Sony HTG700 soundbar buttons not working.
  • JakeShaw
    • Mar 2023
    • 8
    Remote inputs are great and functional, but after 2 mainboard swaps the buttons have stopped working altogether, seemingly. The remote is required to power on and reset, but no amount of messing with it has gotten anything to respond.
    Checked plugs, everything is good, unhooked it and tried a different main, nothing. As everything else is functional I have no clue what else to do.
    Even replaced the button board itself, still no response.
    Listening to Drab Majesty, Chime, Deftones, and other Rushdown Label artists. Professional tech.
  • JakeShaw
    • Mar 2023
    • 8
    Re: Sony HTG700 soundbar buttons not working.
    Thought I would give an update that there has been little progress. Shoulda kept the main board that for-sure functioned, had I known this was going to happen.
    So I'm reordering the parts to try it again. Schematics aren't revealing anything interesting and the lands/wires moving power are looking fine so it has to be something between the main board and the keyboard. My suspicion was the OLED board but that hasn't solved anything as of yet. Going to do a full reorder or parts to see what went wrong.
    • JakeShaw
      • Mar 2023
      • 8
      The moment after I made my last post I got it to work. New version of the keyboard [9-301-003-96] worked just fine. No idea why this one worked, the previous one didn't, but the original one did. Possibly DOA.
      Daily reminder to not be an idiot, I guess.
      • noipi
        sony vaio VJS112C11W FAN NOT WORKING
        by noipi
        I tried to check and look for the Boardview and schematic for this Sony Vaio with mb marking DA0MSAMBAG0, the problem of this sony is the fan not working or spinning, i checked the 5volts to red and yellow, black zero volts and white zero volts. i checked the fan and test to direct 4volts it is spinning. Any diagram to trace this fan not spinning. i change the new fan still not work. Any one have a boardview and schematic diagram?...
        05-26-2025, 09:01 PM
      • lafilipczyk
        lc 80le632u - Lamp error - TV working after counter reset via buttons
        by lafilipczyk
        Hello everyone, I just got my hands on a Sharp lc 80le632u TV that initially had the 1 short, 1 long blink sequence. That indicates a lamp error, however if I follow the isntructions to reset the error counter, the TV starts correctly: no missing LEDs everything lods just fine.
        I went through the process to get to the diagnostic screen, and got this ( attached).
        Since all LEDs are working correctly, and the TV seems to load fine after reset, that tells me that the power board and the LED strips are working correctly. Could this be a main board issue?
        Any...
        07-29-2024, 11:00 AM
      • zyklop
        Philips Soundbar TAB8507B/10 stopped working
        by zyklop
        Helllo everybody....
        i have this soundbar to repair for a friend. Its finally 2 years and seldom used but already broken.
        Inbetween it has one time started, but no more yet.
        Is anybody who has schetatic or service maual ?!
        Power supply seems to be ok and has stable 24V DC. No control line or somthing else...........
        No thermal hotspots or something else controlled with thermal imaging cam.
        No reaction on remote control (function ok, can see it while glow into mobile-camera)
        No shorts to detect.
        ALso tested all reset procederes...
        07-07-2025, 05:08 AM
      • mintka
        Pad PS 5
        by mintka
        PS 5 pad only works on USB C cable all buttons are functional. Charging indicator does not light up does not connect to console. Battery is functional 4.16 V measured outside the pad. No reaction to PSN button does not light up console does not detect it. I took out the disc, read it may be the charging system. My question is how to measure it to be sure. Where should I start diagnosing. Please help me repair it.
        I replaced the battery with a working pad, still the same, it does not connect to the console. I put the pad on the original Sony charger, it has a different charging pinout,...
        04-12-2025, 11:23 AM
      • modtool
        Sony PS4 slim CUH-2216A power supply ADP-160FR not working after short in PFC
        by modtool
        Dear forum members,
        I'm working on this power supply for ps4 slim, that behaves in a similar manner as other cases but I can't find a way to solve the problem.
        When it came to me, externally the ps4 had standby voltage, clicking the disc eject button made the triple beep (without disc inside) and cliking on the power button made the blue power light turn on and then all turned off within 1 second.
        When I opened it up, I found these components shorted:
        Q6 24N60M2
        IC41 1612A (not really shorted but had a hole on it and all pins measured open circuit but the 9th...
        05-31-2023, 08:09 AM
