Cambridge Audio 640P Phono Preamp has Cheap Xunda Caps
  • Hypnotoad
    • Aug 2010
    I recently bought a used Cambridge Audio 640P phono preamp.
    I thought it didn't sound right, being overly bright compared to my other phono stages.
    I got it as a project because I have read many threads about improving the sound by upgrading the capacitors.
    I opened it up and all the electrolytic's are labeled Xunda.
    The funny thing is this unit is not very old but there is brown stuff that looks like it either leaked from inside or it could be the outer coating has melted.
    Not a good sign.
    I ordered replacements for the whole thing.
    Nichicon for the power supply and Elna Similic II for the audio sections.
    The Xunda's seem to be cheap chinese rubbish as why would they leak so soon?
    Why would a respected company like Cambridge Audio use such stuff, I know it's cheaper but it can't cost that much more to use decent ones?
    Here is an example, notice the brown stuff next to the cap on the upper right. looks like it did doodoo:
    Also a quick question, where can I get 22pf, 33pf and 47pf film caps? I also want to replace the ceramic bypass caps as well.
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: Cambridge Audio 640P Phono Preamp has Cheap Xunda Caps
    Cambridge Audio = Creative. Creative is notorious for using ultra cheap caps and 4558 opamps even in their supposed "high-end" stuff, at least since 2000 or so, coz my ole trusty AWE64 ISA still works just fine. There is nothing wrong with using a 4558 in a line output, but using it in a high-gain input stage such as a mike or phono input is just plain wrong. A mike gain stage with a 4558 is only usable for Skype.
    A working TV? How boring!
    • Triodethom
      Try handmade at
      http://www.hndme.com/productcart/pc/...?idCategory=25 silver mika or search for polystyrene on google
        • 31015
        cambridge audio are jokers who pray on peidophiles.
        sorry, i meant AudioPhiles
        they used to advertise oxygen-free mains cable and gold plated mains plugs "for smoother power" - fuckers!
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          I thought it was Audiophools here?
          Mann-Made Global Warming.
          - Dr Seuss
            by momaka
            03-12-2025, 03:42 PM
          • eryjus
            by eryjus
            05-10-2023, 11:21 AM
          • Paxman_Swede
            by Paxman_Swede
            Hello!
            01-14-2025, 09:51 AM
          • captain150
            by captain150
            03-16-2025, 07:34 PM
          • Foetuss
            Gigabyte GA-6OXT :: caps question
            by Foetuss
            Good evening
            I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
            Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
            But I was also suprised about the bigger boys, which are 330µF 25V.
            Could it be they used 25V caps because they were cheaper / available at that time?...
            02-11-2025, 12:22 PM
