Definitive BP9060 Power Supply
  • Impossibre
    • Dec 2021
    • 5
    Hey all. I am currently working on a BP9040/9060 amplifier assembly that has failed. The problem itself lies on the power supply board. There are missing components and DefTech will not supply a schematic for current product lines. The components in question are U7, R14, R15, R17, R18, R21, and D3. If anyone has access to the schematics and can help me with identification of these components it would be fantastic. Thanks!
  • R_J
    • 9594
    Re: Definitive BP9060 Power Supply
    Post clear, good quality pictures of both sides of the board. Based on pictures on the internet, R14~R18 are (47Ω). I suspect there is a lot more wrong than just the missing parts, It is likely the main switching mosfet shorted, causing all this damage.
    It is obvious someone else worked on it, so who knows what else is wrong.
    • Impossibre
      • Dec 2021
      • 5
      I was actually going to reply and clarify/confirm your theory. I am the first to work on this board and the components in question have been destroyed from the cascade failure following the mosfet (Q1) going out. Or at least that is my standing theory. U7 receives the input from the optocoupler and thus I assume it controls the switching. The top is blown off, though it remains on the board so I can't tell what it is. The protection diode (D3) is shorted between U7 and Q1 drain. R21 runs to U7 from the bank of resistors (R14-18) and has a chunk of the face missing so I cannot read the marking. R14-18 are completely blown off the board. I will be removing Q1 from the circuit to verify failure tomorrow. I apologize if I was vague before as in truth I was not expecting much in the way of help. I am currently unable to upload the pictures, but I will be uploading pictures of the boards when I get home. With some close-ups of the damage as best I could take from the eye piece of my microscope. Thanks again for replying to me!
      • R_J
        • 9594
        Look inside the cabinet for the top of the ic, If you were the first to open it, it must be in there.
        Here are pictures found on the internet
        U7 is the pwm ic for the circuit, the optocoupler controls the ic to regulate the secondary voltage.
        D3 could be a MMBD4148 across R19 47Ω (gate drive), as a guess R21 could be a 540Ω or 5.4k this resistor is for the CS (current sense) of the ic. it is between Q1 source and the CS pin of the ic.
        • Impossibre
          • Dec 2021
          • 5
          Enclosed are pictures of the board/damage. Haven't gotten an opportunity to search the speaker cabinet as of yet.
          • R_J
            • 9594
            My FIRST Guess at the ic is OB2269CP, so look for that top piece, it is important
              by sam_sam_sam
              03-31-2024, 02:12 PM
            • JimBanville
              Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
              by JimBanville
              The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
              Opened it up and discovered the power supply is making a faint clicking or ticking sound.
              I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
              I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
              09-13-2023, 07:21 AM
              by sam_sam_sam
              07-01-2024, 06:34 AM
            • cheeky2
              Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
              by cheeky2
              This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
              I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
              Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
              06-15-2025, 05:12 AM
