Sonos Playbar No Power (again) after successful repair
  • rotorrocket
    • Mar 2023
    • 8
    My Sonos Playbar wouldn't power on, a typical power board issue.
    I tested the rectifier and the MOSFET with a multimeter. I had to desoldered the MOSFET to ensure I got an accurate reading and it tested good. Used fresh thermal paste for the heatsink and resoldered it to the board. The rectifier tested good on board and wasn't removed.
    I replaced the two 400v 100uF capacitors that looked suspect and know to fail. The ESR meter table doesn't have a 400v capacitor listed so I just replaced both with the same. The smaller capacitors tested good with an ESR meter on board.
    Nothing else looked suspect on the power board.
    Screwed the whole unit back together (whew) and it came back to life!
    I used the Playbar for about 45 minutes at a normal level without any issues and shut it down as I was done listening to it. I unplugged the unit.
    The next day I plug the unit back in and it's dead again. No power.
    It wasn't plugged into the same outlet when it first failed. So it's not an outlet issue.
    Totally perplexed.
    Any assistance would be greatly appreciated.
  • R_J
    • 9549
    Re: Sonos Playbar No Power (again) after successful repair
    Try replacing the startup cap for the smps ic.
    • rotorrocket
      • Mar 2023
      • 8
      Thanks for the reply.
      Here's a picture of the board.
      • rotorrocket
        • Mar 2023
        • 8
        The small cap between the rectifier and the heatsink?
        • R_J
          • 9549
          This should be the one, it should be off the vcc pin of the ic, Post the number that is on the ic, it's datasheet may have a sample schematic.
          • rotorrocket
            • Mar 2023
            • 8
            Here's a picture.
            Looks like TE5AA
            Thanks!
            • R_J
              • 9549
              It is a FAN6300H, the cap. should be off pin6
              • rotorrocket
                • Mar 2023
                • 8
                Couple more pictures of the suspect cap.
                • rotorrocket
                  • Mar 2023
                  • 8
                  And another.
                  Helpful?
                  • R_J
                    • 9549
                    Originally posted by rotorrocket
                    And another.
                    Helpful?
                    There is no way to tell if the cap is dried out and has lost capacity from a picture, these caps rarely bulge or leak. but if the capacity is low it will not charge to start the ic and keep it running, You could check the voltage on pin 6 (please don't short the pins). This is on the hot side so you need to use hot ground for the negative of your meter (pin4 is connected to hot ground)
                    The voltage needs to be above 16v to start. usually runs about 20~25v, if pin6 drops below 10v the ic turns off
                    • rotorrocket
                      • Mar 2023
                      • 8
                      Thanks. Would you happen to know the cap specs? Unfortunately my only pics don't capture it.
                      It's all put back together at the moment and would like to get a replacement ordered right away so I have it ready if it's indeed the culprit.
                      • R_J
                        • 9549
                        Your pictures do not show the value, I suspect it is between 10~47µf and around 50v, Any good quality 105 degree cap would be ok. This may not be the problem, since the fault is intermittent it could be a poor solder connection on one of the components.
                        • duder
                          • Oct 2013
                          • 26
                          • canada
                          This may help others. I had a similar problem. I had replaced the fet, controller i.c., a 100 ohm resistor and the startup capacitor. The power supply would not start. Then I noticed the diode (bat54c) and 100 ohm resistor at the gate were blown. Also the 4 resistors (0.15 ohm) at the source of the fet were blown. I replaced those and everything is good.
                          • GLISIT
                            by GLISIT
                            01-16-2025, 02:29 PM
                            09-06-2024, 05:59 AM
                          • Goldwing1973
                            Sonos Play 1 pulsing power supply
                            by Goldwing1973
                            I'm rather new to repairing electronics, i do know the basics of most components but never actually repaired a PCB, but i want to change that.
                            So, i bought a faulty Sonos Play 1 speaker with the intention of finding the fault, and replace the damaged part.
                            Well, i did find the fault, i replaced parts that i thought caused the problem, but no-go.
                            The problem is a pulsing power supply, when i connect the mains to the board and hook up my thermal cam i see R306,307 and 308 getting warm, but i assume that's normal.
                            But, whats is not normal is the pulsing of resistor...
                            07-04-2025, 12:59 PM
                            HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
                            This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                            09-12-2024, 02:15 PM
                          • meraklinetx
                            Asus Z97-a power cycle, no boot no cpu voltage
                            by meraklinetx
                            Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                            05-10-2023, 06:08 AM
