Rx-a660 turn off
  • servobillŕ
    • Aug 2019
    • 6
    • Mexico
    Rx-a660 turn off
    hello friends I hope you can help me with the service manual yamaha RX-A660 turns itself off I only suspect DTS (BGA)
    I WAIT FOR ANSWERS
  • pajdek
    Lenovo Y700-17ISK turn on and off
    by pajdek
    Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
    09-20-2023, 02:49 AM
  • JohnML1975
    Falcon FF32S53 turns off by itself then will not turn back on unless you wait
    by JohnML1975
    Dear Forum members
    I searched for a forum on this model TV and could not find so thought I would start a thread on this model and make
    I will upload some photos and share my trouble shooting steps so far
    07-20-2025, 12:28 AM
  • daigs
    Yamaha P-115 turn on but No sound - Doesn't turn off
    by daigs
    I need to repair a P-115 yamaha digital piano with a strange behaviour.
    When I power on the piano from the dedicated on/off switch, the power led go to ON (red led), but the keyboard doesn't produce any sound, nor in the speakers nor in the headphones.
    When I try to power off (pressing the switch for at least 1 second), the keyboard doesn't power off, the red led remains ON. I need to unplug the adapter cable to switch off the keyboard.
    I checked the 12V voltage rail on the input PCB, after the power plug and it is OK.
    I checked also the...
    07-18-2023, 03:47 PM
  • robante15
    Acer Aspire 4520 won't turn on after reboot
    by robante15
    Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
    It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
    The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
    If I remove the...
    04-06-2024, 06:50 PM
  • masoksian
    Dell latitude e7470 not turn on .power buton on off and Run Power problem
    by masoksian
    I am dealing with the problem of turning on and off my Dell e7470 notebook.
    The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
    The system does not turn on, there is no post.
    I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
    The problem continues in the same way.
    I tried to turn on the Fn key, nothing came to the screen....
    02-15-2025, 12:08 PM
