Blomberg electric dryer - Need a replacement relay
    • Jul 2011
    • 6023
    Re: Blomberg electric dryer - Need a replacement relay
    Originally posted by redwire
    because children apparently climb in there for a wash or dry.
    They are not supposed to do things like that
    • steves7839
      • Nov 2014
      • 200
      I replaced the suspect relay with new, but it made no difference. The control board I ordered over a month ago is still out of stock. Any leads to an appliance parts salvage are welcome.
      • ajshoe
        ajshoe
        • Dec 2012
        • 477
        • usa
        have you pulled both relays out and tested them ? did you ohm the wires off the relay that go to the coil for proper resistance ? dryers are fairly straight forward - easy to repair.
        please post model #
        there's one on EBAY https://www.ebay.com/itm/194280574677
        marked washer but its a dryer control board that seems to be the one you need
        another one cheaper - https://www.ebay.com/itm/19381880177...Bk9SR6rHnKGFYQ
          • 30928
          did you check for any thermo-switches usually fitted as a final safety?
          • steves7839
            • Nov 2014
            • 200
            Originally posted by ajshoe
            there's one on eBay.
            Just Wow! Thanks for those links! I have been searching eBayzon and the web for over a month, but using Blomberg or the bare board number as search terms. Ordered on sight.
            • CapLeaker
              Kenmore electric range replacement infinity switch?
              by CapLeaker
              Actually this range had multiple problems but I fixed all the others already.
              I am stuck finding a replacement infinity dual burner switch for a Kenmore C970-605121. The dual burner is stuck full on as soon as you turn the knob either side, either the difference of either only one or both burners running full tilt.
              I tried cleaning it inside contacts, but that didn’t do anything.
              I believe the dual burner switch reads a part number of: 318191021 which is hard to find. I came across a 318191026 part number but it has 2 pins on the row missing. Is there anything...
              05-14-2023, 12:03 PM
            • Sam Scarbo
              Blomberg DV17600W laundry dryer MCU firmware needed. Please help!
              by Sam Scarbo
              I'm helping my brother to fix his Blomberg laundry dryer. He called a repair guy to have a look and the repair guy said the control board is faulty. They said the replacement board costs $400. Too expensive! 😨 My brother asks me to take a look. He has checked the door switch and thermal fuse, etc., and those seems fine.
              After plugged to mains, there is no display. There is just a clicking sound from the buzzer, like one click per second. No other response.
              I suspect the firmware inside the MCU (ATMEGA64A) got corrupted. Can someone in this forum by any chance provide...
              07-21-2024, 05:24 PM
            • Benass
              Looking for Suitable Relay Replacement.
              by Benass
              Hello. I have Industrial Washing Machine PCB.
              Customer Requested Relays Replacement.
              I can't find WJ115F1 relays to buy. Looking for some help to identify possible alternative solutions.
              Or any tips, on how to approach this situation....
              04-21-2023, 01:51 PM
            • jm1234
              9V relay temperature 40C
              by jm1234
              Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
              I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
              05-09-2024, 03:03 AM
            • edugimeno
              Biomass Boiler not driving cleaner motor relay. ENERTRES BIOMASA BI-650
              by edugimeno
              Hi everyone!
              I have this board that suddenly stopped supplying power to an output that drives an interchanger cleaner motor.
              I checked while the board was in place with all wires attached and there's no AC voltage on the corresponding plug X5
              This X5 is driven by fuse F8 (tested OK) which comes from the second orange relay
              To make sure there are no charcoaled contacts inside the relay, I got a 24VDC power supply and got it ready to manually power up the coil side of these relays.
              I respected the polarity, positive to cathode of protecting diode
              So provided all...
              04-18-2024, 01:15 PM
