SU8022 , Technics left channel distorted. Schematic please
  • zen
    • 511
    Replaced the 2 STK0039 chips , plus swapped the left & right pre-amp drive boards , with no change in symptoms.
  • CapLeaker
    Leaking Member
    • 8254
    Re: SU8022 , Technics left channel distorted. Schematic please
    Here is a scanned schematic... better than nothing.
    • zen
      • 511
      Thank you very much
      • lotas
        • Jan 2016
        • 4677
        • Russia
        Here's another.
        • zen
          • 511
          Thanks Lotas
          • CDNBrewer
            Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
            by CDNBrewer
            Hello Everyone,
            I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
            Symptoms:
            • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
            • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
            • I swapped the Left and Right surround
            08-05-2025, 09:29 PM
          • Sik_6ty_Sixx
            HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
            by Sik_6ty_Sixx
            So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
            02-18-2025, 05:06 AM
          • HelpMeRepair
            Yamaha RX-A3010 left channel no signal
            by HelpMeRepair
            Hi everyone , I have a rx-A3010 that all alllll the channel working except of Front left , if someone can lead me on what to begin wit it would be very helpful
            what I did so far ,
            factory reset
            test all other channel
            tone test
            dissasemble and look , visual inspection witout full dissasembly
            looked at all the mosfet for temperature to see if they eas operating
            scratch my head couple of time
            thanks in advance all help is appreciated , service manual are welcome too ! =)...
            11-14-2024, 02:48 PM
          • eccerr0r
            old X58 triple channel board... memtest86 memory speed?
            by eccerr0r
            Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
            Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
            Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
            06-28-2025, 09:06 AM
          • sima112
            Marantz pm 6005 right channel not worknig
            by sima112
            Hi guys,
            I need a help with my Marantz pm6005. It started to have weaker the right channel a few months ago, than it got back to normal and now it has lost sound completely on the right channel. At the final stage it was loosing the channel for a while and than it returned. After it has disappeared completely I could forced it back by unplugging the source form CD (which I normally use) to phone and back. It would then work for a few minutes and died again. Now it is possible power up and all function works normally (apart the right channel ) on all inputs, except the phone both channel...
            01-30-2023, 12:11 PM
