Ampeg PF-350 low volume and other issues
  • Camarada78
    • Jan 2021
    • 28
    • Brazil
    i have an Ampeg Portaflex PF-350 on my bench for repair. It works but with very low volume, 1/3 of what you'd expect. Much lower than any 100-150w amp i have around.
    It has SMPS and a class D amplification. Looking inside i found two issues:
    - found R94 and R98 burned near the Q10 and Q13.
    - found that i'm gettin +80v/-80v instead of the +55v/-55v shown on schematics.
    The overvoltage is probably the reason why the R94/R98 keep burning. But i cant find what is causing it. the SMPS side seems ok. I'm getting 176v before the transformer.
    What i've done so far:
    - since Q10 and Q13 were ok, i tried beefier resistors. also burned.
    - changed Q10 and Q13 (both 33n25)
    What would make the SMSP release 80v instead of 55?
    Anyone experienced with this amp?
    I've annexed the schematics but i could not find the revision I actually have.
    Most schematics online do not have R94/R98 in series with C84 and C97 (as per annexed picture).
  • R_J
    • 9634
    Re: Ampeg PF-350 low volume and other issues
    The resistors are blocked from DC voltage by the capacitors C84 and C97, for the resistors to go open, the capacitors are likely shorted.
    The +/- 55 volts is unregulated so it may show higher when the power amp section is not operating
    • freethink
      Kenwood KR-A70 Receiver Balance changes with volume controls?
      by freethink
      I have a Kenwood KR-A70 Receiver on the bench, and the digital volume control is acting very funky. When I adjust the volume, the balance also changes. Volume Up = balance goes Left, Volume Down = balance goes right. Has anybody ran into this issue, or know what the problem might be?
      11-23-2025, 07:53 PM
    • crackedprint
      Sony HCD-HX80R Amplifier Volume Control Problem
      by crackedprint
      I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
      I have tried a Cold Reset as per the service manual.
      I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
      I have looked all the way through the service manual and tried many online...
      01-21-2025, 12:18 PM
    • gretti
      MSI Z370-A Pro, works but does not power off or reboot and USB issues
      by gretti
      I have a MSI Z370-A Pro. The board does not reboot or shut down from the Windows recovery console. USB communications stop and the status light on USB 1 stays on and does not blink. I have programmed a new BIOS with a CH341A programmer already, swapped RAM, PSU, CPU. The board will power off when the power button is held and resets when the reset switch is pressed, but it will not react to the reset switch if already told by software to shut down or restart. The board will reboot from BIOS after a save and exit command.
      The MSI BIOS included the ME firmware for the board. The size...
      10-16-2025, 02:14 AM
    • BigOof
      Marantz SR5007 popping on volume change and mute in Direct Mode
      by BigOof
      I bought a used Marantz SR5007 and it's giving me some issues that I can't seem to really place. It functions well in most settings, ARC mostly works, it has no issues driving my speakers in any of the digital input modes, but I'm having issues running analog inputs in direct or pure direct mode. For some reason in this mode there's distortion for every volume increment I give it, but once the volume is stable it has no issues. Muting creates a loud pop, switching to another source also causes a pop and so does turning off the amp in that mode. Again, no issue in the digital modes....
      12-12-2024, 06:15 AM
    • dkneyle
      Onkyo DX-V500 Laser Disc Player - weird SMPS fault
      by dkneyle
      This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
      Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS...
      02-01-2022, 02:08 AM
