Hitachi Refrigerator R-Z270AUN7KV not cold.
  • redwire
    • 3910
    Re: Hitachi Refrigerator R-Z270AUN7KV not cold.
    These timer motors run constantly I thought?
    The switch seems to be in series with the compressor, so they disable it, run a heater cycle to defrost, and then allow power for the compressor again.
    You could check the timer motor's resistance (pin 1-3) to see if it is open-circuit or not. The leads are not soldered to the tabs so maybe a bad connection. Some diagrams show a resistor or fuse "C"? in series with the timer motor.
    Sankyo/Hitachi TMDFX05CD1 is a special cycle time, 6min/12hr.
    TMDF706CD1 is close, 7 minutes defrost with 8hr cycle (50Hz).
    • R_J
      • 9549
      The schematic of this fridge is in post#11, You can see that the thermostat switches the a/c on and off to everything but the fridge lamp. The defrost timer only runs when the thermostat is closed, When it is time to run the defrost cycle the compressor is turned off. The defrost cycle time is not that critical as the amount of frost built up is also not predictable.
      • SuperAman
        • Dec 2018
        • 119
        Originally posted by R_J
        The defrost timer only runs when the fridge/compressor is running. The defrost motor is connected across pins 1 & 3, check the resistance of the motor, if it is good then maybe you can get some type of cleaner to wash out the motor and the reduction gears inside it? If not just replace the timer, If you can find a used one it should be ok, you can order them off the internet, just be sure to get the right voltage (ac200~240)
        #54 on the diagram is that a temp sensor for the heating element? I'm getting open reading with the meter. How do I test that? I think it might be faulty as well. There are two thermostats in the freezer compartment one is embedded in the coils and the other one next to the fan motor. How do I check them with a meter?
        • R_J
          • 9549
          I don't know which one it is but if you look at the schematic, there are two, a thermal fuse and a defrost thermo (thermostat) , You said that when you turned the defrost timer so it would defrost that it was working and heating up. if this is the case both thermo devices must be working.
          Did you check the defrost timer motor resistance? If the defrost element was heating up when you turned the timer to its defrost position, you have likely found the problem, if the other parts were bad it would not heat up.
          • redwire
            • 3910
            If the fridge runs say 6 minutes every hour (10% duty cycle) with a 6min/12hr defrost timer (wired to the compressor) it will defrost every 5 days for 1 hour. Seem too long to me, but not relevant to OP's problem. It might be a schematic error.
            I've had problems with a leaking door seal on the freezer causing the evaporator coils to ice up.
            Reposting the schematic for the Hitachi fridge.
            The fixed thermostat in the evaporator coil goes open-circuit when it's hot, but will read zero ohms cold - Some popular defrost thermostats: Open 45°F, Close 25°F, Differential 20°F; another is Open 55°F, Close 35°F, Differential 20°F. Not zero ohms at room temperature.
            So the thermostat needs close to freezing or colder for the switch contacts to close.
            • R_J
              • 9549
              I believe the defrost timer in my fridge works like this, for every 6 hours of "compressor run time" the timer will then defrost for 25min.
              The TMDFX05CD1 = for every 12H of run time it defrosts for 6min
              • SuperAman
                • Dec 2018
                • 119
                So can I replace mine with one that runs 6, 8, or 10 hrs? I don't think I can find one locally that runs 12hrs. Importing one would be cost prohibitive (customs duties and all).
                • SuperAman
                  • Dec 2018
                  • 119
                  I will check it, I put it back together, so I'll have to take it apart again. What kind of resistance values should I be getting from the timer motor?
                  • R_J
                    • 9549
                    I don't know what the timer motor resistance will be, but it is likely fairly high, If it reads anything but open it is likely ok. You can replace it with a different duty cycle, it's not that critical, It doesn't know how much frost is built up at any time so anything will work better than nothing, If you put a lot of hot steamy food in the fridge it will frost up faster.
                    • Th3_uN1Qu3
                      Cooling upgrade on refrigerator. If it works, it ain't stupid!
                      by Th3_uN1Qu3
                      I had this refrigerator at my old folks which I noticed I would put my beer or soda in and take it out warmer than I'd brought it from the store.
                      Now, I don't know much about refrigerators or HVAC but to me it seemed like we have a problem. I threw a thermometer in... 20 deg C in the fridge. WHAT THE... Freezer worked fine with temperatures way below zero, as it should, and it has only one compressor for both sides so it got me scratching my head for a while.
                      Only other things that seemed a bit odd was that the heatsink on the back was barely warm and the...
                      09-03-2023, 06:29 AM
                    • connorcc2005
                      Kenmore refrigerator adaptive defrost timer fix. Part: AP4909015
                      by connorcc2005
                      I have a 20 year old Kenmore side by side refrigerator that was acting up with the following issues:
                      • Evaporator coil in the freezer was frozen up.
                      • Unit was still holding temperature
                      • Evaporator fan would run 2 to 3 seconds on then shut off only to repeat.
                      Defrosted the evaporator coil and began testing. Defrost heater ohmed out good. Defrost thermal switch on the evaporator line in the freezer tested good. Once the evaporator coil was defrosted, the freezer and fridge worked but the fan continued to cycle on and off continuously. I suspect the evaporator coil was destined to freeze up again...
                      03-20-2024, 01:14 PM
                    • CG2
                      Liebherr Fridge Freezer KGT 3456 not working
                      by CG2
                      To be a bit more specific, I've got a 20-ish year old Liebherr that has just stopped working. This was quite a sophisticated beast for its time. It's a twin compressor model, and you set the desired temperatures of the fridge and freezer parts from a couple of little control panels above the door. It displays the actual temps on some eight segment displays there, flashing if it's working to get to where you want it. There's a control board with a microprocessor on it that read the temperature from a couple of sensors, switches the compressors on as necessary, and runs the display. There's also...
                      01-25-2023, 02:12 PM
                    • mikey5791
                      Help repair Panasonic fridge not cooling
                      by mikey5791
                      Hi all forum members,
                      Few days ago, i might have forgotten to close my home fridge freezer door completely. The next day, the ice cubes and frozen meat almost melted halfway and the freezer doesn't feel cool. I shut it off, wipe dry and let it air dry for one whole day. The next day i switched on the fridge, the compressor run for a second and it shuts off(no vibration and no sound at all) only the internal freezer compartment fan is running but is not cooling even i switched on a full day.
                      After shut off, i dismantle the rear water pan holder and reached to the compressor wiring....
                      07-16-2025, 02:01 AM
                    • beetle1303
                      Panasonic Inverter Refrigerator model NR-BY602XS - suddenly not cold overnight
                      by beetle1303
                      I have a 7-year old Panasonic inverter refrigerator model NR-BY602XS that went from working normally to completely not cold air overnight (both freezer and refrigerator compartments...
                      The service manual instruction on Self Diagnostic Test seems to indicated Compressor faulty or locked. But the compressor seems to be working with humming sound and vibrating at variable speed and noise level..
                      Everything else seems to be working normally - power cycled a few times has no effect. All the interior lights, and fan are working. I dismantled the interior panel to expose...
                      04-18-2020, 08:12 AM
