylbeast
        • Oct 2023
        • 5
        Thanks for reply and pic!
        • Vinylbeast
          • Oct 2023
          • 5
          Got her all back together and jamming my music again!!! Thanks again!
          • redwire
            • 3910
            If the pots are still noisy... this can be due to DC current flowing throught them if there is a little DC offset.
            There are two trimpots VR301, VR302 on the KU-9103-4 board if it's in "Source Direct Off" (I think otherwise the relay bypasses that board).
            Denon call it the "Boost Amp Neutral Point Adjustment".
            There's a second downstream offset adj. "UGI Amp Neutral Point Adjustment" to do as well.
            If you find any temperamental scratching, due to temperature etc. with the many JFETS this preamp has, then do the adjustments. Easy to do with a multimeter.
            https://www.manualslib.com/manual/10...-Dap-5500.html
            • ElectricDoodler
              Lenovo Thinkpad X230T Convertible - display assembly and touch digitizer
              by ElectricDoodler
              I need the schematics and boardview for the display assembly and touch digitizer for an X230T convertible tablet from Lenovo. Would anyone happen to have them?
              I have one in perfectly working condition, and I've been primarily using it as a drawing tablet for a while. But the CPU is showing its age with it not being able to handle larger canvases, so I would like to remove the display assembly and use it as a USB drawing tablet, and I need to verify the pin-layouts of the touch digitizer to do so.
              Model: X230T (type 3437-23G)
              Display FRU 04W3919
              Display P/N...
              01-19-2025, 12:57 AM
            • Xenon-Codex
              Volume potentiometer loudness tap bypass?
              by Xenon-Codex
              I salvaged a Sony TA-F170 with broken volume potentiometer. It has a special pot with a loudness tap in the middle, of course not available anymore.
              Is the loudness somehow possible to get to work, at least constant instead of variable? I have a regular potentiometer which works, but the loudness does not.​
              01-16-2024, 01:53 PM
            • LearningToRepair
              How to know if LED driver is potentiometer dimmable?
              by LearningToRepair
              Hi!
              I am looking to dimm 230V AC -> 12 DC LED driver with potentiometer. How do I know if I can dimm LED driver with potentiometer? I found from internet that 0-10V dimmable drivers can also be controlled with potentiometer. Is it so with every driver that says it is 0-10V dimmable? Or how do I know which are and which are not?
              10-30-2021, 05:14 PM
            • mikkele86
              Marantz PM 25 - looking for potentiometer RM050 / M50KC
              by mikkele86
              Hello. im renovation a Marantz Console Stereo Amplifier PM 25.
              One of the potentiometer for the tone control is broken and im having troubles finding a replacement.
              I know its 50K ohm.
              i think its reverse log.
              and 6 pin. Stereo.
              The parts list says its a RS05030350
              05-13-2024, 02:34 PM
            • waigy
              Variable resistor potentiometer has different reading when mounted on the board
              by waigy
              In my fusion FE-402 car amplifier the gain pot is an RK097G.
              I think it is anyway, the RK097G is the closest I've found to the original with the same pin number and dimensions.
              The differences are my pot is blue and has B203 on it and the shaft is plastic with a small slot at the very end only.
              I measured the resistance and found it went from 0 up to 10k so I ordered a 10k pot.
              I then took the pot out the board and it now measured 22k.
              I tried putting it back in the board and it goes back to 10k.
              Is this normal and if so what pot should I order?
              On this...
              11-12-2024, 04:44 AM
